68RFE install questions (revmax 700) - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 04-04-2019, 11:03 AM Thread Starter
So like many others my heavy foot has killed 5th and 6th gear in my 68RFE. I took the plunge and ordered a Revmax Signature 700. Revmax was very helpful in picking the exact specification of my order. The new transmission will be a Signature 700, 17 Blade low stall converter, Cooler bypass delete and the upgraded billet center support. I'll be installing the new transmission after hours at a dealership with a few former mopar techs. I've been doing alot of hunting and still have a few questions.
First some hardware questions. From my experience on my car its a good idea to replace some of the bolts so I was planning on replacing the flexplate and converter bolts. Mopar part numbers I found are 04429522 for the flexplate and 06508406AA for the converter bolts, Can anyone confirm? Also I saw ARP makes flexplate bolts for the 5.9 are they the same for the 6.7 (P/N 147-2901)?
Second a two part fluid question. Revmax says any ATF 4+ trans fluid, has anyone heard anything more specific for this transmission? Figure I'll change the t-case fluid while I'm in there so I found its mopar specific P/N 68089195AA is that correct?
Lastly are there any tips, tricks, special tool reccomendations from anyone whose tackled this before?
Thanks for any help.
2014 Megacab 2500 (Revmax signature 700, EZ-Lynk HPP SOTF tunes, AFE intake, some missing parts )
2010 Mitsubishi Evo X (bolt-ons for now)
nmtevo is offline
post #2 of 6 (permalink) Old 04-04-2019, 08:18 PM
I'm unsure of the hardware, but have you cross referenced the 5.9 mopar part number to 6.7? That should tell you pretty quickly.
I think most built trans guys say to use dex, so I'd double check that.
Special tools, well, a barring tool is nice for converter bolts but not necessarily needed. Otherwise it's normal sockets, wrenches and heavy lifting.
Sent from my SM-N960U using Tapatalk
16 MCSB - Trans - Air - No Fuel (yet) - Thuren Perscription
18 JL Ruby - Wife Wagon
19 HC Challenger M6 - Ordered
suns out guns out is offline
post #3 of 6 (permalink) Old 04-05-2019, 10:09 AM Thread Starter
Thanks, I'll add the barring tool to my list. I tried cross referencing the part number for the 5.9 and 6.7 but have seen different answers from different parts suppliers.
nmtevo is offline
post #4 of 6 (permalink) Old 04-05-2019, 12:15 PM
https://puredieselpower.com/dodge-pr...#/product/2681
Looks to be the same. I'd call ARP to double check because their website is atrocious.
post #5 of 6 (permalink) Old 04-05-2019, 01:00 PM
ritchie1087's Avatar
i used mopar atf +4 as was recommended by my trans builder
ritchie1087 is offline
post #6 of 6 (permalink) Old 04-05-2019, 03:26 PM Thread Starter
Thanks everyone, ended up ordering Mopar fluids and bolts. The arp flexplate bolts should fit but I did not get that confirmed. The part number of Mopar flexplate bolts and ARP are both listed as M12 x 1.25 thread. The length should also work ARP UHL is .7" (converted to mm 17.78) Mopar was 18mm.
nmtevo is offline
Similar Threads
68RFE Full DIY Rebuild - Revmax 850 Kit Mopar Muscle 07.5 - 09 3rd Gen 6.7L Powertrain 10 04-12-2018 04:39 PM
2011 ppe duel fueler install questions allhookedup 4th Gen Performance Parts Discussion 2 09-05-2015 09:39 AM
Revmax valve body and trans (68rfe) Txroofer 07.5 - 09 3rd Gen 6.7L Powertrain 26 05-19-2015 05:35 AM
Couple quick valve spring and push rod install questions ctd2001 98.5-02 Performance Parts Discussion 16 11-09-2012 03:59 PM
Tranny Temp gauge install questions Leo43 07.5 - 09 3rd Gen 6.7L Powertrain 2 04-04-2012 12:52 PM
