2016 68RFE, 3 to 4 Shift Goes to 1st, Delayed P to D - Dodge Cummins Diesel Forum
 1Likes
  • 1 Post By sicumminsde
post #1 of 5 (permalink) Old 04-03-2019, 07:56 PM Thread Starter
Hello all,
Long time learner, not much posting. Thank you for all I've learned here through multiple trucks.
I have a 2016 with 70k miles. Hardway 170 psi transmission tune. I drive like an old man and don't pull much of anything ever.
Today while driving the truck would rev but not accelerate at ~50 mph during a downshift when I applied throttle. I was only able to drive it in 1st. I pulled the battery cables to reset everything, and immediately noticed that shifting from Park to Drive resulted in a delay and hard shift. It drove normally until the shift from 3rd to 4th, where it immediately would rev and not apply power. I used the switch on the shifter and noticed that the truck thought it was in 4th. I can lock it out at 3rd gear and it works normally (other than the delayed and hard shift from P to D). Once I manually allow an upshift to 4th it goes wonky again.
So, how broken is it, and how broke will I be?
Thank you in advance for the assistance.
Ty
2016 4x4 2500, Thuren tuned Kings, 35's, ATS Stage 3, TBE, Hardway Tune
Bent is offline
post #2 of 5 (permalink) Old 04-03-2019, 10:18 PM
https://www.cumminsforum.com/forum/4...ure-68rfe.html
Bent likes this.
2013 2500 CTD Laramie 4x4 68rfe
sicumminsde is offline
The Following User Says Thank You to sicumminsde For This Useful Post:
Bent (04-04-2019)
post #3 of 5 (permalink) Old 04-16-2019, 07:38 PM Thread Starter
I've learned a lot from this message board, and out of respect for what I've gained I thought I'd post the results of my recent failure.
I had the truck towed to ATS (1 mile from my office). They took the transmission apart and found the valve body blown apart with a bent accumulator plate, warped clutch packs and fried OD clutches.
I bought their Stage 3 transmission kit complete with co-pilot. I had no idea what I was missing. The shifts are incredible and the "surge" after shifting in higher gears is unreal. I'm happy knowing that I probably have a forever transmission.
Thanks for the knowledge.
Ty
Bent is offline
post #4 of 5 (permalink) Old 04-23-2019, 05:34 PM
Just wondering if they mentioned the cause of the failure? Is this something running the higher line pressure tune could have caused? I’m currently running the raceme trans turn which boosts the line pressure, and have always wondered if it is actually “better” for the trans.
I’ve always thought Cummins/ram should get a deal with a company like ats and make it a factory option, it would fix their one weak link!
WhiskeyThrottle is offline
post #5 of 5 (permalink) Old 04-23-2019, 06:57 PM Thread Starter
There is so much more knowledge on this forum than what I have. I'll let the smart people answer you properly.
But, my understanding is that the tuner induced increased line pressure (from 160 to 170) is not the issue. The issue is that it needs much more pressure than than to keep the clutches from slipping, and the stocker can't make more pressure than 170.
And, the VB leaks inside and the accumulator plate is weak.
The $8k was a painful hit, but I'm happy with the fact that I have a more reliable "forever" truck.
Bent is offline
Similar Threads
68rfe shift issue Jim.slobe 4th Gen Powertrain 4 07-24-2018 07:20 AM
2016 Transmission Shift Delay bills12ram 4th Gen Powertrain 7 04-25-2017 11:01 PM
68rfe to G56 swap. Everything you need to know and my swap. JGray.proaudio 07.5 - 09 3rd Gen 6.7 Liter General Discussion 13 10-06-2014 12:18 AM
Delayed 3-4 shift? leever95 94-98 Powertrain 3 01-23-2013 09:56 AM
68RFE doesn't shift into 5 or 6 cvandyk 07.5 - 09 3rd Gen 6.7L Powertrain 6 01-12-2013 06:14 PM
