Aux tanks voids warranty - Dodge Cummins Diesel Forum
 9Likes
post #1 of 24 (permalink) Old 03-12-2019, 01:04 PM Thread Starter
So I took my truck a 2015 3500 CTD with the 68rfe with 78k miles that is completely stock other then a transfer tank to the dealer for an odd knocking sound. Zero other issues.
I have now been told it needs a complete fuel system tank to injectors due to metal shavings in the fuel.
The transfer tank is plumped through a 2 micron CAT filter before it hits the factory tank and both factory fuel filters are still in place.
They are denying the warranty based on the fuel system has been modified and are suggesting i contact my insurance company to file a claim.
I'm hoping someone here has some advice.
Thanks.
Lins likes this.
T.j. Skibyak is offline
post #2 of 24 (permalink) Old 03-12-2019, 05:28 PM
Find a new dealer.
dhoagland likes this.
2018 CCLB 3500 SRW 4X4 Laramie - Air Bags - BW Companion - Cat 2 Micron Fuel Filter - Amp Steps - Thuren 1.75 - King 2.0 IFP - PML Rear Diff Cover
2018 Grand Design Reflection 28BH 5th Wheel
Phillipjon is online now
post #3 of 24 (permalink) Old 03-12-2019, 06:25 PM
KATOOM's Avatar
I'd ask the dealer why the trucks come with fuel filters if they apparently arent going to stop metal shavings from leaving the fuel tank and reaching the injectors. So many things wrong with their bonehead response...
KATOOM is offline
post #4 of 24 (permalink) Old 03-12-2019, 06:53 PM
Diesel Freakazoid
Loki223's Avatar
I agree with both of the previous 2 statements. the dealer is looking for an out. the factory fuel system is not modified, only supplemented with an additional fuel system. How long have you had the aux tank installed?
2012 MCSB DRW 3500 Laramie Longhorn, EFI Live By ANARCHY Diesel, 4" flopro turbo back with muffler, S&B air box and filter, Edge Insight CTS2, 2" HBS level, Bilstein 5100s in all 4 corners with steering stabilizer, PacBrake Airbags, GDP Fuel Filter under the hood, Supernova V3 LED headlights and my EGR stuff ran away, lemme know if you find it
HELP ME UPDATE MY IMAGES, IF YOU SEE A BROKEN IMAGE LINK, SEND ME A PRIVATE MESSAGE SO I CAN UPDATE THE IMAGE TO A NEW HOSTING SITE
Loki223 is offline
post #5 of 24 (permalink) Old 03-12-2019, 07:20 PM
tankerpilot01's Avatar
I would research: https://www.consumer.ftc.gov/article...ne-maintenance
My understanding is a dealer would have to prove what you did caused the need for repairs. Iím not a lawyer; but if expensive enough maybe a lawyer would have to get involved. If your aux tank fed directly to engine and bypassed the factory system of filters, etc. but if aux tank feeds into factory tank then no way they could prove fuel from one tank into factory tank caused it. Thatís like saying fuel from pump would void warranty.
Jimmy N. likes this.
Rat
2018 3500 Limited Tungsten 4x4 Dually-True Blue Pearl - CC - 8'
tankerpilot01 is online now
post #6 of 24 (permalink) Old 03-12-2019, 11:28 PM Thread Starter
Officially told to screw myself. Quote I received was 23k for all the required repairs.
post #7 of 24 (permalink) Old 03-13-2019, 12:09 AM
That is all a line of crap from a thief. They did not even diagnose your complaint. PS, bad injectors are a common issues on 6,7L. Was it an engine knock or chassis knock?
Did they show you these metal shavings?, no they made it up.
Also who and where did the aux tank?
Where are you?
Try a different dealer or Chrysler FCA Customer Service or the local service rep for FCA.
Then call the State Department of Consumer Affairs, for Automotive repair. In CA they have the number posted on the wall in the service department.
bigfish95971 is offline
post #8 of 24 (permalink) Old 03-13-2019, 06:30 AM
lauber_03's Avatar
Like others have said they must prove that it directly caused a failure. However pretty much across the board fuel contamination (not saying thats what happened) is not covered by any warranty i know of. Did they provide a sample of the shavings? Fuel? Any rust covered parts from the cp3, rail or drop the tank and show that there was anything?
cwendel likes this.
2012 3500 cclb 6spd manual. Two turbos and other fun stuff that drains the bank.....
lauber_03 is offline
post #9 of 24 (permalink) Old 03-13-2019, 06:18 PM
You should add a cheap inline filter from the tank to the truck. You may be surprised what it catches.
Sent from my SM-N960U using Tapatalk
WJHauling is offline
post #10 of 24 (permalink) Old 03-13-2019, 06:25 PM
He did much better, fuel goes thru 2 micron cat filter before entering factory tank. See original post.
2015 Ram 3500 CCSB 4x4 Aisin SRW
007Poke is offline
post #11 of 24 (permalink) Old 03-13-2019, 06:27 PM
Maybe you missed this part...
post #12 of 24 (permalink) Old 03-13-2019, 07:21 PM
Yes I must have missed it. Sorry
Similar Threads
Aftermarket extended warranty. Help me decide please!! Boots11234 4th Gen Non-Powertrain 8 05-12-2016 11:59 PM
Running ATF in my 06 amazes even me. Ole Smoky 3rd Gen. Powertrain 224 12-07-2015 10:08 AM
Not to sound too stupid but.. voltage1256 2013-2018 General Discussion 44 02-12-2014 06:37 AM
Check engine light and warranty question. 2LO4ME 4th Gen Powertrain 9 12-30-2012 07:43 AM
Fuel Requirements For Cummins Engines - Service Bulletin 3379001 LReiff Technical Service Bulletins & Recall Support 9 11-17-2012 02:48 PM
