Question about tubing if and when. - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 02-12-2019, 06:04 PM Thread Starter
Hello, I hope I'm posting in the right section and this might be a obvious question.
I drive a 2011 6.7 3500 with 125k miles and its deleted.
My stock holset vgt turbo has gone out and I need to replace it. I've looked into 2nd gen swaps but its not something I'm wanting to go for at the moment. (Just trying to get my truck back).
That being said I was recommended the s300 replacement kit that lets me drop the new turbo right in without manifold or anything.
I'm replacing it with a 64.5/.90 size turbo that's supposed to be close to the same Set up as the stock turbo.
My question is, when I replace the old turbo with this s300 turbo, do I absolutely need tunes right out the gate or am I safely able to drive it without causing any damage before I get tunes?
The truck has an H&S tuner that doesn't work anymore. Outside of that I don't know what's been done.
I hope I didn't miss any key info and thanks a ton for any help.
-Nate
Natebrody11 is offline
post #2 of 6 (permalink) Old 02-15-2019, 10:32 PM
Cacciatore's Avatar
Why doesn't the H&S work anymore? Screen dead?
You can unplug VGT and roll with the CEL
2011 2500 CCSB|Carli|5 blade 72mm|S&S 150%|S&S 12mm|Wilson Patterson 48RE|Freedom Racing Engines 6.8|CTT
2013 3500 MCSB |Carli Backcountry|Baja Designs|Stainless s465|RevMax ZeroFlex|L19|CTT
Cacciatore is offline
post #3 of 6 (permalink) Old 02-15-2019, 10:50 PM Thread Starter
I tried plugging what H&S into the truck and nothing happened and then when i plugged it into a computer it beeped and flashed but i couldn't get it to do anything else.
I'm sorry but what do you mean by unplugging the vgt and running CEL?
post #4 of 6 (permalink) Old 02-15-2019, 10:53 PM
Cacciatore's Avatar
How are you getting power to the H&S OBD2 or a fuse tap?
VGT is the turbo, CEL is a check engine light. You'll get one without proper tuning
post #5 of 6 (permalink) Old 02-15-2019, 10:56 PM Thread Starter
Ohhh my bad I see what you're saying now that I realize what CEL is. Thats not so bad then I was just worried that I wouldn't be able to drive the truck at all without tuning.
Also, There were wires hanging that looked like it may have fuse tapped with a so I tried it with those, and I also tried it with the OBD plug but nothing.
post #6 of 6 (permalink) Old 02-15-2019, 10:58 PM Thread Starter
I apologize about the misspelling there, it looks like it could have been fuse tapped after looking online and the different power options. So I tried the wires I found and then with that not working I plugged it into the OBD plug with no avail.
