P0191 code - Dodge Cummins Diesel Forum
post #1 of 12 (permalink) Old 09-09-2018, 09:03 AM Thread Starter
Lightbulb P0191 code
2012 RAM 2500 just put in a new fuel rail pressure sensor code still pops up after awhile. The truck idles good when the codes not popped but when its comes on the idle might jump 2-300 rpm up every few seconds.truck is deleted and tuned runs great with or without code just idles funny. plz help!
6.7Prius is offline
post #2 of 12 (permalink) Old 09-09-2018, 01:00 PM
N of 60's Avatar
All the time or just at start up when cold?
2011,4wd LB/CC 2500 H&S Mini MCC by Tomeygun, BD protect 68rfe VB seperator plate enhanced stall triple disk TC, Super B 64.5/80/.91 3rd gen mani & inline EB, Arp 425s, Fass Titanium 95. Spare Mini in my closet.
High tech old school and finally lovin it.
N of 60 is offline
post #3 of 12 (permalink) Old 09-09-2018, 01:11 PM Thread Starter
It’s very inconstant it might start doing it cold or hot in gear and in park it might not do it for awhile then do it a few times in a row
6.7Prius is offline
post #4 of 12 (permalink) Old 09-09-2018, 01:33 PM
N of 60's Avatar
FRP #s steady at idle. Within a thousand?
N of 60 is offline
post #5 of 12 (permalink) Old 09-09-2018, 03:33 PM Thread Starter
No idea I don’t have a gauge for it.
6.7Prius is offline
post #6 of 12 (permalink) Old 09-09-2018, 03:49 PM
N of 60's Avatar
Deleted and no monitor?
N of 60 is offline
post #7 of 12 (permalink) Old 09-09-2018, 04:11 PM Thread Starter
Right I have the H&S xrt pro
6.7Prius is offline
post #8 of 12 (permalink) Old 09-09-2018, 04:19 PM
N of 60's Avatar
Ok, Miles on the truck and your fuel/power and timing setting? A monitor certainly would be helpful. Fuel filter is new?
N of 60 is offline
post #9 of 12 (permalink) Old 09-09-2018, 04:51 PM Thread Starter
Just rolled 160k new fuel filter and separator. I’m running the xrt on mild timing on 2.
6.7Prius is offline
The Following User Says Thank You to 6.7Prius For This Useful Post:
N of 60 (09-09-2018)
post #10 of 12 (permalink) Old 09-10-2018, 08:33 AM
ZOP
Decoder Ring Specialist
ZOP's Avatar
See if you've got someone who has an advanced scan tool or MM or similar you can plug in to watch the rail pressure. I'm thinking three possibilities (kind of in order of likelihood, FCA and a popped relief valve are both about as likely, but it sounds more like an FCA) - FCA on the pump, popped relief valve, or restricted fuel filter. If it's the FCA you can have RP all over the shop or stuck high. If it's the relief valve, it'll be fine/normal, and then the thing unseats and it can't make pressure. restricted fuel filter usually won't clear up and she'll be gutless as all frig but idle fine.
2011.5 6.7L HO 3500 4x4 ST Crew LB 3.73 SRW Rear 68RFE H&S MM w/ Custom Tuning, B&W+Companion
60 Gal RDS Tank/Tool PacBrake Bags
2012 Fuzion FZ305 35' Toy Hauler (no, the Ford does not pull this...)
ZOP is offline
post #11 of 12 (permalink) Old 09-10-2018, 04:24 PM Thread Starter
Okay I have a plug so I’ll throw that in and check the voltage on the harness, fuel filter just replaced it’s been running fine and on off for months. With a spike in idle around 2 300 rpm then back down to normal
6.7Prius is offline
post #12 of 12 (permalink) Old 07-01-2019, 11:59 PM
I have a similar problem:
The truck:
2012 Ram 2500
155K miles
Running RACE Me
EGR/DPF Delete
Glacier Diesel Big line kit
EDGE CTS Monitor
The problem
Cold Start, No smoke. No hard Start.
Rail Pressure (RP) runs steady 6 to 6.2K
When hot:
on Park RP is 4.8. 4.9K
on Drive, RP runs between 5.8 to 4.3K Yes a bit more thank 1k Fluctuation.
When fluctuation runs a bit fast thats when the DING comes on and P0191.
However, some times RP remains steady at around 5.3 to.5.7K
I've tried to see if the tank fuel level has something to with it, but it seems to do it at any level.
Have not felt power loss
So far I have replaced:
Fuel filter numerous times
Fuel rail and rail pressure sensor
and Fuel Control Actuator or MPROP
What I think I have left:
Fuel injectors
tank Fuel sending unit
Am I missing something? Any Ideas of what to do next?
506 MAE is offline
