Truck Running Hot - Dodge Cummins Diesel Forum
post #1 of 6 (permalink) Old 09-13-2017, 05:12 PM Thread Starter
Matt 007's Avatar
Truck Running Hot
I am not for sure if I have a blown head gasket or not, I am not seeing any bubbles in the overflow tank. The truck normally runs around 202 and now it seams to be running around 204-206 and when I pull a trailer is is climbing up to 216 at times and then running around 210. If I get off the throttle it will cool back down to 199 and then back up to 206. I has not been that hot outside so it shouldn't be running that hot. Any ideas on what it possible could be? Thanks for any help.
2012 2500 fully deleted. XRT Pro 5 inch flow pro TBE. H&S egr and cooler delete. Edge CT gauges. OD tune. Mirror lights to running/blinkers
1996 2500 Stock
Matt 007 is offline
post #2 of 6 (permalink) Old 09-13-2017, 05:26 PM
BigE_RAM's Avatar
Check if your rad is clean, had a buddy with the same problem and the rad was completely plugged with straw dust
2011 CCSB, White, 8" BDS LA Lift, Deleted, H&S Mini Maxx, S&B intake, 20x12 moto metal 962, 37x13.5 Toyo Open Country MT
BigE_RAM is offline
post #3 of 6 (permalink) Old 09-13-2017, 07:07 PM
the man in black's Avatar
That's not hot at all. Factory stat is 200f so they will cycle up around 205-210 then back down. Depending on the weight of the travel and speed your going they can get to 216 very easily.
Scooty Puff Sr - 2016 3500 CCLB
Truckasaurus - 2010 2500 CCSB -sold
the man in black is offline
post #4 of 6 (permalink) Old 09-13-2017, 10:23 PM
DDRamFan's Avatar
Also, the fan clutch does not fully engage to drive the fan at full speed till 217 degrees.
2012 Ram 2500 Laramie CCLB 6.7,4x4, Fully Deleted, BD Air Horn, EFI Live w/ Trans Tune, AFE DFS780 Lift Pump, Injen Evo CAI, Riding on 37x12.50 Ridge Grapplers on Black Rhino 20"Sierra's, Thuren 3" Coils, Rear Shackles, Fox 2.0 Reservoir Shocks, HC Control Arms, Track Bar, King Steering Stabilizer and Torsion Sway Bar. Steering Box Brace, SnugTop,Amsoil Bypass Filter & Oil, RetroShop FXR Projectors w/ HID's, Morimoto LED Fog's, Back Seat Fold Down Hack. Titan 60 Gal Mid-Ship Tank.
DDRamFan is offline
post #5 of 6 (permalink) Old 09-14-2017, 12:57 AM
BigE_RAM's Avatar
Hmm interesting, never seen it go that high but I'm also in Canada so it's always cold, even when it's hot lol
Sent from my LG-H812 using Tapatalk
BigE_RAM is offline
post #6 of 6 (permalink) Old 09-14-2017, 10:00 AM
pwrmvr's Avatar
On my 16 towing a grade will get to the 205-210 fairly easily and towing at elevation I can get the 215 and start to engage the fan on and off. Pretty normal I think. Once you hit 230 with the fan on and won't cool it down I would begin to think something is a miss
16 mega 4x4, revmax valve body, arp 625, hpp efi, 64/70 vgt
pwrmvr is offline
