68RFE slipping in 1st gear pulling a trailer - Dodge Cummins Diesel Forum
 2Likes
  • 1 Post By TransEngineer
  • 1 Post By paulb
post #1 of 7 (permalink) Old 09-11-2017, 12:44 PM Thread Starter
Motorboatin's Avatar
2012 3500 SRW 68RFE
From at take off from a dead stop, tow/haul mode engaged, pulling a 7K lb trailer. The transmission feels like it's slipping/shuddering in 1st gear only. Doesn't do it if I ease out of the stop. Doesn't do it when I jam on the throttle in any other gear, even going up a grade.
Is this normal? I took it to the dealer with the trailer and took a tech on a drive to show him what it was doing. Tech said it could be a clutch or something in the torque convertor, he also said it could be normal. They submitted a STAR case and we're waiting to hear back from the engineers. Anyone else experience anything like this?
Warranty expires this month and I'd like to get this addressed if it is a problem.
Thanks.
Motorboatin is offline
post #2 of 7 (permalink) Old 09-11-2017, 02:15 PM
cumminthanstrockin's Avatar
Is your RPMs surging? Do you have a code? What makes you think you're slipping?
Tow Rig: 2011 Ram 2500 Laramie MCSB - FloPro | Sinister | Draconian EFI | Thuren/Carli | Fuel Wheels | Toyo MT | RIGID INDUSTRIES
Daily Driver: 2016 Ram 1500 Laramie Longhorn Crew Cab w/ 5.7 Hemi & 8 Speed
cumminthanstrockin is offline
post #3 of 7 (permalink) Old 09-12-2017, 04:57 AM
TECH SPECIALIST
You're probably getting "launch shudder," which is not a transmission issue but rather caused by movement of the driveshaft center bearing. I presume you have a 2-piece driveshaft? If you mount a GoPro camera under the truck and video the center bearing, you can see what's going on.
Although some such shudder is apparently normal (unavoidable) with a center bearing, you can sometimes reduce the shudder by shimming the center bearing support, to slightly change the driveshaft angle at the center joint.
Motorboatin likes this.
TransEngineer is offline
The Following User Says Thank You to TransEngineer For This Useful Post:
Motorboatin (09-14-2017)
post #4 of 7 (permalink) Old 09-12-2017, 12:09 PM
paulb's Avatar
The torque converter doesn't lock in first gear, so it would not be the lockup clutch. Does it do it if you put it in manual low?
05 2500 4x4 BBI injectors, UDC Pro, Source Automotive Twins, F1 springs, F1 Cam, Crower Rods,Mitusa, PPE Dual Fueler, Ultimate Transmission, Opie shafts,Isspro gauges - 1015hp
14 2500 4x4 Laramie, Smarty Touch, UDC Pro tuning by me
paulb is offline
The Following User Says Thank You to paulb For This Useful Post:
post #5 of 7 (permalink) Old 09-13-2017, 11:41 AM Thread Starter
RPM is not surging, no codes, not sure if it's slipping, just feel a significant amount of shudder on take-off.
Thanks TransEngineer! I'll have to try the gopro then next time I hook up the trailer.
Do I shim the support to make the angle flatter? Any recommendations how I would go about it? Could the bearing be going bad?
I haven't tried. Thanks for the info, that was my main concern. It's for sure only happening in 1st gear.
Thanks for all the responses guys and sorry it took me a few days to get back, I just got a Aussie pup and she has been soaking up all of my free moments.
post #6 of 7 (permalink) Old 09-14-2017, 05:04 AM
TECH SPECIALIST
I'm not a driveline expert, but I believe that yes, you would add shims between the center bearing and the crossmember to move the bearing down slightly (reducing the driveline angle).
post #7 of 7 (permalink) Old 09-14-2017, 10:49 AM Thread Starter
Ok, as always thanks very much for the info.
2012 6.7 3500 LB SRW - Carli track bar & ball joints - HPP MM3/EGR Delete/DPF&CAT Delete (On order from RSD)
