New turbo, boost not detected code - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 09-09-2017, 03:43 PM Thread Starter
farmboy876's Avatar
I just replaced the turbo in my 2011 because the actuator quit working on the factory turbo. Today I was driving the truck and the turbo died out and almost sounded like a blow off valve. Few minutes later it cleared up and started running fine but it's throwing the boost pressure not detected code. Any ideas?
2011 Mega Laramie--Minimax--5" TBE--Deleted--BDS 8"--20X10 XD Strike's--37" Toyo Mt's
farmboy876 is offline
post #2 of 7 (permalink) Old 09-09-2017, 03:48 PM
N of 60's Avatar
There is no blow off valve or waste gate. Since it was just replaced, check all your charge air connections..
2011,4wd LB/CC 2500 H&S Mini MCC by Tomeygun, BD protect 68rfe VB seperator plate enhanced stall triple disk TC, Super B 64.5/80/.91 3rd gen mani & inline EB, Arp 425s, Fass Titanium 95. Spare Mini in my closet.High tech old school and finally lovin it.
N of 60 is offline
post #3 of 7 (permalink) Old 09-09-2017, 03:51 PM Thread Starter
farmboy876's Avatar
I was using the wastegate as a sound comparison I will re tighten everything
post #4 of 7 (permalink) Old 09-09-2017, 03:59 PM
N of 60's Avatar
Understood
So the only way to get that sound of a large air release may possibly be one of your CA Boots opening up.
Hope it's as simple as that for you.
N of 60 is offline
post #5 of 7 (permalink) Old 09-09-2017, 04:14 PM Thread Starter
farmboy876's Avatar
It just did it again and when the turbo return back to normal, I hear the turbo "seal up" almost the sound it makes when the exhaust brake turns off
post #6 of 7 (permalink) Old 09-09-2017, 07:21 PM
tob_e's Avatar
i had that sound occurred last week when i reverted my setup to stock. The boot closer to the turbo just slipped off. Like N60 said, tighten those boots clamps tight enough that you think you'll break the studs off or if you can see the lip of the boots lifting then its tight
07.5 6.7L 2500, Straight flange 2nd gen, ARP 625, Thuren/Carli goodies.
tob_e is offline
post #7 of 7 (permalink) Old 09-11-2017, 12:05 PM
Shiftin Fool
RobertP's Avatar
Another this to check with that code is the MAP sensor. I have been getting that code for months, over the weekend I pulled the MAP sensor and it was completely clogged with soot. I cleaned the sensor and have not had the code come back yet, also the exhaust brake is working perfectly every time now.
05,5500,g56,II silver 66 second gen style!!, SBC DD,custom pumps and Injectors from II, Hamilton Springs, Smarty! 702.92HP [email protected]! SOLD
2016 2500 Power Wagon 6.4 Hemi sold!
2010 2500 Mega Cab. Leveled on 35 Toyo RT's, 3:73 rear. Deleted,Flo Pro TBE, RPI intake, Anarchy EFI live, CTS2 monitor.
RobertP is offline
