Ticking noise underneath - Dodge Cummins Diesel Forum
 3Likes
  • 1 Post By 012cummins
  • 1 Post By OuchThatHurt
  • 1 Post By Lins
post #1 of 7 (permalink) Old 03-28-2017, 05:23 PM Thread Starter
I have a 2015 6.7 cummins 2500, barely pasted 25k mi, and I am having an annoying ticking noise coming from front underneath my truck been there for about 5k mi the sounds comes and goes and it's not consistent, I've taken it to the dealer 3 times already and every time I take it never makes the noise for them while they have it. I've looked it up on here some say thrust bearing broken, cp3 needs rephasing, or injector, but some how the dealer never comes the noise or hears it so says there's nothing they can do if they can hear or find it but when I leave and get home it's making the noise. ANY advice on what to do now????? Just don't want something to be wrong and I cause something bigger.
My truck makes the same noise as this one.
https://www.cumminsforum.com/forum/4t...1470954?page=1
Jaramos is offline
post #2 of 7 (permalink) Old 03-28-2017, 06:59 PM
I've have a come and go ticking noise too. Also took it to the dealer. They can't replicate it. Mine goes away when I unplug the EGR valve. Not sure if it's the EGR valve or not. Had that checked at the dealer too. They said it's fine. I've had the noise for a couple years. I've learned to live with it.
cwendel likes this.
2018 2500 CC LB 4x4 6.4 Hemi 4.10
B&W Patriot, Timbrens
2013 Fox Mountain 235RLS
012cummins is offline
post #3 of 7 (permalink) Old 03-29-2017, 03:30 PM
Location: Mag Hytec Deep Transmission and Rear Diff pan
Do you happen to be deleted by chance?
The_One is offline
The Following User Says Thank You to The_One For This Useful Post:
1baddrop (04-23-2017)
post #4 of 7 (permalink) Old 03-29-2017, 11:26 PM
67guzzler's Avatar
Depending on where it's coming from under the vehicle it could be the SCR system injecting DEF into the exhaust.
That makes a prominent ticking sound right below the drivers side door, slightly back.
-Guzzler
2017 2500 Crew 4x4 Laramie 6.4L HEMI 66RFE w/4.10
PRIOR: 1994, 1996, 2004, 2005.5, 2010 and 2013 2500's. ALL Cummins.
If someone is nice enough to post a truck-related pic,
I'm more than happy to click a "Like or Thanks."
67guzzler is offline
post #5 of 7 (permalink) Old 04-29-2017, 02:19 PM
OuchThatHurt's Avatar
Yuo, injecter in ur exhaust emissions BS
cwendel likes this.
OuchThatHurt is offline
post #6 of 7 (permalink) Old 04-03-2019, 08:19 AM
So, is the ticking noise right under the driver's side, a little back, that might be DEF related, an ok thing? Or does it need to be addressed. My 2018 never used to do it, but now at about 35k, it does it all the time.
Mlnaire0305 is offline
post #7 of 7 (permalink) Old 04-03-2019, 12:08 PM
Lins's Avatar
Crawl underneath and find where the DEF injector is. Is the ticking coming from there?
N of 60 likes this.
Lins is offline
