G56 Destruction whats next (pics inside) - Dodge Cummins Diesel Forum
post #1 of 19 (permalink) Old 02-16-2016, 07:08 PM Thread Starter
EJS0806's Avatar
Spinning pretty hard in 4th the other day and she caught some traction. Finally had some time to tear it apart today, this is the outcome
Whats my best option to hold the power im around. Stock nv5600 hold up with a nice clutch or should I be looking into a 48 swap? Looking for some other input maybe from people who have done them? Im tossing both ideas around currently.
12 2500 laramie 4X4 nv5600 S475 fleece coolant bypass 125 injectors steed speed manifold h11s Hamilton 110s 12mm stroker cp3 airdog150 w/sump Southbend 3250 grid heater delete/gdp intake turbo smart bov thuren/carli
EJS0806 is offline
post #2 of 19 (permalink) Old 02-16-2016, 07:32 PM
I have a diesel problem..
tdanielson95's Avatar
iTrader Score: 6 reviews
If you have the funds, do the re swap. If not 5600 SHOULD hold...
2013 GMC 2500 LML Duramax. ECSB. Anarchy EFI, 4"
2001 Dodge 2500 ECSB Sport, 24v, Nv5600, Valair DD, 62/68/14, 100hp injectors, Smarty MM3
2003 Jetta TDI, 5 speed swap, DLC1019 injectors, VNT17 Turbo, 3 Bar MAP, Malone stage 4 tune, Southbend SMF clutch, 3" TBE, EGR delete, 2" IC pipe, EGT and Boost gauges, OMI, VAG-COM.
Sold: (Cummins, of course) 12, 06, 03, 01, 01, 99, 97, 95, 94.
tdanielson95 is offline
post #3 of 19 (permalink) Old 02-16-2016, 08:10 PM Thread Starter
EJS0806's Avatar
it's easily double the money compared to the NV which is the only real set back. But another thing is I don't want to mess with it. Last thing I wanna do after working on cars all day is go home and work on my own crap!
EJS0806 is offline
The Following User Says Thank You to EJS0806 For This Useful Post:
TWR (02-23-2016)
post #4 of 19 (permalink) Old 02-16-2016, 08:26 PM
What do you do with the truck? Are you stayin at that power range?
post #5 of 19 (permalink) Old 02-16-2016, 08:42 PM Thread Starter
EJS0806's Avatar
Ocasional towing nothing crazy mostly daily driver/toy never track it but it sees a lot of abuse around town. Honestly somewhat suprized it lasted as long as it did. And power wise Yeah most likely maybe some bigger injectors and proper tuning eventually
EJS0806 is offline
post #6 of 19 (permalink) Old 02-19-2016, 10:01 PM
Nothing crazy like boiling the tires in 4th at boost with a modded hot rod Cummins with bro dozer tires and hooking up hard instantly.....lol. Can't understand why that pos just fell a part?....
Prolly just installed all those go fast parts last week and never even squealed the tires before this........
07 5.9 Mega, G56, SB Single disk Ceramic clutch, OE 1 piece Al driveshaft, 60hp Industrial injectors, Triple dog, Glacier 2mic filter, BD exhaust brake, ATI Super Damper, BD steering brace, Firestone bags, Big Wig swaybar, 4th Gen 20s and some home made Stableloads.
Grit dog is offline
The Following 2 Users Say Thank You to Grit dog For This Useful Post:
Mustang 03 (02-24-2016), Truno223 (02-23-2016)
post #7 of 19 (permalink) Old 02-19-2016, 10:09 PM
Were you running a torque shield on the tranny?
-1999 2500 white sport QCSB/NV4500/EMS free spins
-1997 2500 12v LWB 5spd, 1998.5 3500 P24V 5spd
-2016 MC Laramie G56 maximum steel/CTT/CTS2/SB3250/37s
nuljas23 is offline
post #8 of 19 (permalink) Old 02-21-2016, 03:18 PM
trenthawks's Avatar
I'd say go the Re route, unless your dead set on keeping it a hand shaker. The NV holds up good until your spinning and catch traction. I blew 3rd in a NV 4500 in my 98 3 times due to spinning 35's and high boost (never had a problem with any other gear) Nv5600's are pretty stout but new old stock parts are hard and expensive to find and New aftermarket parts aren't usually as strong as the original parts unless treated/cryo'd. The re route is gonna cost more in the beginning but it will be faster and if driven sensibly will probably be cheaper in the long run due to less broken parts if its built properly.
TPMS & tire size adjustment tool rental for 4th gens! PM ME! 2015 CCSB tradesman,Raceme ultra W/ custom tunes, 68rfe, thuren springs, fox 2.0s, Airlift bags, Rollin on 35's & 17's
trenthawks is offline
post #9 of 19 (permalink) Old 02-21-2016, 03:26 PM
There's quite a few guys making big power with a g56. A Valair ceramic triple disc and a torque shield should help keep it alive
nuljas23 is offline
post #10 of 19 (permalink) Old 02-21-2016, 03:41 PM
TECH SPECIALIST
I only see two gears failed. Can't you just replace those gears? Or are they "not sold separately"? Is the case cracked?
TransEngineer is offline
post #11 of 19 (permalink) Old 02-22-2016, 01:21 PM
I dont not believe the gears can just be replaced. I think the whole main shaft would need to be bought,
2013 CCLB 2500 4x4 Tradesmen: Leveled w/ HellBent Spacer and Bilstein shocks, Racline Assult's w/ST Maxx's, God Speed 62/67 VGT, EFI Live By HPP ..
2013_6.7 is offline
post #12 of 19 (permalink) Old 02-22-2016, 01:29 PM
TECH SPECIALIST
The Mopar parts catalog shows the gears on the input shaft and main shaft are all available individually (although it appears that the front gear on the input shaft is part of the shaft itself).
But you are correct regarding the countershaft; it is apparently only available as a complete kit, with the shaft and all four gears.
Maybe a junkyard trans would be the best bet.
