oil filter info - Page 3 - Dodge Cummins Diesel Forum
post #25 of 32 (permalink) Old 01-25-2016, 10:58 PM
DC305's Avatar
For my 2014 2500 I used Mopar Oil Filters and Fuel Filters from Amazon, even got the Shell T6 Full Syn from Amazon, all shipped for free and price of filters were def. cheaper than the dealer.
2014 SLT 2500.....all stock
DC305 is offline
post #26 of 32 (permalink) Old 01-26-2016, 08:08 AM Thread Starter
joembx's Avatar
Originally Posted by mikes3500 View Post
I did the differentials myself but I have since new taken it to the dealer for oil changes.
$73 and they wash and vaccume my truck. I changed it once myself and didn't even save $20,the mess,disposal of used oil. They use the factory filter which is a Baldwin filter and Rottella oil. Plus they look my truck over each time for potential issues, so far they found a bad rear main seal,covered under warranty,carrier bearing,both front u-joints all warranty
hey diesel freak,,,just for the heck of it I called dealer ( 23 miles ) they wanted 149.99 plus tax ) next dealer 78 miles,,,o well gave it a shot,,,thanks
joembx is offline
post #27 of 32 (permalink) Old 01-26-2016, 08:38 AM
Bighorn2500's Avatar
Originally Posted by Motorolanut View Post
If a person changes oil every 5000 to 6000 miles, those filters would be a waste of money. You would have to risk/run extended change intervals in order for those filters to be cost effective.
Being deleted and/or running 10,000-15,000 mile OCI is where this filter would benefit you, provided you also do oil analysis to ensure your TBN is good.
2012 Big Horn, Mopar tonneau cover, Synthetic oils, 3.73's
Bighorn2500 is offline
post #28 of 32 (permalink) Old 02-24-2016, 03:00 PM
boatcapt's Avatar
I have a new 2016. Would the LF16035 be sufficient for it and would it work on my 2007 5.9? I had been running the donaldson DBL-ELF 7349 on the 5.9. Thanks for the help.
boatcapt is offline
post #29 of 32 (permalink) Old 02-24-2016, 03:02 PM
yes it would work for both. however the Donaldson DBL-7349 is the better filter in both flow rating and micron rating.
04 QCLB. 48re, 4x4,08 mega g56, 4x4.
Killer223 is offline
post #30 of 32 (permalink) Old 02-24-2016, 03:23 PM
boatcapt's Avatar
Thank You, then I will continue with the Donaldson for both trucks.
2019 3500 Mega CTD
boatcapt is offline
post #31 of 32 (permalink) Old 02-24-2016, 08:39 PM
CTDST16's Avatar
Donaldson better micron rating at efficiency as well as better flow rating GPM
97 ECLB 4x4-#10 fuel plate, 5x12 SAC injectors, 47re to NV4500 convert, fleece coolant bypass, K27.
CTDST16 is offline
The Following User Says Thank You to CTDST16 For This Useful Post:
Pufferman (02-24-2016)
post #32 of 32 (permalink) Old 02-24-2016, 09:04 PM
Sledgehammer1's Avatar
It may not be any better than the others, but Im a firm believer in Rotella 15-w40. Have 2 fords with 43x,000 miles, one with 26x,000 miles, and a few machines over 6000 hours that have been run on Rotella 15-40 since day one and no oil related issues with any of them. I just feel like if it works, no need to change. My Ram will have 15-40 Rotella in it too.
Sledgehammer1 is offline
