injector change? - Dodge Cummins Diesel Forum
post #1 of 3 (permalink) Old 12-30-2015, 05:55 PM Thread Starter
injector change?
How often should I change my injectors/ injection pump? Cant find anything in the manual. I plan on doing a full delete of the DPF and EGR.Going with a raceme tuner. Do I need to upgrade my injectors also? thanks
soot1986 is offline
post #2 of 3 (permalink) Old 12-30-2015, 08:04 PM
World Champs!!!
MoparProud's Avatar
Every 5-10,000 miles is routine maintenance.......
Ok I couldn't say that with a straight face. You don't. Only if there is a problem or they wear out do you change. We're talking ideally well north of 100k miles.
'07 3500 SRW QC/LB-6.7 swap-EFILive-Goerend-WOP triple turbo-60% Exergy-Carli Backcountry
'03 2500 QC/LB. HO/NV-
-HE351v-Southbend-TNT/R
Originally Posted by Common View Post
Why would you buy a Hellcat for road trips?
Originally Posted by MorSmokPls View Post
Because you can
MoparProud is offline
The Following 3 Users Say Thank You to MoparProud For This Useful Post:
CTD&TDI (12-30-2015), shanerocks (12-30-2015), soot1986 (12-31-2015)
post #3 of 3 (permalink) Old 12-30-2015, 10:05 PM
CTD&TDI's Avatar
I just changed my first injector with 270k on it
2018 3500 CTD CC Laramie, 385/930, Aisin, 4x4, 3.42, STAYING STOCK
2014 3500 CTD CC Laramie, 385/850, Aisin, 4x4, 4.10, 85k Traded
2007 3500 C&C, 6.7 CTD, Aisin, 4.10, 4x4, Black, Reg cab, 270k, 7520 hours, TRADED
2004 3500, 5.9 CTD, 6 spd, 3.73, 4x2, Black, Quad cab, 305k, 8268 hours, DiPricol Optix FP, EGT, Boost, AFE Bladerunner IC, Cowl Hood, Airdog FP100, GDP Canister Delete
1995 3500, 5.9 CTD, 5 spd, 4x2, Black, Reg Cab, Laramie, 123k, 4" TBE from RSD, Isspro EV's 60 FP, 60 Boost, Pyro going in next...
CTD&TDI is offline
The Following User Says Thank You to CTD&TDI For This Useful Post:
