Game Time! Who can guess the leak! - Dodge Cummins Diesel Forum
post #1 of 11 (permalink) Old 12-29-2015, 06:58 AM Thread Starter
N1ckZ's Avatar
In the process of doing a erg delete found this mess coming out of a fitting? Truck only has 33k miles on it WTF!!!!!!
Can anyone help determine where it could be coming out of? Or if it's a common problem?I have problem with leaks, and cannot drive my truck knowing it's like that!
Thank you for any helpful input!
N1ckZ is offline
post #2 of 11 (permalink) Old 12-29-2015, 07:16 AM
Ratdog1's Avatar
A little bit more seepage than most , but i have 25% of what i see on yours ... i have 48k on mine . I sure your fine don't worry...
Would like to add possible build lube.....
2016 4x4 3500 Laramie CCLB LOST MY EXHAUST SO I HAVE AN 18 INCH RESONATOR AND EGRDELETE.. ALSO HAVE EFILIVE BY PPEI 3.42 rear ,68 trans TUNED BY PPEI
Ratdog1 is offline
post #3 of 11 (permalink) Old 12-29-2015, 08:02 AM
vb712's Avatar
Very common on these trucks. It's the gasket between the cylinder head and the rocker box. Mine seeps as well.
'12 Mineral Grey HO CCSB, Deleted. Studded. EFI Live by Anarchy 13 sec club 💨
vb712 is offline
post #4 of 11 (permalink) Old 12-29-2015, 08:14 AM Thread Starter
N1ckZ's Avatar
So you guys definitely think is between the head the the rocker box? Because if so I think I can live with that leaking haha
N1ckZ is offline
post #5 of 11 (permalink) Old 12-29-2015, 08:17 AM
Ratdog1's Avatar
Yes..........
Ratdog1 is offline
post #6 of 11 (permalink) Old 12-29-2015, 10:18 AM
Truno223's Avatar
Headstuds and while you're in there take a look and replace with a new gasket!
2014 2500 Mega Cummins G56, Southbend 3250 DD, tuning by HPP, ARP 425 studs, Amsoil bypass
Truno223 is offline
post #7 of 11 (permalink) Old 12-29-2015, 11:09 AM
Am I just missing something in the "new to me" 4th gen 6.7 cummins deal or why is this acceptable ? Especially under 50k miles. Is it the gasket quality itself or what allows oil to push through?
2006 5.9-Tuned by Darrel Waltrip
battlegraduate09 is offline
post #8 of 11 (permalink) Old 12-29-2015, 01:45 PM
evildiesel's Avatar
In my opinion this isn't acceptable either. If I saw that on mine I'd be ripping it off, cleaning surfaces and putting a new gasket in. I can't stand leaks
2006 Dodge Ram 2500 ST, RCLB, G56
AFE Intake - 4" Straight Flo-Pro Exhaust - EFILIVE - Southbend DD Clutch - CARLI - TGC 3.5" lift - 20x12 wheels - 35" AT2 Tires
evildiesel is offline
post #9 of 11 (permalink) Old 12-30-2015, 05:54 AM Thread Starter
N1ckZ's Avatar
If I decide to stud that's the only way that leak is getting fixed. [email protected] sucks!
N1ckZ is offline
post #10 of 11 (permalink) Old 12-30-2015, 07:37 AM
178k on my 6.7 and no seepage
'09 /QCSB /Laramie /6.7L/ 68RFE /4X4/GDP/Stainless S465/PTP Blankets/Fass Titanium 95/Isspro EV2x5/Thuren 3"/Bilstein 5100/DT Profab Radius Arms/Synergy Steering/Carli Ball Joints/20x12(-52)/Toyo M/T 37x13.50
cummins4vr is offline
post #11 of 11 (permalink) Old 12-30-2015, 12:32 PM
StealthDiesel's Avatar
If this minor issue is getting you stressed out, I hope you never have any real problems with your truck.
Remove the plastic cover, remove the top valve cover. Check to make sure all the rocker bolts are tight.
Clean the entire area. Re-inistall the valve cover and plastic cover.
Carry on...
2004.5 Dodge SB QC 2500 2wd Cummins 600/6spd manual/3.73 LSD
ATS 3K/5K Twin turbos. DDP 50HP tips, F1 valve springs, ARP headstuds.
SBC Dual disk 3250. Smarty. Glacier Diesel intake plate, air horn, fuel & filter system.
MBRP S.S. muffler. BD short shifter. Brakesmart tow controller.
BD exhaust brake. Pullrite 24k Superglide.
StealthDiesel is offline
The Following User Says Thank You to StealthDiesel For This Useful Post:
Rimcrew (12-30-2015)
