Dealer changed trans fluid. - Page 2 - Dodge Cummins Diesel Forum
post #13 of 23 (permalink) Old 12-24-2015, 01:11 AM Thread Starter
Yes on coded. Incorrect gear ratios for 5th and 6th. Also it went into limp mode, 1st and 4th gear only.
savant is offline
post #14 of 23 (permalink) Old 12-26-2015, 05:37 PM Thread Starter
A little update. Dealer is pulling the trans to dig into it. They said that the power flush might have pushed something into a valve or something. Can't remember all they said. But that 5th and 6th have been damaged and they are going to be replacing them and anything else they find under warranty.
savant is offline
post #15 of 23 (permalink) Old 12-26-2015, 06:33 PM
letsrun100's Avatar
So, I'm a little confused. You said they "changed the fluid" and you got a "complete trans service including filter change", but then the dealer said "the power flush might have pushed something into a valve or something". When you drop the pan, drain the fluid and replace the filters you don't usually do a flush too, do you?
2008 2500 SLT 6.7, 140,000 miles (YEA!!), EGR Delete, CCV Filter Bypass, Edge Evolution CTS
letsrun100 is offline
post #16 of 23 (permalink) Old 12-26-2015, 09:11 PM Thread Starter
They did a flush to get the fluid out of the torque converter and anywhere else that just dropping the pan won't get. I wanted all the fluid out since I towed and it got to warm for my liking.
savant is offline
post #17 of 23 (permalink) Old 12-27-2015, 02:19 PM
Pooter's Avatar
Did you tell the dealership that? They may be having you pay for some of this now knowing the trans got hot towing a load . It might not all be under warranty if you knew the trans got hot and kept going.
'12 Ram 2500 CC 6.7/Auto/4wd - AFE drop in, Raceme, EGR Delete, Flo Pro 4" TBE, 17x9 Addicts 285/75/17 Nitto HTs, Synergy Mini-packs, Bilstein 5100s, 5" Iboard Steps
Pooter is offline
post #18 of 23 (permalink) Old 12-28-2015, 02:35 AM
00' Quad Cab's Avatar
The exact reason I will never let anyone sell me a "flush". 2 trucks ,both flushed, lost trans within 500 miles of being done. I will never allow a flush on another vehicle I own.
Maybe I had poor luck but I will never chance it again.
Jason Hayes, Aberdeen WA
Old rig: 2000 QC LB 4x4
New to me :2011 CC LB 4x4
00' Quad Cab is offline
post #19 of 23 (permalink) Old 12-28-2015, 04:00 AM
tonyb337's Avatar
I have stated in a post several months ago, my dealer WILL NOT do a flush,,reason given to me, QUOTE " "there is a possibility that a small piece of trash may end up in valve body ".........my old dad used to say if you want it all out,,change your oil and filter again in a few days, it's much safer and still cheaper than a flush at the dealer. He refused to buy the flush equipment for his service station on the advise of a friend. This was 25+ years ago, I sure do miss working there in high school, ,brings back memories.
2012 3500 drw 4x4 Laramie HO 68rfe CTS for guages,Anarchy EFI with trans tune,with a knob, COMMUNIST emissions on strike, 4" Proflow,, homemade air filter bug guard,custom rock guard behind grill , ccv delete,B&W hide a ball,,150 k of towing and climbing : Please Remember to support those who have sacrificed:
tonyb337 is offline
The Following User Says Thank You to tonyb337 For This Useful Post:
camperman (12-28-2015)
post #20 of 23 (permalink) Old 12-28-2015, 04:39 AM
diverb's Avatar
I just changed my tranny fluid and both filters last month at 30,000 miles (I only use the truck for towing) just to be safe and I will likely change again around 50,000 or 60,000 and just keep changing fluid & filters rather than flush. Plus its something I can do myself
2017 - 2500 4X4 68RFE, 4" TBE, 190 thermostat, ARP 625 studs,EFI Live Tuned, Trans Tuned, S&B coldair, GDP Intake horn, EGR cooler delete, ATS tranny pan, Mag-Hytec diff covers, EDGE CTS2, FASS 95
diverb is offline
The Following 2 Users Say Thank You to diverb For This Useful Post:
KBoom (12-28-2015), vb712 (12-28-2015)
post #21 of 23 (permalink) Old 12-28-2015, 10:28 AM
Rendezvous's Avatar
Your dad is a 100% correct.
2013 4x4 CC/SB G56-EFI Tuned
2011 GT3 RS
Rendezvous is offline
post #22 of 23 (permalink) Old 12-29-2015, 11:03 PM Thread Starter
No of course not. It also didn't overheat just hotter than I like (220)
Just left the dealer. A spring clip on the front of what looked like the shaft broke off and one of the gears was completely burned. They took pics and sent it in to Chrysler to get it approved under warranty.
savant is offline
post #23 of 23 (permalink) Old 12-29-2015, 11:47 PM
Pooter's Avatar
Thumbs up
Good deal! Thats still not even too bad of a temp if it wasnt very long, but good thing theyre taking care of it!
Pooter is offline
