are all Dodge NV273 transfer cases the same? - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 12-22-2015, 09:59 PM Thread Starter
Found a case out of a 2012 5500. It is an NV273 with electric shift. same as mine. Will it fit in my 3500?
Seems like it should be a direct fit, but....just want to make sure.
2011 3500 4X4 Dually. Deleted with XRT pro.
rnoggle is offline
post #2 of 4 (permalink) Old 12-23-2015, 02:08 AM
lonestarwelder's Avatar
I think the only physical difference is between the manual and auto transmission models.
2015 3500 DRW Laramie CCLB 68RFE 4.10 4x4. CM SS flatbed. Cooper LT255/70R17 ST Maxx and 2" Stahl Steel spacers. Thuren 2.5Ē springs/shocks. Carli track bar Mag-Hytec rear cover with 75/110 Amsoil.
SOLD:2010 3500 DRW Big Horn CCLB Auto 4x4.
SOLD: 2005 3500 SRW SLT 4x4 G56
lonestarwelder is offline
post #3 of 4 (permalink) Old 12-23-2015, 03:13 AM Thread Starter
I was just reading that some of the cab and chassis models have a fixed rear output flange, where the 3500 has a slip yoke. I could probably tear it apart and change the main shaft to a slip yoke style, but then I'd be in for almost as much as a rebuilt TC.
rnoggle is offline
post #4 of 4 (permalink) Old 12-23-2015, 09:54 AM
Things with the same part number SHOULD be the same. However, external parts to fit/couple/connect it could be different. Such parts should not require major surgery to change. I suggest talking to your local recycling yard about the issue - also, have the seller, in writting, warrant suitability/fitment for your truck.
2015 RAM 3500 CC LB SRW, 4x4, Aisin, BigHorn, 8.4an, Husky-X, Duraflap, cabin air filter, LTX MS/2, Maxiscan MS310, Super Z cables, US Cargo 60K recovery strap. Also 1998.5 NV4500, RWD
nlol is offline
