Help!! Transmission jerks hard after transmission tuning - Dodge Cummins Diesel Forum
post #1 of 24 (permalink) Old 12-14-2015, 07:54 PM Thread Starter
Around one month ago, I got Anarchy CSP5 and Transmission tuning. After the tuning, if I accelerate a little bit, then let off the gas, the truck jerks. If I cruise to 60 mph, then cancel the cruise, the truck jerks even harder. Before the transmission tuning, it runs smoothly... Is it normal? Does anybody have the same problem? What's wrong with my transmission?
Btw, I'm a conservative driver, normally I use stock tuning, only use street tuning a few times...
Many thanks in advance~
Andcircle is offline
post #2 of 24 (permalink) Old 12-14-2015, 08:00 PM
the man in black's Avatar
You have to give the trans time to relearn after switching tunes. Drive easy for a while. Don't remember how long as I don't have that issue.
Scooty Puff Sr - 2016 3500 CCLB
Truckasaurus - 2010 2500 CCSB -sold
the man in black is online now
post #3 of 24 (permalink) Old 12-14-2015, 08:15 PM Thread Starter
Thanks for the help~
So you also had similar problems before the trans finished its relearn ?
post #4 of 24 (permalink) Old 12-14-2015, 08:54 PM
Hi, I takes approximately 100 up shifts and 100 down shifts to learn individual driving patterns
vprjack is offline
post #5 of 24 (permalink) Old 12-14-2015, 08:59 PM Thread Starter
It's already one month, but nothing improved...So I should change to manual mode?
post #6 of 24 (permalink) Old 12-14-2015, 08:59 PM
Nope my left foot learns very quick I have the G-56
post #7 of 24 (permalink) Old 12-14-2015, 09:01 PM
If you havent switched levels in a month you may want to talk to your tuner the trans should learn after a few days
post #8 of 24 (permalink) Old 12-14-2015, 09:08 PM Thread Starter
Yeah, I've contacted with Anarchy, waiting for feedback now. Just wanna see does anybody else have the similar problem, and learn from their experiences.
post #9 of 24 (permalink) Old 12-14-2015, 09:10 PM Thread Starter
I definitely should go with mt....even considering swap at to mt, but mine only got 29k, so maybe later...
post #10 of 24 (permalink) Old 12-15-2015, 06:21 AM
TECH SPECIALIST
Or just go back to the stock PCM programming. You said you were a conservative driver; you shouldn't really need a performance trans tune.
TransEngineer is offline
post #11 of 24 (permalink) Old 12-15-2015, 11:09 AM
TwinRams's Avatar
After the tuning, if I accelerate a little bit, then let off the gas, the truck jerks. ~
This^^^. Stop doing this. Probably not going to hurt the transmission, but it will probably shorten the life of your U-joints. When you are accelerating, your transmission is preparing a firm shift (increased line pressure I would assume) so as not to slip clutches. When you lay off the throttle just before it shifts, it just continues its firm shift, but without the torque being actually applied to it, it seems quite excessive. I think the stock tuning has some type of torque reduction just before the shift so smooth, soft shifts don't burn clutches. Your aftermarket tuning eliminates this pre-shift torque reduction, so firmer shifts are required to not smoke clutches.
Sorry for the butchered explanation. I'm paraphrasing things I've been explained and read from memory (and certainly getting some of it wrong).
2011 CC Laramie DRW 4x4 auto, deleted. EFI by Dave, 5" Flo-Pro, Edge CTS2, GDP Air Boss, 625s, Carli stuff, Synergy steering
2012 CC Limited DRW 4x4 auto, deleted. MM w/MCC by Dave, 5" Flo-Pro, leveled
TwinRams is offline
post #12 of 24 (permalink) Old 12-15-2015, 01:46 PM
What mode are you running on your CSP5? My truck is also Anarchy tuned with transmission tuning and haven't run into anything like what you're seeing. I have noticed the shift timing seems quicker and it holds the gear longer than the stock program. I'm running the tow program with the exhaust brake engaged and tow/haul on, not sure if that is a factor as well...
al_2012 is offline
The Following User Says Thank You to al_2012 For This Useful Post:
giantslefty11 (01-04-2016)
