Help!! Transmission jerks hard after transmission tuning - Page 2 - Dodge Cummins Diesel Forum
post #13 of 24 (permalink) Old 12-15-2015, 03:48 PM Thread Starter
Thanks so much. That's the answer I'm looking for. So my trans doesn't have problems, just the tuning makes it behave like this?
Andcircle is offline
post #14 of 24 (permalink) Old 12-15-2015, 03:50 PM Thread Starter
Stock, tow or street.... all have the same probleme....
post #15 of 24 (permalink) Old 12-15-2015, 03:58 PM
I had this problem with several tuners. It wasn't till recently i resolved mine with a different tuner.
2011 Ram 2500 Longhorn..... 3in Carli Coils, Thuren Track Bar, Carli Sway, 5160's and 35's, Carli 7100 Steering Stabilizer, Carli Skid Plate,Carli mini-packs,Carli Arms, ARP 425's, F&R Replacement Bumpers, WARN Powerplant HD, Missing emission parts......
vwp6269 is offline
post #16 of 24 (permalink) Old 12-15-2015, 04:04 PM Thread Starter
That is quite a lot of money 😂
post #17 of 24 (permalink) Old 12-15-2015, 04:06 PM
TwinRams's Avatar
The tuning combined with driving style. I can drive to avoid it 90% of the time, but occasionally it still happens for me. Seems like it's more likely for me at the 3-4 shift in city traffic (realize I'm speeding or the light isn't going to turn green after all and let off suddenly). It's not just you (have had this conversation with some of my friends too), and no it doesn't seem to be bothering my transmission much. 135,000 and going with trans tuning. Someone will probably chime in later and correct what I've gotten wrong.
2011 CC Laramie DRW 4x4 auto, deleted. EFI by Dave, 5" Flo-Pro, Edge CTS2, GDP Air Boss, 625s, Carli stuff, Synergy steering
2012 CC Limited DRW 4x4 auto, deleted. MM w/MCC by Dave, 5" Flo-Pro, leveled
TwinRams is offline
post #18 of 24 (permalink) Old 12-15-2015, 04:15 PM
MamthTORQ's Avatar
Are you driving in tow haul mode, if I am empty in tow haul my shifts can be rough/firm unless I am under WOT. otherwise they are just slightly more firm then stock. I drive in tow/haul pretty all the time. btw
2010 Longbed 4x4 68re 3.42s, B&W, light force 240s, Carli, Amsoil,FASS, he451 waiting for install,saving for a built 68 ANARCHY TUNED! and the 9500ix radar detector to use it
MamthTORQ is offline
post #19 of 24 (permalink) Old 12-15-2015, 04:54 PM
Cummins_1340R's Avatar
I have anarchy tunes and trans tuning it does have a little clunk when I let off the throttle and they said it's because it's under load same thing with letting off of cruise control I run with the street tune have 27,000 miles no problems yet you will have to keep us updated
Cummins_1340R is offline
post #20 of 24 (permalink) Old 12-16-2015, 12:56 AM Thread Starter
Yeah, I will try to do data log, and send it to Anarchy. Any feedback, I'll put it here~
Many thanks for your input~
post #21 of 24 (permalink) Old 12-18-2015, 01:12 AM
turbo246's Avatar
Did you have any luck ?
95 2500 cummins
12 3500 laramie
turbo246 is offline
post #22 of 24 (permalink) Old 12-18-2015, 09:56 PM
USARMY12V's Avatar
Most of these "shifting problems" we experience in 68RFE trucks are due to the design of the transmission itself to protect itself from otherwise detrimental operation. If you pay attention to the conditions surrounding the shifts you can 90% of the time avoid the transmission replicating it due to how quickly you let off the throttle or at what MPH you let off the throttle etc. Most of these complaints are not going to go away if you run a stock Dodge transmission regardless of whose tuning you use or what fluid/filters you use. It simply is what it is, many have these symptoms and drive thousands upon thousands of miles with no real trouble from it other than these grumblings.
98 QCLB 4x4 GT37, Contag!ous Diesel, DPC Converters. Team AirDog
2010 MCSB 68RFE w/Overdrive, XRT Pro, Draconian MCC. Sinister EGR/Cooler delete, Flo-Pro.
USARMY12V is offline
The Following User Says Thank You to USARMY12V For This Useful Post:
Andcircle (12-19-2015)
post #23 of 24 (permalink) Old 12-19-2015, 01:58 AM Thread Starter
Thanks man. Now I know I'm not the only one having these 'problems', feel more relaxed about it~
post #24 of 24 (permalink) Old 12-19-2015, 08:06 AM
Yeah for sure man if I have cruise set at 40 mph and tap the brake it's just a small clunk. Does it seem like yours does it more in a certain gear or mph ?
