Long starting. What's causing it? - Page 2 - Dodge Cummins Diesel Forum
post #13 of 18 (permalink) Old 12-05-2015, 11:48 AM Thread Starter
westTex6.7's Avatar
I will check it out!
2010 2500/4*4/AFE Stg2 intake/leveled/Fully deleted/ 4" diamond eye turbo back/ EFI live tune/trans tune
westTex6.7 is offline
post #14 of 18 (permalink) Old 12-05-2015, 09:05 PM
#40Fan's Avatar
Mine has done this to me as well. If I wait for the chimes to stop, it'll fire every time. If I try to crank early, it might or might not fire up.
2011 2500 CC ST G56 LB MM 5" Flo-Pro 463
#40Fan is offline
post #15 of 18 (permalink) Old 12-05-2015, 09:43 PM
USARMY12V's Avatar
Mine has done this ever since I got it. If you immediately turn it back off, it fires up instantly like everyone else states. My batteries went bad last winter so I replaced both of them, still did it after I got new batteries. I replace my fuel filters every 3-4000 miles just to be safe, always does it even after brand new filters. It'll go a couple thousand miles no issues then do it twice or three times in the same week then go a long time again without issue. Not sure why it does it...
98 QCLB 4x4 GT37, Contag!ous Diesel, DPC Converters. Team AirDog
2010 MCSB 68RFE w/Overdrive, XRT Pro, Draconian MCC. Sinister EGR/Cooler delete, Flo-Pro.
USARMY12V is offline
post #16 of 18 (permalink) Old 12-06-2015, 01:27 AM Thread Starter
westTex6.7's Avatar
Yea I wait for the chimes to go off and it usually doesn't do it.
Hoping maybe after my tear down and EFI live tune it won't do it any
more.
post #17 of 18 (permalink) Old 12-27-2015, 03:00 PM
Lots of filters (between fuel and oil on that schedule)! To the OP, this has happened twice in the last 20,000 miles for no rhyme or reason. Shut it off in panic and fires right up on the second attempt.
2010 CCLB Lamarie SRW | Greystone Pearl | Banks Automind Tuner - Banks Ram Air Intake - GDP MK2 Filter and Big Line Kit | Carli Suspension Front End Upgrade Kit - 3" Linears with Fox 2.0s | Snug Top
Hotshotdodge is offline
post #18 of 18 (permalink) Old 12-27-2015, 03:08 PM
firedude's Avatar
Same here. I think it is the tip start that is causing these issues.
2010 Inferno Red, Carli stuff, DT Profab, Method double's, 37" Toyo R/T's. H&S XRT with Draconian Diesel Tuning.
firedude is offline
