Aisin vs 68RFE - Page 4 - Dodge Cummins Diesel Forum
post #37 of 39 (permalink) Old 12-27-2015, 06:35 PM
svt98's Avatar
Originally Posted by rnoggle View Post
I have the 3.42 rear end with the 68RFE. I pull 10-14,000 lbs trailers every day, and sometimes as high as 16K. No problems or isues with the trans at all. oh, by the way, my transmission has 800,000 miles on it now and has never been out of the truck for anything. If you don't abuse it, beat on it, drag race it or get into pulling contests with it, the stock 68RFE will do everything you need it to.
Wow that's impressive you have any major problems with the motor yet ?
2015 Chevrolet Silverado 2500HD Duramax sold
2014 Ram 2500 68RFE, PPEI tuned, deleted
svt98 is offline
post #38 of 39 (permalink) Old 12-27-2015, 06:41 PM
CTD&TDI's Avatar
I believe he said in another thread he swapped motors at 600k-ish?
2018 3500 CTD CC Laramie, 385/930, Aisin, 4x4, 3.42, STAYING STOCK
2014 3500 CTD CC Laramie, 385/850, Aisin, 4x4, 4.10, 85k Traded
2007 3500 C&C, 6.7 CTD, Aisin, 4.10, 4x4, Black, Reg cab, 270k, 7520 hours, TRADED
2004 3500, 5.9 CTD, 6 spd, 3.73, 4x2, Black, Quad cab, 305k, 8268 hours, DiPricol Optix FP, EGT, Boost, AFE Bladerunner IC, Cowl Hood, Airdog FP100, GDP Canister Delete
1995 3500, 5.9 CTD, 5 spd, 4x2, Black, Reg Cab, Laramie, 123k, 4" TBE from RSD, Isspro EV's 60 FP, 60 Boost, Pyro going in next...
CTD&TDI is offline
post #39 of 39 (permalink) Old 01-03-2016, 04:48 AM
The 68 with 4:10 works very well. There is nothing this set up won't go over with relative ease. I always watch my egt's and trans temp when towing and drop a gear on hills keeps egt's down along with trans temps. I tow 15k with no problems
2010cclb3500,Austintan,68rfe,4:10,4x4,mm,sinister, ccv,dpf,cat, flow pro, stock muff back,69z28dz302,09HD,
Ultra classic,se103w/cams,
mikes3500 is offline
