2014 Ram Tapping - Dodge Cummins Diesel Forum
post #1 of 9 (permalink) Old 10-15-2014, 12:23 PM Thread Starter
NCCTD's Avatar
2014 Ram Tapping
Hey all. I have a '14 2500CTD with 5,600 miles on it. Just over hte last few days it has started to tap in the morning when cold. It is most noticable @ 1,200 rpm and the tapping is linear with the RPMs...which has be thinking valve, injector or exhaust leak (really not sure...just guessing). Frankly, I'm afraid to take it to the dealer...they don't seems to know much about the truck. It's not the standard diesel clatter. Its a new noise and it goes away after 5 minutes when warmed up. No power loss; just a tapping noise (I don't think its the DEF pump either). Any thoughts or experience with this? Thanks.
2014 Ram 2500 Laramie
NCCTD is offline
post #2 of 9 (permalink) Old 10-15-2014, 12:56 PM
JK2947's Avatar
Our 13 LL has around 8900 miles on and it I believe that it does the same thing. I Just ignore it, and yeah the dealer might be a far shot if you want them to fix it. When you put our truck in gear and mash the pedal, its like a manual with a clutch that's only grabbing like 10% so to say. And they told us "oh it just needs to warm up" And it does it even when its 100 degrees outside.
600+HP 1000+ft/lbs 04.5 SCLB. Sport, Laramie 6spd. Smarty S06, BD exhaust manifold, S&B Intake, Banks 3.5 manifold, Insight CTS, Magnaflow 5", SB DD clutch, ARP studs, AirDog 150, S366 My Truck - http://www.xtremediesel.com/Dodge59l...0045-2007.aspx
JK2947 is offline
post #3 of 9 (permalink) Old 10-15-2014, 01:26 PM Thread Starter
NCCTD's Avatar
I'll try to ignore. Just totally suck that at $50k+ some of us have to ignore things. Ugh
NCCTD is offline
post #4 of 9 (permalink) Old 10-15-2014, 01:42 PM
N of 60's Avatar
Cold timing rattle may be just what it is, which is normal. Especially if it goes away after it warms up. Mine became worse after having custom tuning.
2011,4wd LB/CC 2500 H&S Mini MCC by Tomeygun, BD protect 68rfe VB seperator plate enhanced stall triple disk TC, Super B 64.5/80/.91 3rd gen mani & inline EB, Arp 425s, Fass Titanium 95. Spare Mini in my closet.High tech old school and finally lovin it.
N of 60 is offline
post #5 of 9 (permalink) Old 10-15-2014, 01:59 PM Thread Starter
NCCTD's Avatar
Do you think cold timing rattle would get louder with the exhaust brake? Had it on the other day and the tapping got 10X worse...at least for the first few minutes.
NCCTD is offline
post #6 of 9 (permalink) Old 10-15-2014, 02:16 PM
N of 60's Avatar
I only really noticed timing rattle on low acceleration placing a load when it's cold, thats when I really pick up on it. Yes there is extra noise at idle but I think that's with any diesel when they're cold.
By putting on the exhaust brake at idle, that may cause you to hear more since it actually gets quieter at the arse end at normal idle and it's not drowning out the noise at the front end. Not at high idle.
Just my thoughts though.
Cheers
N of 60 is offline
post #7 of 9 (permalink) Old 10-16-2014, 12:17 AM
2014 2500 CTD 4x4 LARAMIE
tjsroka's Avatar
I now have a 2014 with no issues at 10,000 miles but my 06 had a tap that would go away when got warm !! Then it did it constantly ! It ended up being a bad injector ! It sounded identical to a valve tap! I would keep an eye out to see if u get a puff of smoke at start up or a slight vibration at idle! If so maybe an injector! But these motors do not like to b cold so I hope it's just a little cold diesel rattle and nothing major !! Good luck
tjsroka is offline
post #8 of 9 (permalink) Old 10-16-2014, 01:05 AM
BigCE's Avatar
The erg is open a lot more when the engine is cold and depending on the erg position the exhaust note or engine noise can change quite a bit. There is less erg being used once the engine warms up and the noise goes away.
This would be my guess anyway. You could try unplugging the erg and plugging it back in to see if you can here the noise come and go.
2010 2500 Mega Cab Laramie Sold
2015 Jetta TDI...Yep
BigCE is offline
post #9 of 9 (permalink) Old 10-16-2014, 01:25 AM Thread Starter
NCCTD's Avatar
Thanks all. Appreciate the input. I'll keep an eye on it.
NCCTD is offline
