upgraded VGT turbo? - Page 2 - Dodge Cummins Diesel Forum
post #13 of 16 (permalink) Old 10-13-2014, 08:29 AM
cattech15's Avatar
I sold mine and went with a second gen swap. for the money you will be spending on just a turbo you can second gen swap and put an inline exhaust brake
2012 RCLB SLT G56 S472 II 180 Nozzles SBC Triple Disc 700HP-SOLD
2015 CCSB Big Horn 68rfe EFI Live by HPP-WRECKED
2017 CCSB Laramie G56 Bright Silver w/ Black Sport Package-CURRENT
cattech15 is offline
post #14 of 16 (permalink) Old 10-13-2014, 09:22 AM
RyeThomas's Avatar
iTrader Score: 6 reviews
I agree 100% unless you live in a state with visual inspections. That's where the Fleece shines, and is really when they are worth it. That or if you purchase a compound turbo kit that runs off a stocker and you want some more, and don't want to change your entire set up or mess with the piping.
2013 Crew 3500 Dually 4x4 68RE , vinyl seats, rubber floors, no bells no whistles.
2012 Crew 4x Auto CTD
06 MEGA TRE Trans, E.D. 63/68, EFI by Les @ SBT, Motorsport Diesel Pump
06 750hp Built By TRE Diesel SOLD
Former United States Marine . Good luck and God speed to all our troops!
Current Professional Firefighter
RyeThomas is offline
post #15 of 16 (permalink) Old 10-14-2014, 02:18 PM
Rougen123's Avatar
Can this fleece be swapped as simply as y'all are making it sound? Would your truck require any tuning to run the different set up?
2012 2500 SLT CCSB 4x4, Carli Fox 2.0 Commuter Suspension Package, 20" Stock Laramie wheels, LT295 Firestone Transforce, TT1 Tuner W/ OD unlock, Flow pro 4", Sinister EGR del, 3.42's
Rougen123 is offline
post #16 of 16 (permalink) Old 10-15-2014, 03:03 PM Thread Starter
Salt And Vinegar's Avatar
I've also been eye-balling the BD super-B special. It comes with the turbo, manifold and inline brake. My question does this break spice into the existing EB switch or is this a separate plunger style valve? I have a G-56 so if thats the case I'd most likely mount an inline on the stick.
The swap is as simple as removing your stock turbo and replacing it with the Cheetah. Keep in mind they are both essentially HE351VE's. Yes its ideal that you tune your truck for optimal results.
I'm already running custom tunes so its not that hard for the builder to pull up my file and do some tweaking for the Cheetah.
Cummins G-56 BDS/H&S/Fox/Fuel/Toyo/ARP/DynaTrac/Flo~Pro/SouthBend/AAM/S&B/RamTuff/aFe/Sinister/ArmaGuard Coatings/Hurst/ISS-Pro/Anarchy/Rigid/Truxedo Duramax LLY Toyo/Sinister/EFI-LIVE/CCS/Rancho/S&B/Fuel/custom paint/ArmaGuard Coatings
Salt And Vinegar is offline
