Clutch (can someone direct me) - Page 2 - Dodge Cummins Diesel Forum
post #13 of 15 (permalink) Old 10-11-2014, 12:15 PM Thread Starter
Being pushed by several to try a valair clutch because of noises and ease of use... I'm wondering how the noise and ease of use is different when the design is the same...
Kurt14 is offline
post #14 of 15 (permalink) Old 10-11-2014, 10:18 PM
dd9
I had a ton of trouble just trying to get my transmission separated from the motor because it's hitting the floor of the cab. Is there something I can do to help with the claerance?
2011 crew cab 4x4 DRW g56. Stock
dd9 is offline
post #15 of 15 (permalink) Old 10-11-2014, 11:53 PM
RWH
RWH's Avatar
To answer your question, take a strap and cinch it across each frame rail so that the strap is tight across the bottom of the forward part of the engine's oil pan(See picture below ) . this will prevent the engine from tilting forward and stop your lighter transmission from being shoved into the floorboard. To the OP, Ive got a Southbend and love it. The noise isnt bad if you drive it correctly.
2012 SLT Bighorn CCSB 4x4/G56/SBDD3250/Silver Bullet 64/BD Exh Brake/MAG-HYTEC/ARP Studs/2"Leveled/Onboard Air/Bilstein 5100's/XD Misfits/Toyo A/T II's/Hornblaster Shocker!
Active Duty Navy Senior Chief
RWH is offline
The Following User Says Thank You to RWH For This Useful Post:
dd9 (10-12-2014)
