Service air filter - Dodge Cummins Diesel Forum
post #1 of 7 (permalink) Old 08-05-2014, 11:19 PM Thread Starter
Service air filter
I have a 2011 that has smarty jr. and a cat/dpf delete pipe.. The truck has 50k on it and I have changed the filter 4 times and it doesn't really make a difference for long, Lately the service comes on every 10 min. Is there a problem or do I need a after mkt. filter ? .. Thanks
zrt1000 is offline
post #2 of 7 (permalink) Old 08-05-2014, 11:25 PM
how do you make one of these trying to make one but cant figure out this web site
joshua gaylor is offline
post #3 of 7 (permalink) Old 08-05-2014, 11:50 PM
Cummins Freak
SRich12's Avatar
You probably have a dirty or bad maf sensor in your intake!!! Do you drive in real dusty conditions? you should not have to be changing that often!!! Did you remove the baffle from your intake. I'm pretty sure you can clean the sensors with non chlorinated brake cleaner?
2018 Ram 2500 4X4 SLT Bighorn White 4.10 Gears/Carli Level/295 Toyo AT2's /Full Console swap w shifter /Projector Headlights with HID's-LED Highs/ B&W Turnover Ball----
2017 Dodge Ram 2500 4X4 Laramie , 35" Toyo AT's / Center Console Shifter Mod. SOLD---- 2012 Ram 2500 4X4 Crew-Silver- 4:10's / Carli 3" Coils w/35" Toyo AT2's / Ranch Hand Bumper / Center Console Swap w shifter SOLD!!!
SRich12 is online now
post #4 of 7 (permalink) Old 08-06-2014, 05:23 PM
Ragin-Cajun's Avatar
Check that maf sensor. Mine came on one time after changing out my cai. Never again after that.
2017 Big Horn CC 4x4
Ragin-Cajun is offline
post #5 of 7 (permalink) Old 08-08-2014, 10:29 AM Thread Starter
Thanks.. I will give it a try
zrt1000 is offline
post #6 of 7 (permalink) Old 08-15-2014, 04:26 PM Thread Starter
Which sensor is it.. I see a few .. Thanks
zrt1000 is offline
post #7 of 7 (permalink) Old 08-15-2014, 08:14 PM
Vatalaro's Avatar
The drivers side, on the back side of intake horn, it has one torques screw holding it in. Don't break it, you have to twist it around to get it out, clean with non chlorinated brake clean, or carb clean or maf cleaner, use tooth brush to scrub the goop, let it dry then your good to go.
2011 2500 SLT CCSB,68RFE,3.42's,White,SRW,Edge CTS2 w/pyro,EFI by HPP,4" FloPro,250Kmi
Vatalaro is offline
