V2.1 vs v2.0 CTT Tuning - Dodge Cummins Diesel Forum
post #1 of 13 (permalink) Old 01-24-2020, 10:06 AM Thread Starter
miami ram salt life's Avatar
Has anyone gone from V2.1 to V2.0? I am thinking about switching to unlock shifts to avoid putting extra strain on the 68rfe.
2014 Cummins 4x4 Black Appearance / AFE dry filter intake / 22" light bar / LED lights all around / Thuren Leveling kit with track bar & fox shocks all around / Mishimoto Coolant Hoses / AMP Steps / 22x10 American Force on 35's
miami ram salt life is offline
post #2 of 13 (permalink) Old 01-24-2020, 04:14 PM
A.carlisle16's Avatar
I am wondering the same thing. I am running the 2.1b its good and all, but some days it seems like i get a shudder when trying to get into it a bit. I did send ctt a message today and they said to either use the 1.6.9.1, 1.6.9 or 2.0. I am gonna try the 2.0 and see how that goes.
A.carlisle16 is online now
post #3 of 13 (permalink) Old 01-24-2020, 05:45 PM
RamHunter18's Avatar
Ask them for one of the latest tunes. They are unlocked
18 Ram 2500 Big Horn 68rfe, CPS tune w/ aftermarket trans tune, Revmax vb, thuren springs w/ fox 2.0
RamHunter18 is offline
post #4 of 13 (permalink) Old 01-24-2020, 05:46 PM
Update on the 2.0. I just did my 30 mile transmission relearn and it shifts alot like factory. Only thing I really noticed is it holds the upper gears a bit longer than factory.
post #5 of 13 (permalink) Old 01-24-2020, 06:09 PM
Are you running unlocked tunes? I was running the 3.2a beta, but I did not like the engine tuning. I felt like I had no power at all and the turbo didnt seem to spool very much. Plus it smoked alot more than any other tune I have used.
post #6 of 13 (permalink) Old 01-24-2020, 06:29 PM
I haven't run 2.0 but I can tell you that I much prefer the unlocked shifts. I haven't liked a single 3.x tune and I've tried a bunch. My favorite tune so far is a 1.71 tune that I got Jonathan to revise with unlocked shifts. Probably similar to the 1.6.9 tunes.
The 1.71 tune holds gears longer than the 2.1 tunes I've tried and doesn't short shift. I found the tow haul mode is better and a lot smoother on 1.71. 2.1 would always lock the TCC in 3rd and shift to 4th kind of abruptly. 1.71 will lock in 3rd under light throttle and heavy throttle, but at 35% to 40% throttle it will keep it unlocked, shift to 4th and lock in 4th a little bit into the gear. Ot makes it seamless.
Keep us updated on the 2.0 if you don't mind.
'14 3500 SLT CCLB SRW 68RFE 3.42
Aaron37 is offline
post #7 of 13 (permalink) Old 01-25-2020, 08:16 AM
I definitely will. The only thing I dont like, and the 2.1 tunes did this as well is when I put my truck into drive it feels like it is slamming into drive. Doesn't do it into reverse or neutral.
post #8 of 13 (permalink) Old 01-25-2020, 09:52 AM
Walker111's Avatar
How can you tell its a locked shift or not? Flare? TC slip?
16 CTD 2500 Bright White Crew Cab
Walker111 is online now
post #9 of 13 (permalink) Old 01-25-2020, 10:13 AM
I'm running 3.5 it is 4th gear lock up with unlocked shifts, power is great and I have no smoke. The 3.3 is also go but I dont like the harsh 3rd gear lock up personally.
post #10 of 13 (permalink) Old 01-25-2020, 10:16 AM
It depends on who wrote the tune, some flare, but you can watch your tc in your gauges depending on what tuner you have, raceme, mm3 or ezlynk all show your tc mode
post #11 of 13 (permalink) Old 01-25-2020, 10:22 AM
Walker111's Avatar
So you look for the slip in the TC? What should you be looking for? 100 slip, 5-600 slip? Or -5 - 5 slip?
I don't know much about auto transmissions, TIA.
post #12 of 13 (permalink) Old 01-25-2020, 11:45 AM
If it stays around 0 when shifting then its locked, if your seeing 500 or so then it's unlocking.
