Modify/delete exhaust on 2018 3500?? - Dodge Cummins Diesel Forum
 2Likes
post #1 of 18 (permalink) Old 05-15-2019, 01:17 PM Thread Starter
Does anyone have any info on how-to remove stock exhaust-DPF,Cat,DEF,Muffler--on a 2018 6.7??
I did it and put a 5 inch "open pipe" style on mine with an Edge Juice tuner and I couldn't get the codes to clear- a dozen or so -all exhaust service-dealer-service required type appeared on the dash. Apparently, the factory computer is much more sophisticated on the 2018 compared to 2007 when I did this same thing and just cleared the resulting codes with an H and S tuner. Any help, or tech data would be appreciated
Thank you
CurtM
curtminnard is offline
post #2 of 18 (permalink) Old 05-15-2019, 01:19 PM
Not with the edge.
you can still do it but you have to have a tuner (and programmer) that will make it happen.
2004 3500 with a NV5600
2016 2500 mega cab. Stock for now.
2004 VW Jetta TDI
1tonson is offline
post #3 of 18 (permalink) Old 05-15-2019, 04:16 PM
Get with PPEI they can help.
I personally have the ez lynk from PPEI and I love it so far.
Had a small issue but ppei fixed it quickly.
Sent from my SM-N960U using Tapatalk
Cajuncowboy654 is offline
post #4 of 18 (permalink) Old 05-15-2019, 04:29 PM
Im interested i this aswell, keep us updated
05.5 5.9L QCLB 4X4; G56, Valair clutch, CRAZY LARRY, Pusher, Aero 4040XL, No Cat, Cool Tube, Donaldson ELF7349 oil, Baldwin PF7977, Donaldson P551313 2nd fuel filter head,1 piece drive shaft #52123162AC, Nitto Dura Grapplers, Firestone Ride-Rite airbags, 3.73Gears
usmc5593 is offline
post #5 of 18 (permalink) Old 05-15-2019, 08:03 PM Thread Starter
Thanks Cowboy
PPEI worked on your.....? which year Cummins??? I'm told Dodge enhanced their ECU tremendously starting in 2018, apparently up to the 2017 there are several companies that make a setup that enables 1 to run open pipes,,,,so.
post #6 of 18 (permalink) Old 05-15-2019, 09:08 PM
3brorce's Avatar
iTrader Score: 8 reviews
Who told you to go with an Edge tuner? Not enough initial research was done or you were told incorrectly majorly.
3brorce is offline
post #7 of 18 (permalink) Old 05-15-2019, 10:05 PM Thread Starter
yes, I didn't do enough research initially. Thank you for pointing that out. helpful information.
post #8 of 18 (permalink) Old 05-16-2019, 09:19 AM
3brorce's Avatar
Oh you are very welcome. Must have money to burn. Edge hasnt had a capable tuner in probably 10 years..
gsbrockman and Lins like this.
3brorce is offline
post #9 of 18 (permalink) Old 05-16-2019, 02:09 PM
Spazoid's Avatar
I don’t remember the exact year but I believe it’s 13+ need an unlock cable or specific software to unlock the ecm so it can be tuned. I went with mm3 from double r diesel before they went to not selling to the general public.
Project:1998 Toyota Tacoma 4bt Cummins crawler
Sold: 2005 QCLB 2500 SRW full billet auto ~500hp
Current: 2018 cclb 3500 laramie g56 stock for now
Spazoid is offline
post #10 of 18 (permalink) Old 05-16-2019, 04:06 PM
3brorce's Avatar
13+ no longer need an unlock cable with EFILive.
3brorce is offline
post #11 of 18 (permalink) Old 05-16-2019, 05:11 PM Thread Starter
cool
Thanks
post #12 of 18 (permalink) Old 05-17-2019, 02:28 PM
Thanks Cowboy
Sorry I have an 18 3500.
Yes some changes to system from 17-18. That was my issue.
With the old tunes the heat seats and wheel wouldn't work. PPEI sent me an updated tune for the 18 models and it's been working like normal.
Also seeing better fuel mileage on the dash, haven't ran a full tank to test hand calculated yet. Been having a heavy foot so wouldn't be the best calculation of my normal driving style
Similar Threads
New 2018 Dodge 3500 My Old Dodge 2013+ General Discussion 47 08-03-2018 11:15 AM
2018 Ram 3500 Torque with 68RFE Transmission??? bowler1 2013+ General Discussion 120 07-08-2018 02:47 PM
New 2018 3500 Exhaust question themagicone 4th Gen Performance Parts Discussion 5 06-08-2018 07:16 AM
89 cummins 47rh swap, compound turbo, water-meth injection, bigger injectors, etc bmashattack 89-93 Powertrain 7 04-18-2018 01:04 PM
97 Dodge 3500 4 in exhaust question jimmarla General Diesel Discussion 3 01-12-2012 12:09 PM
