Vgt actuator calibration help - Dodge Cummins Diesel Forum
 12Likes
post #1 of 39 (permalink) Old 08-29-2017, 04:00 PM Thread Starter
pwrmvr's Avatar
I just re installed my modified vgt back on the truck and the veins are moving up and down searching. Apparently it needs to be recalibrated which I was told it did not. Anyway I am looking for a little advice from someone who has done this. I saw this can be done with a snap on scanner. I am wondering if the actuator has to be removed from the truck or can it just be left on. Any advice is much appreciated
16 mega 4x4, revmax valve body, arp 625, hpp efi, 64/70 vgt
pwrmvr is offline
post #2 of 39 (permalink) Old 08-29-2017, 10:25 PM
08 Cummins
KhakiCummins's Avatar
The actuator must be removed from the turbo but not completely from the truck since you're need to communicate with it through the OBD2 port. You're not really calibrating the actuator itself, you calibrating the actuator to the turbo vane position.
pwrmvr likes this.
Duane
2008 Ram 3500 QuadCab
KhakiCummins is offline
post #3 of 39 (permalink) Old 08-29-2017, 10:28 PM
me78569's Avatar
yep, set the actuator arm to middle position, bolt it to the turbo, Pass command
lo_byte, hi_byte, 0x02, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF
It will cycle from full closed to full open and "calibrate" those positions.
this can be done via a good scan tool like the snap on or with an arduino and a canbus shield and some code I posted awhile back
pwrmvr likes this.
2018 3500 CCLB G56
me78569 is offline
post #4 of 39 (permalink) Old 08-29-2017, 10:39 PM Thread Starter
pwrmvr's Avatar
Found a local shop here with a snap on scan tool. Going to give it a go tomorrow
pwrmvr is offline
post #5 of 39 (permalink) Old 08-29-2017, 10:46 PM
On call 24/7
98whitelightnin's Avatar
iTrader Score: 16 reviews
This isn't necessary. Let me dig up my previous post and link it
1998 12v, 4x4, Club Cab, Carli, Thuren, BlueTop, Core 4x4, BD Diesel, PDD 5x.012, South Bend
2012 Laramie Longhorn, EFI by Ryan, Carli, Thuren
1995 Dually, Weston's 5x.016, 4k GSK, 5" FloPro, 255/85r16 Toyo M/T, Goerend, ARP, 60# Springs, BW 62/65/14, BW 75/96/1.10, Isspro, Fass 125, BDP Sump, 7mm DV's, 751 HP 1883 FP Torque on NOS
1998 P-Pumped 24v, 4x4, NV4500 swap
98whitelightnin is online now
post #6 of 39 (permalink) Old 08-29-2017, 11:26 PM
me78569's Avatar
This article covers the process of making your own Turbo calibrate tool for less than $75. If the actuator comes off the turbo you really should calibrate it.
https://mopar1973man.com/cummins/art...ntroller-r531/
Truno223 and steinbrenner like this.
2018 3500 CCLB G56
me78569 is offline
The Following User Says Thank You to me78569 For This Useful Post:
steinbrenner (08-29-2017)
post #7 of 39 (permalink) Old 08-29-2017, 11:43 PM
On call 24/7
I can't find the pics and cannot get them to load. Leave the ignition off and pull the actuator without unplugging it. Set the gear almost all the way to the back but line up the hole in the gear with the indentation in the actuator. Done! Put it back on and your good to go. I have done two like this without fancy tools and no problems .
post #8 of 39 (permalink) Old 08-29-2017, 11:49 PM
me78569's Avatar
Given the Design of the actuator you cannot reliably calibrate the turbo by hand.
it's so stupid cheap to build a calibration tool, why not.
Here is the document you are referring to, I think
2018 3500 CCLB G56
me78569 is offline
post #9 of 39 (permalink) Old 09-14-2017, 03:44 PM
I tried the method described in post #18 of this thread last night on my 08. It worked perfectly. I would add one step though. I would perform the procedure once and mark on the gear with chalk or something then perform the procedure again making sure the gear stops in the same location just to make 100% sure you get the right spot.
https://www.cumminsforum.com/forum/07...bration-2.html
sanielsen28 is offline
The Following User Says Thank You to sanielsen28 For This Useful Post:
StealthDiesel (09-14-2017)
post #10 of 39 (permalink) Old 09-14-2017, 06:25 PM
tob_e's Avatar
Does your code works with HE300VG?
07.5 6.7L 2500, Straight flange 2nd gen, ARP 625, Thuren/Carli goodies.
tob_e is offline
post #11 of 39 (permalink) Old 09-24-2017, 11:38 PM
07Mega59's Avatar
Same question here. If my programmer/scanner can do custom CAN commands, can I possibly just enter the "lo_byte, hi_byte, 0x02, 0xFF, 0xFF, 0xFF, 0xFF, 0xFF" commands?
2014 Mega Cab Laramie EZ Lynk with custom emissions present tuning - Thuren Track bar
Past: 2013 Ecoboost F150 FX4, 2007 Mega Cab Laramie 5.9 Cummins and too many others to list...just ask my wife
07Mega59 is offline
post #12 of 39 (permalink) Old 09-24-2017, 11:41 PM
me78569's Avatar
Here is an article I created to help you guys out with tubro calibration
If you can send can commands then send that command to ID 0x0CFFC600
2018 3500 CCLB G56
me78569 is offline
07Mega59 (09-25-2017)
