Column shifter to center consol shifter conversion - Dodge Cummins Diesel Forum
4th Gen Non-Powertrain Discussion of Accessories, Interior, everything not power related...NO ADVERTISING
 43Likes
post #1 of 466 (permalink) Old 04-10-2012, 12:55 AM Thread Starter
cuda7man1's Avatar
Hi, everybody!! I have a video of the center console shifter mod. This is a better one than the first one I did (at post #13)
bootsy1968 and Cat can do like this.
cuda7man1 is offline
The Following 13 Users Say Thank You to cuda7man1 For This Useful Post:
6.7L RCLB (10-14-2012), 63boxtop (11-17-2012), adama (11-14-2013), c-bolt (09-05-2016), Dano123 (04-10-2012), dmack6.7 (04-10-2012), FROG (04-10-2012), Jeffs64 (11-05-2014), jetfuel394 (04-10-2012), picdodge (04-10-2012), Sabre6 (06-13-2013), slick nick (08-07-2014), Zayne3500 (01-04-2013)
post #2 of 466 (permalink) Old 04-10-2012, 07:51 PM
jetfuel394's Avatar
sooo here is the pics and the write up. first the pics of the parts.
insalled pics on the truck,cable routing, trans connection.
part#S
1GE44XDVAB column cover (grey)
68024883AC shifter jumper wire
52855896AA shifter
52109706AC lever manuel control
52104371AG bracket,shift cable
52855956AG gearshiftcontrol cable
remove the cupholder liners and tray liners
remove 2 screws in forward tray
remove 4 screws in the compartment.
remove the chrome bezel
remove the larger bezel
remove the compartment
remove the sterring column cover, 3 torx screws in the bottom.
remove the cover top first, then the bottom.
remove the lower console trim piece by the drivers foot.
remove the cover with your obd connector,below the steering column
disconnect the cable from the shift handle, and unbolt the bracket from the steering column.
go under the truck and disconnect the cable from the shift end at the trans.
unbolt the bracket from the trans that holds the cable.
pull the cable thru the firewall and remove.
to remove the column shift handle you need to take out the bolt completely and pull the handle toward the pass side. it is a little tight.
you will need 3 1/2x2" bolts to mount the new shifter.
i used the body style clips that slide onto the console w/1/4/20x1 3/4 for this.
drop the shifter into the hole, route the new cable into the console and attach the ball end to the shifter. then mount the cable into the holder at the end of the shifter assy.
locate the two wires 1 at the column that is black,1 to its left that is white. unplug these and connect them to you new jumper wire.
route the wire into the console and attach it to the shifter.
bolt down the console
route the new cable thru the firewall to the trans
go back under the truck and connect the new cable mount bracket to the trans where the old one was.
connect the cable to the ball end on the new shift lever and attach it to the trans.
there is also a light on the drivers side of the shifter,about center top,it has no connection to the harness so you will need to splice it into your dash lights. the red is + black = i just used the 12vpower outlet so they come on with the key. you can decide where to tap it.this light is for the P R N D illumination.
check for operation and toggle function,
assemble the parts and you are done.
hope this all makes sense,and helps someone.
04.5 2500 Q/C l/b.not so stock
2011.5 2500 c/c l/b.laramie. smary,s&b cold air kit,center console shifter,custom painted headlights,tree hugger crap gone,some other stuff
jetfuel394 is offline
The Following 31 Users Say Thank You to jetfuel394 For This Useful Post:
4gtwrk (03-01-2013), 6.7L RCLB (10-14-2012), arcticzale (04-12-2016), B-MAN (09-19-2012), Bigpuddie (08-02-2012), blaketx (09-12-2012), cpobst (04-10-2012), cuda7man1 (04-10-2012), Dano123 (04-13-2012), Dieselover (03-04-2014), dmack6.7 (04-10-2012), enforcer17 (08-02-2012), expatracer (01-30-2013), gprguy (04-10-2012), greylynn (11-24-2013), Hemisphere2 (04-10-2012), jakebrake 60 (08-08-2013), Jeffs64 (11-05-2014), ksnell (04-10-2012), Loki223 (08-22-2016), Luvnacummins (04-21-2012), makgybare (01-29-2014), n2jmh (09-12-2012), Perogy (05-11-2013), ridofpwrstroke (05-14-2013), Soddy (04-10-2012), SRich12 (04-12-2012), Twistedcummins (05-08-2012), UNDER-PRESSURE (04-11-2012), wayned87 (03-24-2015), Zayne3500 (01-04-2013)
post #3 of 466 (permalink) Old 04-10-2012, 08:11 PM
jetfuel394's Avatar
te end product:
The Following 14 Users Say Thank You to jetfuel394 For This Useful Post:
6.7L RCLB (10-14-2012), 63boxtop (11-17-2012), 6BANGER (05-29-2012), arcticzale (03-22-2016), autogateman (07-01-2016), cuda7man1 (04-10-2012), dmack6.7 (04-10-2012), enforcer17 (08-02-2012), HICKS25 (12-11-2013), ksnell (04-10-2012), makgybare (01-29-2014), RFairbairn (07-11-2012), SRich12 (04-11-2012), UNDER-PRESSURE (04-11-2012)
post #4 of 466 (permalink) Old 04-10-2012, 08:14 PM
jetfuel394's Avatar
also guys you do need six parts,cable,cable bracket,trans lever,shifter,jumper wire, column cover. part#S in previous post are accurate. this is pure awesomeness for sure!!!!
The Following 3 Users Say Thank You to jetfuel394 For This Useful Post:
6.7L RCLB (10-14-2012), cuda7man1 (04-10-2012), makgybare (01-29-2014)
post #5 of 466 (permalink) Old 04-16-2012, 04:50 PM Thread Starter
cuda7man1's Avatar
Thumbs up
Originally Posted by Soddy View Post
So is the wire we need to splice for the illumination the red/white stripe and black wire on the top left of the shifter? And I'm assuming for hooking the 12volt power that it's black to black and red to the purplish color?
Hi, you can connect into dash light circuit (E12) from pin 9 OR/GY to another OR/GY wire. On the models with heated rear seats, the switch is on the rear of the center console for this option, these switches are illuminated on the same dash light circuit (E12). When I did my shifter mod I connected to the dash light wire OR/GY that goes to the heated seat switches with a quick connect.
Harness Part Number: 68024883AA (This is for reference only)
Cavities: 10
Color: BLACK
Gender: Female
Engineering Name: Assy_Shifter
Connector No: D635A
Pin Circuit Wire Color Gauge Function
A1 NO CONNECTION
A2 K900 DB/DG 22 SENSOR GROUND
A3 T5 DG/YL 22 AUTOSTICK UPSHIFT SIGNAL
A4 Z911 BK/LG 22 GROUND
A5 K321 BR/YL 22 BTSI UNLOCK CONTROL
A6 NO CONNECTION
A7 NO CONNECTION
A8 NO CONNECTION
A9 E12 OR/GY 20 PANEL LAMPS DRIVER (this one!!!)
A10 T824 YL/DB 22 TRS PARK SIGNAL
Here is link for wiring diagrams https://techauthorityonlinedemo.extr...ew/classic.htm Here is a link for parts catalogs http://www.gmb.be/CJD_parts/CD5/Catalogs/index.pdf Have fun with your Rams and your projects!!!
The Following 2 Users Say Thank You to cuda7man1 For This Useful Post:
FROG (04-16-2012), jetfuel394 (04-18-2012)
post #6 of 466 (permalink) Old 04-21-2012, 08:33 AM
gerrypenney1's Avatar
hope this helps shroud is the grey one
2011 C/C 8" BDS fox shocks, de badged, bushwacker pockets, hs full package 4" AFE TBE, road armor pre runner, HBS steering brace, 38.13.5.20 toyo M/T on Fuel Krank 20x10 rims, console shifter and still some chrome to get rid of
gerrypenney1 is offline
The Following 2 Users Say Thank You to gerrypenney1 For This Useful Post:
Luvnacummins (04-21-2012), travishaas88 (12-09-2012)
post #7 of 466 (permalink) Old 05-01-2012, 02:01 PM
Free parts distributor
LaMoparPower's Avatar
Just a heads up guys, i gave robert at steve white parts the list of parts...... he can get it for what looks to be cheaper then any of the prices ive seen listed here... and they are a forum supporter!
beow is a link to his profile if youd like to PM him..
https://www.cumminsforum.com/forum/member.php?u=166782
2017 MCSB
Originally Posted by jmd025 View Post
Duke, can we get "official G2G backer - outer" put under his name?
LaMoparPower is offline
The Following 5 Users Say Thank You to LaMoparPower For This Useful Post:
bigdlawrence (04-21-2013), expatracer (01-30-2013), MOJO (05-01-2012), stevewhiteparts (05-01-2012), ZJARCHER (02-14-2015)
post #8 of 466 (permalink) Old 05-05-2012, 06:00 PM Thread Starter
cuda7man1's Avatar
Originally Posted by Thiago12/6.7 View Post
when you get this mopar t handle can you post a pic and part number thanks
Shift Knob - 82211622
$132.00
Mopar Billet Aluminum Shift Knobs enhance your interior's appearance. Shift Knob is a direct swap, installing easily. All hardware is included.
T-handle gear shift knob replacement for automatic transmission only, chrome finish, Mopar logo ( Hi, here is the info on the T handle!!) just google the part no. for the picture. hope this helps you out.
post #9 of 466 (permalink) Old 05-05-2012, 06:53 PM
Whussjr's Avatar
The mail man brought me the T-Handle I ordered.
2001 Black 2500 HO Q-Cab LB, 6 spd, 4x4, SO VP44, II ps62/14, PDI manifold, Quad Adrenaline/Pulse, Smarty, Mach 2's, Isspro gauges - fuel, boost & pyro, 5" mitre cut stacks, SB Con-OFE, Airdog FP150, AFE stage 1 w/power tube.......479hp/990tq
2011 Black 2500 HO CC, Deleted w/H&S MM w/ OD, ATS Stage 4 w/Co-Pilot, ATS Duel CP3s, ATS Aurora 7500 plus compounds, Flux 3s, ARP 625 studs, Hamilton valve springs & pushrods, GDP grid heater delete, GDP intake & tvm grid heater, Airdog 200, 4th gen gauges - Boost, Pyro, Drive pressure
Whussjr is offline
post #10 of 466 (permalink) Old 05-07-2012, 06:20 PM
Rex Ashton's Avatar
I got roped in.....
Dear Rex,
Thank you for placing your order with FactoryMopar.com. Order details are given below:
Order Summary:
Order Reference # 1032461
Order Status AWAITING PROCESSING
Order Date/Time 2012-05-07 18:13:42
Shipping Method UPS Ground (3-5)
Estimated Shipping Amount $30.90
Estimated Order Total $268.61
Order Comment:
Ordered Items:
Item Detail Part# Qty Price Total
WIRING-SHIFTER JUMPER
Make: Dodge
68024883AC
1 $17.36 $17.36
SHIFTER-TRANSMISSION
Make: Dodge
52855896AA
1 $113.38 $113.38
LEVER-MANUAL CONTROL
Make: Dodge
52109706AC
1 $9.38 $9.38
BRACKET-SHIFT CABLE
Make: Dodge
52104371AG
1 $6.23 $6.23
CABLE-GEARSHIFT CONTROL
Make: Dodge
52855956AG
1 $52.64 $52.64
W/console shift, Gray
Make: Dodge
Model: Ram 2500
Section: STEERING COLUMN
Category: Shroud, switches & levers
Sub-Category: Column cover
1GE44XDVAB
1 $38.72 $38.72
Dealer Detail:
Dealer Name FactoryMopar.com
Email Address [email protected]
Dealer Address [email protected]
Amityville
Dealer Phone# (888)-772-9635 [Ext: ]
Dealer Fax# --
Dealer Website FactoryMopar.com - Dodge, Chrysler, & Jeep Genuine Mopar Parts & Accessories
2010 loaded Mineral Gray 2500 CCSB Laramie 4x4, Carli, H&S, deleted, ARP head studs, 5" turbo-back, 20" Fuel wheels, Amp research, dechromed and color matched, etc.....and about 23 other CTD's that have come and gone.
Rex Ashton is offline
post #11 of 466 (permalink) Old 10-14-2012, 06:02 PM
CF Administrator
THE STIG's Avatar
iTrader Score: 6 reviews
After alot of digging, I feel this is very usefull as a sticky for anybody else that is curious. Clears up alot of confusion about the conversion. Thanks to all for the write up
Original thread source for those who like to read ALOT.
https://www.cumminsforum.com/forum/4t...o-shifter.html
Powerful - Reliable - Inexpensive. Pick any two at a time, the third is not included.
CUMMINSFORUM. Often imitated, never duplicated. The world's largest #1 resource for everything Cummins Turbo Diesel.
Need something? PM any moderator or report posts anonymously! We are here to help.
THE STIG is offline
The Following 2 Users Say Thank You to THE STIG For This Useful Post:
cuda7man1 (01-24-2019), jetfuel394 (10-18-2012)
post #12 of 466 (permalink) Old 10-16-2012, 02:21 AM
jb-kix's Avatar
So can we get the steering column covers from a manual truck? just to cover the slot where the shifter was.
2011 mega 3500,all debadged,2.5 leveled,20s fuel hostages,BFG A/T,amp power steps,snugtop,air bags, h+s mini maxx ,o.d.sofware .exaust deletes!
jb-kix is offline
