Largest Tire Size without Leveling - Page 3 - Dodge Cummins Diesel Forum
4th Gen Non-Powertrain Discussion of Accessories, Interior, everything not power related...NO ADVERTISING
post #25 of 57 (permalink) Old 02-06-2012, 11:37 AM
JustinHayes's Avatar
Originally Posted by hutchman View Post
I have 295/70-17 Trail Grappler MTs on stock ST wheels with no rub whatsoever.
Do those Trail Grappler MTs cause much road noise?
JustinHayes is offline
post #26 of 57 (permalink) Old 02-06-2012, 11:55 AM
r00ster's Avatar
I an running 295/70R17 Toyo Open Country MT on my 2011 with no problems whatsoever. Also I deal with snow and ice all the time being I live in Alaska. They have never failed me. Great highway travel with mild road noise. Also wear life is pretty good. My previous set lasted over 60K miles doing stuff I probably shouldn't have been doing. Hope this helps.
1999 Ram 2500 QCSB, auto, stock(for now)!
r00ster is offline
post #27 of 57 (permalink) Old 02-06-2012, 04:18 PM
megacabctd's Avatar
35 12.50 17 and they rub the shiaatt out of the control arms
2011 Dodge Mega 2500 4x4- Color matched, Carli Equipped, on 37's
They 10's but I keeps em clean
megacabctd is offline
post #28 of 57 (permalink) Old 02-06-2012, 09:34 PM
im running 35 inch general grabbers on 18 inch rims with no rubbing at all I have a buddy running 37's with no leveling kit on stock tires but i like my 35's better
Murdered2500 is offline
The Following User Says Thank You to Murdered2500 For This Useful Post:
lustrium (10-03-2013)
post #29 of 57 (permalink) Old 02-06-2012, 11:16 PM
paratrooper's Avatar
Before I leveled my truck - 285 75r 18 BFG KM2s on Rockstar rims rubbed slightly in the driver side wheel well. A heavy duty (black zip tie) took care of the problem. I simply drilled two small holes at the bottom of the wheel well and pulled it back about an inch and took care of everything. I have sinced leveled the truck - not because of the tires, but to counter the sag from my Ranch Hand bumper. Hope this helps.
Wayne
2011 Ram 3500 SRW Mega Laramie HO 4X4
2.5" level, 285-75R/18 BFG KM2s, Rockstar Rims
Ranchhand Legend Bumper
paratrooper is offline
post #30 of 57 (permalink) Old 02-21-2012, 10:41 PM
Originally Posted by n2o View Post
With some +.5in control arms to center the wheel/tire up in the wheel well, you can make 35+in tires fit. My last truck had a "leveling kit" on it that placed unwanted stress on my steering system. I had one side of my trackbar/drag-link snap on me. I have already added extra support to my new truck and I've been researching my wheel/tire combo. I ordered some control arms today and I'm going with 295/60/20 Terra Grapplers on some 20x9 wheels with a -offset. From the things I've read I should be able to clear them without issue. Keep researching and you'll find what you're looking for. Look over on dodge talk for more info as well.
Hey did these fit for you or did they end up rubbing? What rims did you get, and whats the offset you ended up with? Consdiering the same tires as well! Else I will go with 275/65/20!
2010 Dodge Ram 2500 CTD MC 4x4 Laramie - MBRP 4in TBE w/ muffler, Mini Maxx w/ MCC from TSD, ARP 625 Studs, Sinister EGR Delete
HemiAg is offline
post #31 of 57 (permalink) Old 02-22-2012, 07:56 AM
Glad to Be Here
2012 RAM 3500's Avatar
Got any pics?
2012 Ram 3500, G56, 4 x 4. Stock. SOLD.
2012 RAM 3500 is offline
post #32 of 57 (permalink) Old 02-22-2012, 08:18 AM
JEDJR's Avatar
Anyone have any feedback on the Kumho MT KL 71 Tire?
2012 Sagebrush Dodge 2500 CCSB 4x4 6.7 Cummins H.O.,AFE Magnum Force Stage 2 Pro Guard 7 Gold CAI,Top Gun Customz 2 1/2 inch leveling kit ,TGC adjustable track bar, 5100 Bilstein shocks,3rd Gen aluminum rims,Kumho MT-KL71 265-70-17's
JEDJR is offline
post #33 of 57 (permalink) Old 02-22-2012, 08:57 AM
I have a similar question and could not find the answer I was looking for in the what wheel will fit thread.I have a 2011 Laramie 3500 crew and want to upgrade the wheels and tires.I don't want to do any mods other than wheels and tires and don't want any rubbing.I want to go with an 18" rim with Nitto E rated Terra grappler AT'S. I would like to run a 275/70/18 tire my question is what offset do I need so there will be no rubbing??My truck is admittedly a pavement princess who's only purpose is to pull our boat, haul a camper and tow our enclosed Harley trailer.Here is a pic of the truck and the wheels I want to use any help would be much appreciated
Name:	Aug. 12th 002.jpg
ID:	41808   Click image for larger version
h20king is offline
post #34 of 57 (permalink) Old 02-23-2012, 01:15 AM
djcheez's Avatar
i dont have a calculator in front of me and dont want to look up the size of that tire so can you give a standard size for that tire? I have 34x11 terra grapplers on a 20" wheel with zero rubbing. The Wheel is either -18mm or +18mm and sits nicely in the wheel well. Ive got 55k miles on them and will probably put new ones on in about 10k or so miles and will go up to 35's.
2010 2500 Black cclb, 4x4 auto, 4.10. 35.5x12x20 Nitto Trails. 2.5 levelling, airbags. 4"flopro straight , MM, H&S EGR and cooler delete. updated tune ATT. ARP2000's
djcheez is offline
post #35 of 57 (permalink) Old 02-23-2012, 01:21 AM
megacabctd's Avatar
you could run 40's if you had a body saw
post #36 of 57 (permalink) Old 07-11-2012, 03:01 AM
im_compensating's Avatar
I have 37x 12.5r17s on my 03 ram dually. The only rub I got w/ no mods was on the plastic inner fender and sway bar. And that's only cuz my hankooks have the sidewall lugs. So 35x12.5 would clear both by an inch about. Or 315x70 is equivalent. Also some tire shops will let u test fit different sizes, that's how I determined what size I wanted.
Sent from my DROID RAZR using AutoGuide.Com Free App
2012 3500 4x4 6spd 8in lift, 40x15.50r20s, 4.44 gears, SB dual disk ceramic clutch, Airdog 150, EFI Live, Cheetah VGT
Gone: 2003 3500 6spd, 1989 W350 5spd
im_compensating is offline
