Car audio amps and alternator discussion - Dodge Cummins Diesel Forum
4th Gen Non-Powertrain Discussion of Accessories, Interior, everything not power related...NO ADVERTISING
 3Likes
post #1 of 28 (permalink) Old 03-24-2020, 04:10 PM Thread Starter
Andrewme's Avatar
Hello all. Wanted to start a discussion about car audio. I have pioneer door speakers running off a pioneer 4 channel amp running 100w rms at 4ohms and 2 American Bass xd10 dual 4 ohm vc wired to 1 ohm on a Kicker CXA1200.1 amp. One of my buddies is big into car audio and is telling me I'm not going to get more then 500watts with the stock electrical system. Is he full of bs? I have a 0ga wire from the passenger battery run under the truck, comes up through the floor behind the rear seat and splits into 4ga wire. One to each amp. And a 200A breaker 6" from the battery.
2011 Ram 2500HD CCLB. G56. Valair DD clutch, 5" tbe, stainless diesel 472SX-E, ATS twin cp3, S&S 80% injectors. Smeding diesel intake horn, aem meth injection, air dog II 165gph lift pump, EFI Live by Anarchy Diesel, 1.75" level; 35x12.5R17 on G-FX TR-12
Andrewme is offline
post #2 of 28 (permalink) Old 03-24-2020, 04:20 PM
Good question lol, I’m getting ready to go down this road for the first time. Something different then power train and drivetrain. I know a lot guys on here have nice setups just doesn’t get talked about the details too often. Because you’re automatically a young punk if you have a system lol I’m old enough to be a lot of these guys dad but I still like my music loud! Good luck
Fass6.7 is offline
post #3 of 28 (permalink) Old 03-24-2020, 04:24 PM Thread Starter
Andrewme's Avatar
Yea. Not wanting to shatter and windows or anything. Just like my music sounding good and I like to feel it.
Andrewme is offline
post #4 of 28 (permalink) Old 03-24-2020, 05:43 PM
cumminthanstrockin's Avatar
What alternator are you running? I will promise you a normal 180 wont support 1200 especially with 20 or so of cabling you have.
Tow Rig: 2011 Ram 2500 Laramie MCSB - FloPro | Sinister | Draconian EFI | Thuren/Carli | Fuel Wheels | Toyo MT | RIGID INDUSTRIES
Daily Driver: 2016 Ram 1500 Laramie Longhorn Crew Cab w/ 5.7 Hemi & 8 Speed
cumminthanstrockin is offline
post #5 of 28 (permalink) Old 03-24-2020, 05:54 PM Thread Starter
Andrewme's Avatar
I had a mopar 220A but it burned up last fall so had to put the stock alt back on. Theres about 15' of 0ga wire. Found a company in Arizona that has a 250A for 300. Or could go big with a mechman 240A unit for 400. Also running 4 led fog lights at night, and have a 13K winch that I use on occasion. Of course the music will be turned way down before I use it. Also have an 8 led bulb stove light kit that's used in conjunction with the winch. The winch has been bogging down a good bit this winter. Use it to pull cars/trucks out of the ditch when it snows bad.
Andrewme is offline
post #6 of 28 (permalink) Old 03-24-2020, 05:56 PM
Rear Admiral Rickard Onmi
Loki223's Avatar
Can't chime in to much on this, as i am by all means a car audio Novice However, @Andrewme When i was doing my sub upgrade i consulted a buddy of mine who had over 10 years of car audio experience as an installer and designer. I considered running the power wire under the truck and he immediately told me to never do that Even high quality marine grade power wires will eventually wear and cause issues. In your issues i would either look into some heavy duty loom to protect your power wire and prevent a future electrical hazard, or re-route the power wire entirely.
Busted likes this.
2018 Ram 3500 Limited - Crew Cab Long Box 4x4 SRW Stock at the moment, but that will change
Make your puddle lights great again!
SUPPORT SITE VENDORS, THEY MAKE ALL THIS POSSIBLE
HELP ME UPDATE MY IMAGES, IF YOU SEE A BROKEN IMAGE LINK, SEND ME A PRIVATE MESSAGE SO I CAN UPDATE THE IMAGE TO A NEW HOSTING SITE
Loki223 is offline
post #7 of 28 (permalink) Old 03-24-2020, 06:06 PM Thread Starter
Andrewme's Avatar
I used pure copper oxygen free welding cable. And is zip tied above the frame. I learned my lesson after having to replace all the wires for my fog lights and rear camera wire from corrosion.
Andrewme is offline
post #8 of 28 (permalink) Old 03-24-2020, 06:20 PM Thread Starter
Andrewme's Avatar
From my install last week. It's crazy messy still. Need a bit warmer weather to tidy everything up.
Andrewme is offline
post #9 of 28 (permalink) Old 03-24-2020, 06:31 PM
Id recommend the highest alternator you can. A 180 wont hold a candle to a 750 watt amp running higher in the load range. Unless your truck is charging a strong 14.4+ it wont power the amp appropriately. I recommend jumping up the amperage and you should be fine even if your stored voltage drops once youve turned on your fogs and headlights.
Another quality piece of hardware that can somewhat prevent big fluctuations (your Amps worst nightmare) is a capacitor. It will hold power for those big hits and prevent the trucks voltage from dropping drastically. Theyre rather cheap and could make it feasible to use a 300 amp alternator vs a 400. Crutchfield has many options.
post #10 of 28 (permalink) Old 03-24-2020, 06:42 PM Thread Starter
Andrewme's Avatar
Okay. I may step up to the mechman 320A and upgrade all the power and ground wires. The fog lights only pull about 5 amps per pair. And their only used at night which I dont seem to be doing much night time driving in it anymore. And it doesnt even get dark until around 10pm or later during the summer here
Andrewme is offline
post #11 of 28 (permalink) Old 03-24-2020, 06:52 PM
iTrader Score: 15 reviews
While corrosion may be its own problem, I believe that what the other poster is referring to is an eventual fire hazard due to the wire insulation wearing down against the truck frame/body at contact points. While I happen top believe that running power wires under the truck is OK, I also do believe in running hime either in flex conduit or corrugated wire loom for added safety. Of course, ir also needs to be properly fused at the battery end of things.
Here is a GREAT link to help you figure out wire sizes etc , as well as provide excellent basic wiring information--
WIRE
Andrewme likes this.
2005 SLT 4x4 QC LB G56, GDP horn, HDCAI, SBC ConOFE,
seafish is offline
post #12 of 28 (permalink) Old 03-24-2020, 07:06 PM Thread Starter
Andrewme's Avatar
I used a 200A breaker type fuse about 6" from the batter. I should add a fuse after the 0ga splits into 2 4ga wires but theres not much room to add one.
Andrewme is offline
