2010 ST - Retrofit Tailgate Lock/Camera - Dodge Cummins Diesel Forum
4th Gen Non-Powertrain Discussion of Accessories, Interior, everything not power related...NO ADVERTISING
post #1 of 5 (permalink) Old 06-11-2019, 03:13 PM Thread Starter
I would like to install a tailgate lock and rear camera for my truck. I have an aftermarket head unit that has an input for a backup camera.
I have found this handle:
https://www.ebay.com/itm/Tailgate-Ba...72.m2749.l2649
and the part number for the OEM lock (68071073AA). Is that all I would need? What else?
2010 CCSB 68RFE - HP Tuner self tuned - BD Diesel Protect68 Kit - Transgo 45RFE-HD2 Shift Kit - 4" TBE Exhaust w/ 17" FTE Resonator - Crower 110lb valve springs - Manton Series 3 Push Rods 7/16x.120 - 12.9 head bolts
jfreemanak is offline
post #2 of 5 (permalink) Old 07-31-2019, 11:56 PM Thread Starter
No ideas? I bought the 68071073AA part, but it is not everything that I need to have a locking tailgate.
post #3 of 5 (permalink) Old 08-06-2019, 08:13 PM
timm9's Avatar
The unit appears to be identical to the one I installed last year.
Install was quick and without issue except wiring.
FWIW, You will need to 'tap' into the wiring harness for the Trailer wiring as the amperage to the backup lights are too low to trigger the backup camera.
2011 Dodge 2500 SLT
timm9 is offline
post #4 of 5 (permalink) Old 08-07-2019, 12:13 AM Thread Starter
Thanks for the information. What about the lock? Did you already have one or what parts did you have to buy?
post #5 of 5 (permalink) Old 08-14-2019, 06:37 PM
I bought a similar backup camera to yours. The power from my backup lamps works fine on my truck.
As for the tailgate lock, my SLT had a lock from the factory. But I added an actuator from Pop and Lock so it works with the door locks. Same for the topper on my truck.
If you need just the lock mechanism, it's a pretty simple thing, but I'm not sure the part numbers. It's been well over a year since I had mine apart, so I can't recall exactly how it all works.
This is the actuator: https://www.popandlock.net/power-tai...50Ram2500-3500
You may also need this release lever to go with your lock cylinder: https://parts.allmoparparts.com/oem-...wtbDYtZGllc2Vs
Hope that helps.
David Walker
2012 2500 4x4 CCSB/SLT/6.7L/68RFE/3.73 /deleted black vinyl door posts/breathing free /H&S XRT Pro Race/FloPro/5100's/2" Daystar
x2mosg is offline
