Brake Dust - Dodge Cummins Diesel Forum
4th Gen Non-Powertrain Discussion of Accessories, Interior, everything not power related...NO ADVERTISING
post #1 of 8 (permalink) Old 04-04-2019, 04:14 PM Thread Starter
Brake Dust
Recently made my first couple longer trips towing the trailer and I've noticed something unusual. Cleaned the truck before leaving and now the right front wheel is significantly dirtier than the rest with brake dust. A reddish coating. The opposite side is not bad at all.
Do factory pads dust up badly? Why the extra dust one side? A caliper dragging?
2013 Ram 2500 BigHorn - Black - 6.7l Cummins - Bone Stock
KYBigHorn is offline
post #2 of 8 (permalink) Old 04-04-2019, 05:04 PM
Lins's Avatar
Yes they can dust up a lot, and very common especially with the front passenger tire if you dig around. Mine did it more when it was newer, not so noticeable now.
Lins is online now
The Following User Says Thank You to Lins For This Useful Post:
KYBigHorn (04-04-2019)
post #3 of 8 (permalink) Old 04-04-2019, 10:29 PM
Tech740's Avatar
Mine did that on the drivers side. Frozen caliper pin was my issue.
2010 Ram 2500 Quad Cab
6.7 Short bed 3:73
Tech740 is offline
The Following User Says Thank You to Tech740 For This Useful Post:
KYBigHorn (04-05-2019)
post #4 of 8 (permalink) Old 04-05-2019, 01:38 PM
I have the 17" factory rims on my 2012 and it does exhibit some brake dust when towing. It is a reddish rust color with my truck as well.
2012 2500 Laramie, 6.7L 4x4 w/ 68RFE Auto Trans, Mega Cab Short Box w/ AFE CAI, AFE trans pan, AFE rear diff cover, Throttle-Up Industries fuel filter kit, Alpharig steering stabilizer brace
tnt_motorsports is offline
The Following User Says Thank You to tnt_motorsports For This Useful Post:
KYBigHorn (04-08-2019)
post #5 of 8 (permalink) Old 04-13-2019, 09:18 PM
BR1
I've been chasing this on my truck, but on drivers side. I think it might just be a difference in my rotors or something. they are EBC ceramic pads, and 3 wheels stay quite clean. the front drivers is nasty. no pull, no sticking, pins are clean.
2010 CCLB Auto 4x4, 37x12.5x17 Ridge Grapplers, Method Standard machined, dynatrac pro-steer's, Carli TracBar, Carli arms, Carli Fox Commuters, Creative Box Brace, 3" Carli springs, synergy shackle, Tom Woods front shaft, synergy steering, carli lower stablizer.
BR1 is offline
post #6 of 8 (permalink) Old 04-14-2019, 02:32 PM
aflumb1982's Avatar
as I clean my truck every week I hardly ever have brake dust build up. the problem I have is the driver side front squeals every time I touch the brakes. its really annoying. I have taken the pads off once already. going to do it again.
'17 Delmonico Red Laramie 4X4 Mega, ProZ cover, N-Fab steps Thuren 2.75 kit, Track bar, Method NV 305 Bronze/Cooper STT Pro 295/65R20, RC steering stabilizer, rear spacer---'06 4X4 Mega Cab- (sold 15 Apr 2017)
aflumb1982 is offline
post #7 of 8 (permalink) Old 04-17-2019, 03:31 AM
Pufferman's Avatar
Think factory pads are bad? My Orange Stuff pads = dust build up by end of day. LOL
THE WHITE WHALE 2010 2500 6.7 4x4. Auto. MCSB. 363SXE. Hamilton 194/220. Manton 110# Springs & Rods. ARP 2000. 160HP Tune By PHIL. 5" TBE. AFE Intake. Fleece Thisandthat.
Pufferman is offline
post #8 of 8 (permalink) Old 05-25-2019, 10:20 PM Thread Starter
I finally pulled the front caliper apart today. The pads are effeminately dragging. Caliper pins were free. It looks like whomever did the last pad change used the old pad hardware. The clips that the pads slide in on the end. They were gummed up and gritty. Pulled them each out and sanded and cleaned them up. When I put the pads back in the they were much more free to move in the caliper bracket. There are a couple little springs on each end of the pads and it was pushing the pads away from the disc which it wasn't doing before I started. Hoping that does the trick. If not it has to be the caliper.
Similar Threads
Anyone else having bad brake dust issues up front? 2018 TakeAwayTheFear 2013-2018 General Discussion 6 03-29-2018 09:32 AM
Replace OEM Ram Brake Controller with an Aftermarket Brake Controller? MoreTorque 2013-2018 General Discussion 111 10-08-2016 09:36 AM
Brake issues... Help please dodgedieselnewbie 98.5-02 Non-Powertrain 59 05-05-2016 07:20 PM
Brake dust mbjerry Detailing 1 04-10-2012 02:19 PM
