AlphaOBD - Turbo Actuator Calibration - Page 4 - Dodge Cummins Diesel Forum
4th Gen Non-Powertrain Discussion of Accessories, Interior, everything not power related...NO ADVERTISING
 8Likes
post #37 of 41 (permalink) Old 10-07-2019, 04:54 PM
nibs75's Avatar
I feel.like there must be a flag set in ecmor somethingnin computer not allowing the calibration. I expected a quick job.
Sent from my SM-G955U using Tapatalk
2013 Ram 2500 Laramie MegaCab - CTD
Sold - 2008 RAM 2500 MegaCab - CTD
Sold -2005 RAM 1500 QuadCab - HEMI
nibs75 is offline
post #38 of 41 (permalink) Old 10-07-2019, 07:31 PM
nibs75's Avatar
Checked with another scanner and found this code I dont see in alfa obd. Cannot clear this. I am able to write stock file back to ecm and back to tuned file.. but not sure if this has anything to do with not being able to calibrate?
nibs75 is offline
post #39 of 41 (permalink) Old 10-07-2019, 07:54 PM
nibs75's Avatar
Disregard.. code is normal for my truck. My brain is tired. I'm tired of thinking about this.. I guess I will have to get someone smarter than I am.. lol
nibs75 is offline
post #40 of 41 (permalink) Old 10-07-2019, 09:52 PM
nibs75's Avatar
Thanks to Diesel Power and Performance, a local shop, I am calibrated and buttoning things up. They stopped by with the professional scan tool and got it done. For whatever reason alfa obd did not work for me.
wilsonck and SRich12 like this.
nibs75 is offline
post #41 of 41 (permalink) Old 12-01-2019, 12:36 PM
AlphaOBD VGT Calibration
Just wanted to weigh in on my experience using AlphaOBD for VGT calibration. I bought a new actuator. I'm using the MX+ scanner. I performed the pre-alignment with no problems. When I installed the actuator and tried the calibration, it would not complete. I waited several minutes and finally cancelled the test. I took the actuator back off and tried to do the pre-alignment again. Now it wouldn't work either. I started looking around in AlphaOBD and noticed that my battery voltage was only around 8 Volts. I had the hood open for several days and didn't realize that the hood light doesn't time out. I just figured with all the computers on these things that it would time out rather than drain the battery. I hooked up a battery charger and let it charge overnight. Next morning, I scanned for errors and had an error that actuator was not calibrated. Sorry I don't remember the exact code. I couldn't clear it. I performed the pre-alignment successfully. Installed the actuator and it also performed the calibration successfully. Bottom line, AlphaOBD will perform VGT pre-align and calibration, but your batteries need to be well charged. BTW, I have a 2013 Ram.
srt84me is offline
Similar Threads
STEALTH 64MM Drop in Turbo 600+ Hp Factory Appearing. Calibrated Power 3rd Gen. Performance Parts Discussion 183 05-22-2019 11:35 AM
Garrett Powermax Stage 2 GT3782R Install/Review AH64ID 3rd Gen. Performance Parts Discussion 264 10-01-2017 12:15 PM
Had it up to my EYEBALLS w/ he351.. have you changed out your turbo? I need your hel only1stegall 07.5 - 09 3rd Gen 6.7L Powertrain 66 07-28-2016 10:06 AM
Is this the correct wiring woodworthcummins 3rd Gen. Powertrain 8 04-28-2012 09:07 PM
Switchblade turbo CumminsDieselSoot 3rd Gen. Performance Parts Discussion 3 04-24-2012 03:21 PM
