Light bar in stock bumper - Page 2 - Dodge Cummins Diesel Forum
4th Gen Non-Powertrain Discussion of Accessories, Interior, everything not power related...NO ADVERTISING
 8Likes
post #13 of 23 (permalink) Old 01-14-2019, 09:38 PM
14 2500/68rfe 4X4 CC SWB Tradesman 315/70/18 Toyo MT's
ARE DCU
2500/6 is offline
The Following User Says Thank You to 2500/6 For This Useful Post:
Rhinopkc (01-14-2019)
post #14 of 23 (permalink) Old 01-17-2019, 12:48 PM
MSquare's Avatar
Vision X 20" light bar and Vision X mount. Very $$$ but the light output is ridiculous. I travel over two mountain passes with lots of deer and elk, so I figured the extra light was worth the expense. It is way to bright to ever use in traffic, but I'm on the road at 0400 so there is not a lot of other vehicles out at that time.
ID:	838451   Click image for larger version
G. Mcpherson likes this.
2015 2500, crew cab, auto, sb, stock Cummins, ARE Canopy, Cargo Glide, Vision X front and rear, Carli Backcountry System, XD 20" Wheels, Toyo ATII's 35/12.5/20, Duraflaps
MSquare is offline
post #15 of 23 (permalink) Old 01-17-2019, 01:25 PM
https://www.thurenfabrication.com/pr...ght-mount.html
2018 CCLB 3500 SRW 4X4 Laramie - Air Bags - BW Companion - Cat 2 Micron Fuel Filter - Amp Steps - Thuren 1.75 - King 2.0 IFP - PML Rear Diff Cover
2018 Grand Design Reflection 28BH 5th Wheel
Phillipjon is offline
post #16 of 23 (permalink) Old 02-04-2019, 11:32 PM
firemancooter's Avatar
I just put a 42" light bar in my tradesman withOUT tow hooks. Bolted up with just a little tweaking to the brackets. Works like a champ. We will see how good the quality is on the light bar.
Sent from my SM-G950U using Tapatalk
firemancooter is online now
post #17 of 23 (permalink) Old 02-05-2019, 12:52 AM
HeavyTwo's Avatar
I dumped the factory hooks. They bend or misalign the bumper if you apply any load other then exactly 90. I used a curved LED light, the curve matches the curve of the bumper.
I have a front receiver used to park large trailers. I mounted a D-Ring there as a replacement to the factory hooks. ( I just installed the D-ring in this picture, its kinda too big for my likings. Had a smaller normal one before.)
2014 RAM HD. Cummins 6.7 364.5SXE Turbo. EZLynk Tuned. Straight piped. Air-Ride.
HeavyTwo is online now
post #18 of 23 (permalink) Old 02-06-2019, 03:27 PM
Does that bar come with a harness or did you purchase was separately, how was wiring it up? I have the brackets that measure 42,5" between the brackets, but no bar. Do you have the grid heater plug, can you still access it with the light bar there?
2016, 2500, 6.7, Mega, Laramie, 68rfe, SAP, AMP Steps, HIDs.
adboyd06 is offline
post #19 of 23 (permalink) Old 02-06-2019, 04:16 PM
Jimmy N.'s Avatar
Originally Posted by Vicdaman7 View Post
Would the light bar affect the cooling of the engine or transmission?
I would think that the charge air cooler is the big loser when blocking that portion.
Jimmy N. is offline
post #20 of 23 (permalink) Old 02-06-2019, 05:05 PM
It doesn't come with a harness. I got one from Amazon, less then $15. And I dont have the plug but there is a little space on the ends that I would think is enough for your plug.
post #21 of 23 (permalink) Old 02-14-2019, 02:59 PM
'13 CTD, Outdoorsman, 20" 645MB Dropstars with Toyo AT II's LT 275 65 20E, Clear hoodguard painted body color, Tinted windows, (crappy) Mopar tonneau cover.
My other ride is your sister
Last edited by Dodosmike; 02-14-2019 at 03:37 PM. Reason: nothing to see here folks, move along......
Dodosmike is offline
post #22 of 23 (permalink) Old 03-31-2019, 07:30 PM
Kodiak led has a 28" that fits perfectly between factory tow hooks.
Requires a bit longer tow hook bolt, so you can fit bracket behind the hooks
chadfeeg is offline
post #23 of 23 (permalink) Old 03-31-2019, 08:05 PM
K9Kodi's Avatar
Where in va is the op from
--2015 2500, Crew Cab, Long Bed, 4x4, G56, Maximum Steel
- To Do List, 6" suspension,37" tires,4.56 Gears
--2006 2500 4x4 4 door long bed auto, 8" BDS, 37s
K9Kodi is offline
