2012 to 2016 Laramie Limited Grille Upgrade - Page 2 - Dodge Cummins Diesel Forum
4th Gen Non-Powertrain Discussion of Accessories, Interior, everything not power related...NO ADVERTISING
 10Likes
post #13 of 17 (permalink) Old 01-30-2017, 06:04 PM
Striper05's Avatar
Very nice job....looks great
Sent from my iPad using Tapatalk
2016 3500CC 4X4 6.4 bed CTD
207Cummins12 likes this.
Striper05 is offline
post #14 of 17 (permalink) Old 01-31-2017, 10:58 AM
Heck if I know
bulldogbones's Avatar
Good Golly Miss Molly, that sucker aint cheap.
2010 6 wheeler, 4x4, 4th gen factory matched gauges (Boost, Trans, Egt) A1H11 Studs,S467, BD Exhaust Brake, EFI Anarchy
bulldogbones is offline
post #15 of 17 (permalink) Old 01-31-2017, 11:02 AM
67guzzler's Avatar
Yep -- You gotta want it...
-Guzzler
2017 2500 Crew 4x4 Laramie 6.4L HEMI 66RFE w/4.10
PRIOR: 1994, 1996, 2004, 2005.5, 2010 and 2013 2500's. ALL Cummins.
If someone is nice enough to post a truck-related pic,
I'm more than happy to click a "Like or Thanks."
67guzzler is offline
post #16 of 17 (permalink) Old 02-01-2017, 01:20 PM Thread Starter
207Cummins12's Avatar
Here's another picture of the grille on the truck. Best I can get right now, getting ready to put EBC brake pads on and clean the layers of OEM brake dust off my wheels.
67guzzler likes this.
2012 Ram 2500 Limited 6" Lift, 37"X13.5" Toyo Open Country, Fuel Maverick 22x12. Deleted. EZ Lynk W/HPP Tunes. Building a Custom Air Ride Setup (Rear is built).
207Cummins12 is offline
post #17 of 17 (permalink) Old 11-30-2019, 11:30 AM
DieselSandwich's Avatar
Originally Posted by 207Cummins12 View Post
Hey Guys,
First upgrade thread on here so bear with me.
Did a Grille upgrade on my 2012 Laramie limited tonight, I replaced it with a Limited grille from a 2016.
I purchased mine from AllMoparParts.com. Cost me an arm and a leg but I love the look and it was brand new and here in less than a week.
Part Numbers shown in the picture below:
First thing you have to to do is remove the four push buttons that hold the top cover on. Then remove the four bolts on top of the grille. Once these are removed with a firm pull on each bottom corned the grille snaps out.
Now on to the new grille:
First step is to flip the grille over and remove the driver side inner support shown in the picture below to make room for the cooler lines.
After that you have to make a few adjustments to the lower grille mounts on the truck and to the lower attachments on the grille itself.
First I cut a slit for the lower grille hook:
Then I found out that the grille wouldn't sit flush enough to shut the hood, so I had to notch out the mount:
Followed by shaving the hook on the grille:
After all of that the grille snapped right into place. The only thing I did was make a couple of plastic shims for the inner two bolts where the grille attaches to the truck. Only tools I needed was a dremel with an end grinder attachment and a cutting wheel. Hope this help someone else looking to install this grille.
Im interested in doing this on my truck but cannot view the pics in your post, any chance you could send them to me? Thank you
DieselSandwich is offline
