new tires.......now alignment is off and truck pulls to the right. - Dodge Cummins Diesel Forum
4th Gen Non-Powertrain Discussion of Accessories, Interior, everything not power related...NO ADVERTISING
post #1 of 16 (permalink) Old 11-06-2015, 04:41 PM Thread Starter
DOC3500's Avatar
any ideas why?
DOC3500 is offline
post #2 of 16 (permalink) Old 11-06-2015, 04:43 PM
That Truck Guy
Skyd Ram's Avatar
iTrader Score: 8 reviews
Originally Posted by DOC3500 View Post
any ideas why?
What tire did you come from and what tire did you go to?
Many tires on the market will have a little left or right pull. In some cases you can compensate for this with some alignment work. In other cases you can run a higher pressure adjustable stabilizer like the Carli High Mount (on a '13+ 3500) to help correct right pulls. For 03-13 2500's a Low Mount can be used.
Carli Suspension | Pure Performance Suspension | Bilstein Shocks | Dynatrac
Synergy Suspension | Fox Shocks| aFe Power | S&B | SOTA Wheels| Air Dog | Amp Steps
TRUCKBOSS Sled Decks | Spicer | ARP | REV-X | RIGID Industries | Baja Designs
888-886-2480
Skyd Ram is offline
post #3 of 16 (permalink) Old 11-06-2015, 04:52 PM Thread Starter
DOC3500's Avatar
I came from the general grabber that came on the truck from the factory to stock size wrangler duratracs
DOC3500 is offline
post #4 of 16 (permalink) Old 11-06-2015, 05:02 PM
Mine does the same thing. Will get stabilizer, track bar and steering brace. Hopefully that should solve all issues.
2014 6.7L CTD CC SLT, Anarchy,Deviant EGR kit, 5" TBE, Autometer Pyro/Boost, Thuren Fox IFP, 315/70R18 Toyo M/T on Stock wheels, 2" Spacers, Stubby Antenna, Tint,S&B Intake, GDP Big Line Kit, ARP 425
shanerocks is offline
post #5 of 16 (permalink) Old 11-06-2015, 05:40 PM
That Truck Guy
Skyd Ram's Avatar
Toyo MT's have a very noticeable right pull. A Carli High Mount (on radius arm trucks) will solve it and those others items will tighten up the steering feel even more.
888-886-2480
Skyd Ram is offline
post #6 of 16 (permalink) Old 11-06-2015, 05:42 PM
That Truck Guy
Skyd Ram's Avatar
Sounds like it is just a side effect of those tires. If it is a mild pull your alignment shop may be able to take care of it with a little cross caster. If not then a Carli High Mount stabilizer (on a '13+ 3500) would be your best bet.
888-886-2480
Skyd Ram is offline
The Following User Says Thank You to Skyd Ram For This Useful Post:
DOC3500 (11-06-2015)
post #7 of 16 (permalink) Old 11-06-2015, 05:45 PM Thread Starter
DOC3500's Avatar
thanks for the info fellas
DOC3500 is offline
post #8 of 16 (permalink) Old 11-06-2015, 05:50 PM Thread Starter
DOC3500's Avatar
what's the difference between a low mount and a high mount?
DOC3500 is offline
post #9 of 16 (permalink) Old 11-06-2015, 05:55 PM
That Truck Guy
Skyd Ram's Avatar
ON a '13+ 3500 and a '14+ 2500 a Low Mount replaces the stock stabilizer and "pushes" to the right. This would be good for correcting a tire that pulls left.
The High Mount works in addition to the stock stabilizer but "pushes" to the left to help correct for right pulls. They are also great for guys running 37's and bigger and/or pounding their trucks pretty hard off road.
888-886-2480
Skyd Ram is offline
post #10 of 16 (permalink) Old 11-06-2015, 06:30 PM
Originally Posted by Skyd Ram View Post
Toyo MT's have a very noticeable right pull. A Carli Low Mount will solve it and those others items will tighten up the steering feel even more.
Would a Thuren stabilizer do the same thing? Since I have his setup?
post #11 of 16 (permalink) Old 11-06-2015, 06:38 PM
Probleminfected's Avatar
I'd either raise the caster on the left side or lower the caster on the right side.
Hard to tell with it not on the machine.
But if you paid for an alignment, I'd have them fix it, if they know how that is. Just because the can get anything in the green doesn't mean they know what they are doing.
Probleminfected is offline
The Following User Says Thank You to Probleminfected For This Useful Post:
post #12 of 16 (permalink) Old 11-06-2015, 06:48 PM
That Truck Guy
Skyd Ram's Avatar
I assume that the Thuren stab pushes right so it would make it worse just like a Carli Low Mount would. The Carli High Mount pushes left to counteract the right pull of the Toyo's.
888-886-2480
Skyd Ram is offline
The Following 2 Users Say Thank You to Skyd Ram For This Useful Post:
DOC3500 (11-06-2015), shanerocks (11-06-2015)
