2017 RAM 4500 4x4 ESC light stays on - Dodge Cummins Diesel Forum
4th Gen Cab & Chassis Discussion of performance, powertrain, and non-powertrain on Cab & Chassis Trucks....NO ADVERTISING
 1Likes
  • 1 Post By Jimmy N.
post #1 of 6 (permalink) Old 11-17-2019, 05:23 PM Thread Starter
spdgofast's Avatar
Hey guys, I just bought a 2017 Ram 4500 4x4 Cummins and the ESC light stays on. If I hook up my El Cheapo scanner to it I get no codes. I can turn the ESC on and off with the button on the dash but the one ESC light always stays on. The truck is 100% stock and has 27000 miles on it. Any ideas?
ID:	860855   Click image for larger version
ID:	860857   Click image for larger version
95 RAM 3500 4X4 12 VALVE, BUILT TRANS, 271 T CASE, GEAR VENDORS O/D, ARP HEAD STUDS, 62/65/13 TURBO, INJECTORS. SOLD. BEING REPLACED WITH 09 RAM 3500 4X4 AUTO LARAMIE, SO FAR 2ND GEN TURBO SETUP, PUSHER INTAKE.
spdgofast is offline
post #2 of 6 (permalink) Old 11-17-2019, 08:12 PM
Jimmy N.'s Avatar
Did you do a Brockman and pinch a wire with the diff cover?
Jimmy N. is offline
post #3 of 6 (permalink) Old 11-20-2019, 09:02 PM Thread Starter
spdgofast's Avatar
What the heck is a "Brockman"? I checked under the truck and the rear speed sensor wires look good and in place. The 4500 has a one piece axle housing like a Ford 9 inch so there is no diff cover.
post #4 of 6 (permalink) Old 11-21-2019, 01:39 PM
Jimmy N.'s Avatar
Ah, yes, I forgot. @gsbrockman pinched stuff when he still had a 3500, then bought a 4500 to eliminate that potential problem.
gsbrockman likes this.
Jimmy N. is offline
post #5 of 6 (permalink) Old 11-22-2019, 10:36 AM
White Lightning
gsbrockman's Avatar
iTrader Score: 28 reviews
You should be under the 3/36 warranty, unless your in-service date determines otherwise. Seems like a trip to the dealer is in order.
2018 RAM 4500 Chassis Tradesman Crew Cab 60 C/A 4WD, 6.7L Cummins, AISIN AS69RC Transmission, 4.10 Axle Ratio, Chrome Appearance Group, Keyless Entry, Fog Lamps, Chrome Tubular Steps, 52+22 gallon fuel tanks, 5.0 Radio, Single Disc CD Player, 225/70R19.5 Firestone FD690s, Aluminum Wheels, Parkview Backup Camera, Trailer Brake Controller. Equipped with a CM SK Series flatbed w/B&W Turnover Ball. Purchased new April 23, 2018. Currently : 187,948 miles and 3,293 hours as of December 23rd, 2019 (Average Miles Per Hour = 57.1)
gsbrockman is offline
post #6 of 6 (permalink) Old 12-13-2019, 02:42 AM
BrianF's Avatar
Any updates? The ESC should be a chassis code, which requires a fancier code reader to pick up. In my experience, that could be a crappy ABS sensor or steering wheel position sensor.
2017 Ram 3500 Megacab, SLT, True Blue, SRW, CTD, AS69RC. Ubique
BrianF is offline
