Using OEM fog light switch fir lightbar - Dodge Cummins Diesel Forum
4th Gen Cab & Chassis Discussion of performance, powertrain, and non-powertrain on Cab & Chassis Trucks....NO ADVERTISING
post #1 of 2 (permalink) Old 06-22-2019, 10:45 AM Thread Starter
Anyone ever wire in a lightbar to turn on when the fogs do? So wiring it to the same switch as the OEM fogs, I've heard of it being able to be done. Any good info?
yosh30 is offline
post #2 of 2 (permalink) Old 06-22-2019, 07:52 PM
El Pozzinator's Avatar
Yes but with the exception that the fog switch doesnít actually send power to the bar, only to a relay which allows the bar to draw power direct from an auxiliary key-on hot terminal. Those light bars draw more juice than the fog circuit is expecting to see, so you could end up with an overloaded circuit making the computer (BCM?) freak out.
08 Resistol. Anarchy EFI, 5" TBE, Sinister coolant filter, Carbonite DP sensor, CSS -4" springs, reverse level, CalTracs, Amsoil bypass filter, Revmax VB/TCM, & a madly leaking radiator.
El Pozzinator is offline
