Uneven Ride Height - Dodge Cummins Diesel Forum
4th Gen Cab & Chassis Discussion of performance, powertrain, and non-powertrain on Cab & Chassis Trucks....NO ADVERTISING
post #1 of 6 (permalink) Old 04-14-2019, 04:10 PM Thread Starter
Uneven Ride Height
Hello, shortly after I purchased my truck in Aug 2017 (12 miles on the odometer) I took ride height measurements in order to setup my weight distribution hitch. I noticed that the passenger side fort was 5/8" lower than the driver side ride height. Now, I measured it after noticing that the right front seems to be sagging more and see that itis now 1 1/8" lower than the drivers side. Whats going on here? Rear ride height is within a 1/4" of each other. Stock suspension.
Thanks-
2017 RAM 2500 CTDCC 4x4 (Stock)
Raven_CTD is offline
post #2 of 6 (permalink) Old 04-14-2019, 06:43 PM
I'm assuming you were measuring from the hub? This makes me want to measure my '18. I've had this feeling walking up to the truck that it's leaning front passenger side as well. 7k miles on my truck and my big sits on the other side.
What option package do you have? I have snow plow springs, but there are 652 different springs from what I understand. I'd also recommend contacting the dealer to see if that's a warranty claim. That's a big difference side to side on a low miles truck.
Handshaking is offline
post #3 of 6 (permalink) Old 04-14-2019, 07:32 PM Thread Starter
I measured from the bottom of the tire to the top of the wheel well. Tire pressures are within 1psi of each other. No suspension options, stock tradesman. I missed this on the warranty claim, currently at 38K miles. I didn't know if others were having a similar issue, maybe a spring issue from the factory???
Measurements:
Driver side: 40 7/8"
Passenger side: 39 3/4"
Thx
post #4 of 6 (permalink) Old 04-16-2019, 05:58 PM
Lins's Avatar
Caster adjustment out of whack? They shouldn't be more than one notch different in adjustment. You might get more responses outside of the C&C section for a 2500.
Lins is offline
post #5 of 6 (permalink) Old 04-20-2019, 05:52 PM Thread Starter
Thanks Lins! Bingo! Apparently when the local Ram dealership performed the alignment last month they left the caster adjustment bolt loose resulting in it rotating and causing the difference in ride height. I took it back in today and they realigned it (free) and everything looks good. After 30+ years of driving, thats a new one on me. Thanks again
post #6 of 6 (permalink) Old 04-20-2019, 09:21 PM
Lins's Avatar
Glad it was an easy fix
Lins is offline
Similar Threads
ICON 2014-UP RAM 2500 4WD 2.5" Suspension System - Stage 1 (Air Ride) Dudes Diesel Performance Dude's Diesel Performance 0 11-08-2017 06:27 PM
Air Level Suspension Questions AZhunter79 2013-2018 General Discussion 23 10-30-2017 03:29 PM
Leveling or Factory ride height? work truck Frac_it 2013-2018 General Discussion 26 06-12-2017 12:50 PM
Stock ride height front and back boarder923 94-98 Non-Powertrain 2 06-11-2013 06:07 PM
285/75-17 on H2 Rims - Will they fit on stock ride height? cbsnow31 94-98 Non-Powertrain 4 11-07-2012 08:54 AM
