Help 2013 rear hub torque - Dodge Cummins Diesel Forum
4th Gen Cab & Chassis Discussion of performance, powertrain, and non-powertrain on Cab & Chassis Trucks....NO ADVERTISING
post #1 of 5 (permalink) Old 03-23-2019, 05:24 PM Thread Starter
13RAM2500SLT6.7Evin's Avatar
Hey everybody. Im doing my rear bearings & seals and need hub torque for proper reassembly. I cany seem to find a straight answer online. Any help is appreciated. 20
2013 RAM 2500HD SLT Cummins 6.7 4wd
Sent from my SM-N950U using Tapatalk
13RAM2500SLT6.7Evin is offline
post #2 of 5 (permalink) Old 03-23-2019, 06:55 PM
08 Cummins
KhakiCummins's Avatar
This is from the 2008 Service Manual but all AAM 11.5 axles should be the same.
INSTALLATION
1. Install outer hub bearing cup with Installer 8961
and Handle C-4171.
2. Install inner hub bearing cup with Installer 8153
and Handle C-4171.
3. Pack bearings with the appropriate wheel bearing
grease.
4. Install rear bearing and install new grease seal
with Instalter 8963 and Handle C-4171.
5. Slide hub on the axle tube and install front bearing
into the hUb.
6. Install hub bearing nut with Socket 8954 (1) and
tighten with torque wrench (2) to 30 Nm (22 ft.
Ibs.) while rotating the hUb.
7. Back off nut about 30 and align next hub nut key
slot with axle tube key slot and install locking key.
NOTE: End play should be 0.025 .. 0.25 mm (0.01-0.001 in.)
8. Install retainer ring (1) with ring end in the key slot
(2).
9. Install new axle shaft gasket and install the axle
shaft.
Duane
2008 Ram 3500 QuadCab
KhakiCummins is offline
The Following User Says Thank You to KhakiCummins For This Useful Post:
13RAM2500SLT6.7Evin (03-29-2019)
post #3 of 5 (permalink) Old 03-29-2019, 12:21 PM Thread Starter
Its definitely a close description but i was doing rear on a 2013 so no grease because it gets lube from diff. Most steps are correct tho. Thanks.
Here are the pics for bearing, wheel seals axle flange gasket, hub tool, and installation instructions specified for the job i did.
Hope this helps someone else
4th gen 2013 RAM 2500HD SLT 4wd 6.7
post #4 of 5 (permalink) Old 03-29-2019, 05:15 PM
08 Cummins
You must have missed step 3. Pack bearings with appropriate wheel bearing grease. You still use wheel bearing grease on these rear ends even though they will get some lube from the differential.
Duane
post #5 of 5 (permalink) Old 04-01-2019, 09:14 AM
x2 on packing the bearing, they’re not in a full oil bath. When I replaced my leaky inner seal I wasn’t able to get the hub gasket loacal, rtv works just as well FYI
WhiskeyThrottle is offline
Similar Threads
I learned a new dealer trick today, dont trust the window sticker #s!! kalantar 2013-2018 General Discussion 15 04-18-2017 03:22 PM
Rear Axle difference 2012 vs. 2013 Ram 3500 SRW? wrasse 2010-2012 General Discussion 18 04-18-2014 04:08 AM
2013 Ram 3500 4WD Crew Cab Laramie Diesel DRW tnpete 2013-2018 General Discussion 5 11-16-2013 02:32 PM
Defrost on power sliding rear window for 2013? frobozz 2013-2018 General Discussion 69 08-09-2013 08:33 AM
What broke on your truck and when? cummins939 3rd Gen. Powertrain 46 03-12-2013 09:13 PM
