Dealing with the huge Aisin 2nd to 3rd gear spacing - Dodge Cummins Diesel Forum
4th Gen Cab & Chassis Discussion of performance, powertrain, and non-powertrain on Cab & Chassis Trucks....NO ADVERTISING
post #1 of 5 (permalink) Old 02-16-2019, 09:38 AM Thread Starter
Sledgehammer1's Avatar
Just curious what others do that find this annoying.
When using Tow haul , the torque converter locks in 2nd gear. Unless I hold the pedal nearly to the floor, the 2nd to 3rd gear shift happens way too soon for the huge space. Just accelerating normal with weight in T/H, the rpms will drop to about 1300rpm when this 2-3 shift happens. Not an issue towing light, but put any decent load (10k+) behind it and combined with any grade and its near useless! I have had it shift to 3rd, quickly figure out its falling on its face then shift right back to 2nd. Or it will lug at 1300rpm barely moving until the grade flatens out enough to gain momentum. Its stupid!! I do have 3.73 and im sure this isnt as noticed in 4.10 trucks, if it is at all. I love this truck and everything about the Aisin AS69RC, but this is the most annoying thing I've ever encountered towing with any of the big 3.
So im stuck either not using t/h so the converter doesnt lock in 2nd and the rpms stay up for the 3rd gear shift....which i dont really like but it does work.
Or using the ERS buttons to hold 2nd gear until about 2200-2300rpm. This is what I usually do. Just kinda hate using the bottons when i dont have to in the other non Aisin trucks.
Or hold it to the floor. Not a fan of this but it does work. Just seems like a lot of unnecessary wear and i dont like beating on my trucks.
Just curious what others do or if im the only one that finds this an issue.
2013 3500 Laramie 68rfe 3.73 HPP
2018 3500 Tradesman Aisin 3.73 C&C CM TM deluxe bed
Sledgehammer1 is offline
post #2 of 5 (permalink) Old 02-17-2019, 12:39 AM
Bedlam's Avatar
It's not as noticeable with the 4.44 final ratios and I'm sure it would be even better with the 4.88's if you were willing to give top speed.
Bedlam is offline
post #3 of 5 (permalink) Old 02-17-2019, 01:56 PM Thread Starter
I figured it would be less noticeable with the numerically higher gear ratios. Im also not sure how much the lower power of the C&C plays into this as Ive not driven a pickup version with the Aisin. There is a very noticeable power difference between my 68rfe pickup and this C&C though so im sure that effects it some. Had I towed with an Aisin C&C before, I would have definitely gotten the 4.10s at minimum.
post #4 of 5 (permalink) Old 02-17-2019, 02:35 PM
Bedlam's Avatar
I went from an older pickup to my chassis cab and did not lose/gain horsepower but did gain an additional gear and more torque. I also went from 3.73 gearing to 4.44 but in a truck weighing 3000 lbs more when empty. I think getting 4.44’s allows you to use all six speeds more often and puts the gear spread closer together so you don’t feel that larger gap as much.
Bedlam is offline
post #5 of 5 (permalink) Old 04-04-2019, 04:42 PM
With 4.88's I never notice this. Even towing 41,000 lbs in the mountains. I put a throttle booster on it and it made it more responsive. pLus I'm deleted.
2013 Ram 5500 SRW pickup auto 4x4, 4.88 gears, Kelderman air suspension, extreme outback compressor, rickson wheels, toyo 285/70/19.5 M608Z, transfer flow 40g tank, blue lake front and rear winch bumpers, milemarker hydro winch. EFI by HPP, Flo pro muffler, 36x13.5x19.5 super swamper IROK's. The ramman locking hubs, pacbrake LoadLeash, arp 425's,
ridofpwrstroke is offline
Similar Threads
New to Me 2015... What's Going On With My 2nd -3rd Gear Aisin Shifts tlukasavige172 4th Gen Powertrain 2 11-08-2017 05:06 AM
2014 3500 Differential Oil Capacity mt1949 2013-2018 General Discussion 6 02-28-2016 12:00 AM
Front and rear diff fluids kev2500 2010-2012 General Discussion 5 02-08-2011 06:34 PM
Timing/power steering gear whine? Bondo07 89-93 Powertrain 11 01-30-2011 09:05 PM
Trans issue (No O/D or Reverse) justacummins 98.5-02 Powertrain 8 01-24-2011 02:23 PM
