First 60K Servicing Of The AS69RC In My 2018 RAM 4500 Cab & Chassis - Page 6 - Dodge Cummins Diesel Forum
4th Gen Cab & Chassis Discussion of performance, powertrain, and non-powertrain on Cab & Chassis Trucks....NO ADVERTISING
 95Likes
post #61 of 72 (permalink) Old 04-09-2019, 11:57 AM
Jimmy N.'s Avatar
I merely wanted to test your level of senility, Brockman. I knew you were wandering into a Lowe's...well, at least you said you were.
But, it sounds like your mental status is better than what your wife claims, so all is good. For now.
Jimmy N. is online now
post #62 of 72 (permalink) Old 04-09-2019, 03:48 PM
BrianF's Avatar
I am sure this is what really happened.
gsbrockman and Jimmy N. like this.
2017 Ram 3500 Megacab, SLT, True Blue, SRW, CTD, AS69RC. Ubique
BrianF is offline
The Following User Says Thank You to BrianF For This Useful Post:
Jimmy N. (04-09-2019)
post #63 of 72 (permalink) Old 08-09-2019, 11:59 PM Thread Starter
White Lightning
gsbrockman's Avatar
iTrader Score: 28 reviews
Tonight I rolled in from a 686 mile round trip run delivering two gooseneck trailers from Somerset, KY to the retail store in Marietta, GA. White Lightning is at 153,632 miles, so its just a little overdue for the 30k drain and fill.
When I got home, I left the truck idling, kissed the wife and daughter, changed into some work clothes, and gathered up my drain pan and wrenches. Within 45 seconds of shutting off the truck, my drain and fill was underway.
Ill leave it draining overnight, although on most of my previous drain and fills, very little additional fluid came out after the :30 mark. When dropping the sump filter, more fluid drains for an extended time whenever the sump filter is out.
Due to the drain plug location of the PML pan, it will be interesting to see if I get the P0868 code, like I normally always got with just the sump filter replacement.
Since this is my first drain and fill with the new pan, I will need to measure the fluid drained. Im expecting to replace between 10.0 to 10.5 quarts or so.
BrianF and Jimmy N. like this.
2018 RAM 4500 Chassis Tradesman Crew Cab 60 C/A 4WD, 6.7L Cummins, AISIN AS69RC Transmission, 4.10 Axle Ratio, Chrome Appearance Group, Keyless Entry, Fog Lamps, Chrome Tubular Steps, 52+22 gallon fuel tanks, 5.0 Radio, Single Disc CD Player, 225/70R19.5 Firestone FD690s, Aluminum Wheels, Parkview Backup Camera, Trailer Brake Controller. Equipped with a CM SK Series flatbed w/B&W Turnover Ball. Purchased new April 23, 2018. Currently : 196,704 miles and 3,437 hours as of January 27th, 2020 (Average Miles Per Hour = 57.2)
gsbrockman is offline
The Following User Says Thank You to gsbrockman For This Useful Post:
Electrojake (08-10-2019)
post #64 of 72 (permalink) Old 08-10-2019, 12:10 AM
BrianF's Avatar
Looks good under there! Clean and where is the rust? Don't you guys get rust down there!
BrianF is offline
post #65 of 72 (permalink) Old 08-10-2019, 12:26 PM Thread Starter
White Lightning
gsbrockman's Avatar
Well....the results are in.
Looks like I was off a decent amount in regards to the amount drained. According to my empty containers, I drained 12.0 quarts of old Mobil 3309.
Attached are pictures of the magnetic drain plug and my 3 (1) gallon containers of verified Mobil 3309 drained. Yeah.....it was just a partial / half-azzzzzzzzed drain, but my AS69RC thanked me for it.
Additionally......I feel the additional fluid drained is due to the pan design. The OEM pan is angled, keeping the sump filter submerged. The new pan is more flat, and deeper, allowing the sump filter to drain freely after the drain plug is removed.
With that being said....PML touts a 3 to 4 quart increase over the stock pan.
On my OVERNIGHT drain, I will be seeing a 5 quart increase.
ID:	853835   Click image for larger version
post #66 of 72 (permalink) Old 08-10-2019, 12:52 PM
P2609 Fanatic
Electrojake's Avatar
Thank you @gsbrockman for the great posts! This is exactly the sort of "bolt-on" stuff I love to do to my truck.
That pan looks great and will probably be my next expenditure!
I just hope it turns out better than the Mag-Hitec rear diff pan I proudly installed (and then un-installed) shortly thereafter.
My truck July 2017. . .
My truck July 2018...
My wallet right now. . .
As I've learned; The devil is in the details,
(but alas, with each costly blunder I grow a tad wiser).
Thanks again GSB, your posts were great!
-Ej-
2016 Longhorn 3500 4x4 short-bed in Pearl White.
Cummins HO, AISIN, CrewCab, SRW, Ride-Rite remote rear air suspension, Edge CTS2, plus the typical after-market bolt-on crap.
> Reduced current grid heater mod w/all emissions intact.<
*Hauling a 2017 Northstar Arrow-U.
Electrojake is online now
post #67 of 72 (permalink) Old 08-10-2019, 03:25 PM
Jimmy N.'s Avatar
Brockman, did you borrow my diff plug for that photo?
Actually, there was very little on it when I checked before this trip. I'll pull the cover when back home and see how much the external magnet it put on the cover has picked up.
Plus, by pulling the cover I can get rid of any chunks too large for the magnets to hold.
post #68 of 72 (permalink) Old 08-10-2019, 05:28 PM Thread Starter
White Lightning
gsbrockman's Avatar
Nope......I swear thats my transmission pan drain plug.
Where are you off to now? Is CA calling you home?
post #69 of 72 (permalink) Old 08-10-2019, 07:16 PM
Jimmy N.'s Avatar
Okay, good, I really didn't want to see that much crap on mine again. But now I need to get a mag plug on my tranny pan...that looked, umm...not perfect for piece of mind.
No, I'll lazy out and put a couple of strong magnets on my stock pan instead. Less work, same result...maybe.
Yep, at an event in CA after a 10 year absence. Based on what people here are saying (not a true cross section of CA voters in general), this state will lose another several thousand citizens real soon.
gsbrockman likes this.
post #70 of 72 (permalink) Old 08-16-2019, 07:25 PM
P2609 Fanatic
This service is due at 60k miles?
Lets see...
That means at this rate my 2016 will be due in about another 8 years.
Just saying
-Ej-
post #71 of 72 (permalink) Old 08-16-2019, 11:40 PM Thread Starter
White Lightning
gsbrockman's Avatar
Let’s see...
Just saying
-Ej-
Define “this”......
  • Drain and fill -OR-
  • Sump filter and fluid change
post #72 of 72 (permalink) Old 12-30-2019, 06:49 PM Thread Starter
White Lightning
gsbrockman's Avatar
I recently changed the fluid and sump filter in the 2018 RAM 4500 Cab & Chassis. Since Id never hacked apart one of the AS69RC transmission sump filters....I thought Id go ahead and give it a try.
Not sure of the manufacturing process of this filter, but the case is tough and almost impossible to pry apart. I ended up using a thin cutoff wheel and just buzzed it in half. The filter media is really sandwiched in there as well.
Attached are a few pictures of said hacking.....
ID:	864069   Click image for larger version
ID:	864071   Click image for larger version
ID:	864073   Click image for larger version
Slats Extend likes this.
biofumes (02-10-2020)
