Dodge Cummins Diesel Forum - View Single Post - Broken Input Shaft.... Can I Replace it with..?
post #2 of (permalink) Old 11-26-2011, 02:58 AM
5.9sledhead
I have a1 1/4 shaft id sell ya. You need the 13/8 retainer too with the bigger shaft. Umm as far as the pressure plate idk for sure if the bolt holes line up it may work but the pressure is prob way less on a stock clutch plate than a double disc. So if it doesn't put enough pressure on you have the equivalent of a stock clutch again but with two plates to wear out.
5.9sledhead is offline
