EDIT Code U010C HELP!! Getting code after putting DPF back on
Had to re-install everything a couple of days ago so I could get my E test done. In the process I forgot to attach the plug under the EGR and drove that way for about 100 miles. The CE was on but I thought I read that it took a few key turns to get it back to normal. So today I attached the plug and cleared all the codes but one, PC10C. I did a search and found no real help.
So does anyone know what the deal is with this code? I have two days left till I have to get my E test and new tags for my plate.
You can call me at 3o3 ..829 + o7o3 I need help and so does my truck.
update, I took the software to catcher 2 to see what would happen and the CE went away. So I took it back to stock software and the CE came back as did code PC10C (no it is not a typo)
Then when I turned the key on and off to check codes I got P0700 and P2509. So what is the deal??
EDIT Smarty read the code wrong, the odometer read the code as U010C Fault code U010C-lost communication wih turbo charger. THe truck seems to drive fine but it does seem like it takes a few to spool up and get going. Now I can't really tell if that is how it is supposed to be since I have driven it on Catcher 5 since I got it. So again thanks for all of your help so far but still need some.
