Diy cup holder light - Dodge Cummins Diesel Forum
3rd Gen Tech Articles Tech Articles for the 5.9L 3rd Gen Dodge Cummins Diesel...NO ADVERTISING
post #1 of 12 (permalink) Old 03-23-2010, 03:48 PM Thread Starter
If your truck is like mine, you are hunting to find cup holder at night, this may be the way to go. My truck, by check at dealer by last 9 digits of VIN was NOT wired to accept a cup holder, therefore my truck was without. Some trucks are wired for it, but it is just simply not there. YOU MAY SEE SOME ADDITIONAL COMPONENTS REMOVED FROM MY DASH. IGNORE AND ONLY REMOVE WHAT IS SUGGESTED. I HAVE OTHER PROJECTS I AM DOING AS WELL.
Step One:
get you light Assy DODGE PART # 55361226AA $23.16 + Tax PLUS 2 scotch
lock connectors
Step 2 Remove trim piece by removing one screw locate above trash bag hook, pull on hook and work your way around the trim piece.
It should nw look like this
Disconnect all electrical connections from the heater controls, cig outlet, any other remaining and totally get this trim piece out of your way. With this out of the way you MAY find the connector to hook light up to in the location I am pointing to.
If not then your truck is like mine and you need to tag into some wires.
Here is the location of where your new light will live, you will want to remove some of the screws on the bottom trim piece to pull it rearward enough to slide it into its location.
Now its in place. If you were lucky enough to have the plug, plug it in and your done. If your truck was like mine follow below. The smaller of the two plugs you removed from manual heater control (see pic) Locate orange wire with yellow tracer. This goes to the orange wire with grey tracer coming from light assy.
Next locate white wire with black tracer. This goes to the Violet wire with black tracer from light assy. BOTH THESE WIRES ARE IN SMALL CONNECTOR GOING TO HEATER CONTROL.
You should have your scotch locks and wind up with something like this. I simply took side cuts and cut the plug from the light assy.
At this point you are finished with the install. Turn your park lights on. Verify your scotch locks have made the proper connection. Run dimmer wheel up and down on headlight switch to verify proper working order. You can visibly see the bulb to verify this from looking up.
Enjoy not having to fumble and spill your drink.
2007 Ram 3500 Dually Bone Stock 5.9 Auto Long Bed
DOT2340390 MC799200
shakn03 is offline
The Following 7 Users Say Thank You to shakn03 For This Useful Post:
ddeater (09-22-2012), ericalbert (11-16-2013), kenny110482 (03-23-2010), RonLynnJr (03-25-2012), SCdiesel (03-23-2010), T-Rob's Cummins (03-23-2010), VanillaGorilla (09-10-2011)
post #2 of 12 (permalink) Old 03-23-2010, 06:39 PM
kenny110482's Avatar
Great job on the write up
2015 3500 Mega Cab Laramie DRW
kenny110482 is offline
post #3 of 12 (permalink) Old 03-23-2010, 07:15 PM
Cowbizzoy's Avatar
niiiiice! thanks for the write up....pretty lame they don't all have that light installed........
2003 2500 CTD Auto QuadCab, AFE stg II intake, smarty, 5" exhaust, Clarion dvd, Boston Acoustics speakers, Autometer Cobalts a couple ISSPRO EV2's, Espar D5.
Cowbizzoy is offline
post #4 of 12 (permalink) Old 03-23-2010, 07:32 PM Thread Starter
I completly agree. But like my truck it was not even a option when designed. Anyway this is ashtray/cup holder. Ill take some pics tonight after dark. Itll be nice to see before and after.
DOT2340390 MC799200
shakn03 is offline
The Following User Says Thank You to shakn03 For This Useful Post:
Ccncomm (02-11-2017)
post #5 of 12 (permalink) Old 03-23-2010, 08:00 PM
Dodgezilla's Avatar
iTrader Score: 18 reviews
Very thorough writeup. Good job on that. Unfortunately I already have the light so this did not help me...
Good Job!
04 Ram 2500,Green/Silver-305/555. Sold!
2018 Dodge Ram 3500 Tradesman
Dodgezilla is offline
post #6 of 12 (permalink) Old 03-23-2010, 09:34 PM Thread Starter
Good Job!
Man you must have got a Tuesday, Wednesday, or Thursday truck. These monday and friday trucks just didnt get one...
DOT2340390 MC799200
shakn03 is offline
post #7 of 12 (permalink) Old 03-23-2010, 09:56 PM
RedCummins04's Avatar
Any photos yet?
2004 Q/C SB 4x4 6 speed, FMW467, Stainless Diesel, Innovative UDC, SB 3600, Airdog 200, 22's, US Gear EB, ARP's, Exergy 100% over, Motorsport duals, Turbosmart.
RedCummins04 is offline
post #8 of 12 (permalink) Old 03-23-2010, 10:03 PM Thread Starter
Originally Posted by RedCummins04 View Post
Any photos yet?
Cup holder lights off
Lights on
Will it blind you NO. Does it let you see the cup holders??? Sure does. I am very glad I did this. Driving with my knee and feeling with one hand for the cup holder with my coffee in the other hand got real old real quick...
DOT2340390 MC799200
shakn03 is offline
post #9 of 12 (permalink) Old 03-23-2010, 11:38 PM
DELETE YOUR TURBO!!!!!
WATERLOO49's Avatar
iTrader Score: 4 reviews
great write up but theres no way i would ever put scotch locks on my truck but i am going to look in to dooing this on my truck. thanks for the info
POWER TRIP Pulling Team
Sponsored by Banghart Diesel & Performance and Big Tints.
2015 Nebraska Bush Points Champion
WATERLOO49 is offline
post #10 of 12 (permalink) Old 03-23-2010, 11:45 PM Thread Starter
I relate to the scotch locks. They for me are something I would rather not use, however in certain places, like inside low amp always clean enviroment situations like this I find them really handy. Ultimatly the connection method is your choice. I choose scotch locks because it was something everyone could have quick access to VS cut splice, solder, shrink wrap method.
DOT2340390 MC799200
shakn03 is offline
post #11 of 12 (permalink) Old 03-24-2010, 12:03 PM
Awesome thanks!
post #12 of 12 (permalink) Old 03-24-2010, 10:06 PM
VANNY's Avatar
just a heads up for the 6 spd guys. my truck came with the cup holder light and it works great but with the boot at the bottom of the shifter, the light doesnt light up the cup holders just the back of the shifter boot.
04 2500 H.O. 6spd 4x4 qclb-he351,fass,bop,4"ext,aem intake,24v horn,heater delete,edge ez,4.5"lift,air bags,35x12.5 trail grappler
NOTHING RUNS LIKE A DEERE WITH A CAT ON ITS TAIL
VANNY is offline
