Boost Guage Installation - Dodge Cummins Diesel Forum
3rd Gen Tech Articles Tech Articles for the 5.9L 3rd Gen Dodge Cummins Diesel...NO ADVERTISING
post #1 of 13 (permalink) Old 02-17-2010, 07:30 PM Thread Starter
where does everyone with a boost gauge drill into the intake manifold to hook it up, just throw some ideas out there please
04 3500 single wheel rear end, 6sp, four wheel drive, 60 gal aux fuel tank, looking to take it to 600hp and still have it as a daily driver, its hooked to a 30000lbs trailer 5 days a week. ((((currently not running looking for 12 valve to put in it))))
bloughc is offline
post #2 of 13 (permalink) Old 02-17-2010, 07:45 PM
2007LaramieMGM's Avatar
Im gonna be using one of these pretty soon. You just remove one of the bolts holding the intake to the cylinder head and replace it with this bolt. Boost Bolt
2007 Laramie 2500 QCSB 4x4 48re: GDP MK-2 w/Donaldson filter, FBD 5" TBE, Donaldson 40" muffler, Quadzilla Boost Fooler, Cool Blue Hose, Mopar Air Filter, DTT Triple Disk TC, DTT Custom VB. SMARTY coming soon.......
2007LaramieMGM is offline
post #3 of 13 (permalink) Old 02-17-2010, 07:49 PM
mainer's Avatar
right there
04.5 2500 5.9, 4x4, Turbo silencer gone, Amsoil 6" filter, Smarty, 5" TBE, Isspro boost, pryo,and trans temp, Quad Rail pressure gauge,Nitto Trail Grapplers, Goerend Trans- SOLD
mainer is offline
The Following User Says Thank You to mainer For This Useful Post:
jforsyth (03-20-2013)
post #4 of 13 (permalink) Old 02-17-2010, 11:55 PM
tryNto's Avatar
If your OK with drilling and tapping, do like above..
If not, get the boost bolt, takes about 5 min. to install.
'03 QCLB 2500 305/555 NV5600 w/ FastCoolers 3.73 4x4, Color match Lear Topper.
Smarty S-06 PoD, Edge CTS for Gauges, DPP Cool Tube w/ OEM AF Box, Baldwin PF7977, GDP MK-2 FF Kit, Pusher Intake Horn, Adj. Boost Elbow @ 30psi, OEM Fan Clutch Delete/Mod, Steering Box Brace, On-Board Air w/Horns
tryNto is offline
post #5 of 13 (permalink) Old 03-17-2010, 10:44 PM
Hide your cats!
mstoaks's Avatar
does the male fitting from the boost bolt come with the boost bolt
2005 white auto, thanks to stoakenstine creations, 23 Diesel,smarty so6 Ats 5-star, 5" TBE to 6" stack, bhaf, GDP air boss, full triple pod, gdp 2 mic. edge ez 547hp 1078ft.lbs
mstoaks is offline
post #6 of 13 (permalink) Old 03-18-2010, 02:53 AM
tryNto's Avatar
Do you mean the compression fitting for the tube?
No that comes with the Gauge/tube kit...
tryNto is offline
post #7 of 13 (permalink) Old 03-18-2010, 07:10 AM
Hide your cats!
mstoaks's Avatar
i got the autometer complete kit from xdp and i couldnt even tap the manifold if i wanted to, it only has a t fitting, ill be calling them today ot fighure out whats up, thanks
mstoaks is offline
post #8 of 13 (permalink) Old 03-18-2010, 10:02 AM
dieseljay74's Avatar
iTrader Score: 4 reviews
I tapped the intake manifold like above
'03 2500 CTD
RAPTOR RP100 W/GDP 2 MICRON INLINE KIT
6" TGC LIFT
37" MT/R Kevlars on XD Enduros
DIABLOSPORT PREDATOR w/AEM BRUTE FORCE CAI
BANKS HIGH RAM & 5" TBE w/30" FTE RESONATOR
GREAT LAKES CUMMINS CREW MEMBER
[SIGPIC][/SIGPIC]
dieseljay74 is offline
post #9 of 13 (permalink) Old 03-18-2010, 10:37 AM
Hide your cats!
mstoaks's Avatar
If I got all the fitting then I would have tapped the horn but not my case
mstoaks is offline
post #10 of 13 (permalink) Old 03-18-2010, 12:19 PM
silver5.9cummins's Avatar
Is the boost bolt accurate?
2005 Ram 3500 Crew Cab 4x4 Dually 2" coil spacers, Smarty, AEM Brute Force intake, 4" down pipe into 5" straight pipe into 8" mitre cut black stainless stacks
silver5.9cummins is offline
post #11 of 13 (permalink) Old 03-18-2010, 01:43 PM
SEAN06's Avatar
it is on mine,thats what i used
SEAN06 is offline
The Following User Says Thank You to SEAN06 For This Useful Post:
silver5.9cummins (03-18-2010)
post #12 of 13 (permalink) Old 03-18-2010, 06:22 PM
tryNto's Avatar
No difference between the Boost Bolt and the Intake Horn as far as I saw...
I've had it both spots...
tryNto is offline
The Following User Says Thank You to tryNto For This Useful Post:
Romeo cummins (10-14-2014)
