Coolant flush on a 3rd Gen. - Dodge Cummins Diesel Forum
3rd Gen Tech Articles Tech Articles for the 5.9L 3rd Gen Dodge Cummins Diesel...NO ADVERTISING
 3Likes
post #1 of 6 (permalink) Old 12-13-2009, 11:21 AM Thread Starter
COFFMAN CUSTOMS
AH64ID's Avatar
This is a pretty simple maintenance procedure, but I thought I would throw my .02 out here for everyone to read.
First off the service manual has the procedure, and it really is quite simple.
Originally Posted by 2005 Service Manual
DRAINING COOLING SYSTEM - 5.9L DIESEL ENGINE
WARNING: DO NOT REMOVE THE CYLINDER BLOCK DRAIN PLUGS OR LOOSEN THE RADIATOR DRAIN
PLUG WITH SYSTEM HOT AND UNDER PRESSURE. SERIOUS BURNS FROM COOLANT CAN OCCUR.
DO NOT WASTE reusable coolant. If the solution is clean, drain the coolant into a clean container for reuse.
1. Start the engine and place the heater control temperature selector in the Full-On position.
2. Turn the ignition off.
3. Do not remove radiator cap when draining coolant from reserve/overflow tank. Open radiator drain plug and
when tank is empty, remove radiator cap. If the coolant reserve/overflow tank does not drain, (Refer to 7 -
COOLING - DIAGNOSIS AND TESTING). The coolant need not be removed from tank unless the system is
being refilled with fresh mixture.
4. Remove radiator pressure cap.
REFILLING COOLING SYSTEM - 5.9L DIESEL ENGINE
Clean cooling system prior to refilling (Refer to 7 - COOLING - STANDARD PROCEDURE).
1. Close radiator drain plug.
CAUTION: Due to the use of the one-way check valve, the engine must not be operating when refilling the
cooling system.
NOTE: The diesel engine is equipped with two one-way check valves (jiggle pins). The check valves are
used as a servicing feature and will vent air when the system is being filled. Water pressure (or flow) will
hold the valves closed.
2. Fill the cooling system with a 50/50 mixture of water and antifreeze.
3. Fill coolant reserve/overflow tank to the FULL mark.
4. Start and operate engine until thermostat opens. Upper radiator hose should be warm to touch.
5. If necessary, add 50/50 water and antifreeze mixture to the coolant reserve/overflow tank to maintain coolant
level. This level should be between the ADD and FULL marks. The level in the reserve/overflow tank may drop
below the ADD mark after three or four warm-up and cool-down cycles.
In addition to the coolant flush I changed the thermostat. That procedure can also be found in the service manual.
5.9L DIESEL ENGINE
WARNING: DO NOT LOOSEN THE RADIATOR
DRAIN WITH THE SYSTEM HOT AND PRESSURIZED.
SERIOUS BURNS FROM THE COOLANT
CAN OCCUR.
Do not waste reusable coolant. If the solution is clean,
1. Disconnect the battery negative cables.
2. Drain cooling system until coolant level is below
thermostat (Refer to 7 - COOLING - STANDARD
PROCEDURE).
DR/DH ENGINE 7 - 65
WARNING: CONSTANT TENSION HOSE CLAMPS
ARE USED ON MOST COOLING SYSTEM HOSES.
WHEN REMOVING OR INSTALLING, USE ONLY
TOOLS DESIGNED FOR SERVICING THIS TYPE OF
CLAMP, SUCH AS SPECIAL CLAMP TOOL (NUMBER
6094).
CAUTION: A number or letter is stamped into the
tongue of constant tension clamps. If replacement
is necessary, use only an original equipment
clamp with a matching number or letter.
3. Remove radiator hose clamp and hose from thermostat
housing (1).
4. Remove the three water outlet-to-cylinder head
bolts and remove the water outlet connector.
5. Clean the mating surfaces of the water outlet connector
and clean the thermostat seat groove at the
top of the thermostat housing.
5.9L DIESEL ENGINE
1. Inspect thermostat seal for cuts or nicks. Replace if
damaged.
2. Install the thermostat into the groove in the top of
the cylinder head (2).
3. Install the thermostat housing (1) and bolts. Tighten
the bolts to 10 Nm (89 in. lbs.) torque.
4. Install the radiator upper hose and clamp.
5. Fill the cooling system with coolant (Refer to 7 -
6. Connect the battery negative cables.
7. Start the engine and check for coolant leaks. Run
engine to check for proper thermostat operation.
I started off by simply draining the OE fluid into a bucket. It was still very red, no oil, or any contaminates that I could see. There was a little bit of some contaminate the showed up on the 3rd flush in the radiator, but looked liked what I have seen in every cooling system. On my 2nd flush the coolant was much warmer and now had a small oil film on the top. But my buckets were new and I attribute that to the new plastic and warm water, something to consider if you find the same conditions when you flush your system.
Since it was in the 20's and snowing yesterday I knew I would have a hard time making the coolant warm enough to open the thermostat to get a good flush, and removing the thermostat would cause a leak so I modified my OE thermostat. A freind of mine calls this a "Hawaii T-Stat".
So I drained the block/radiator 5 times. This may seem excessive, but consider this. A drain only gets about 4-5 gallons out, and its a 7.4 gallon system. So I wanted to ensure that I had as much of the old coolant out as possible.
What I would do is drain it, very slow about 30 minutes to drain, then fill it with distilled water, and start it. I would then top it off with the engine idling, put the pressure cap back on and bump the idle to 1100 and turn the EB on to get some heat. With my Hawaii T-stat and a 30ish degree garage (cant fit the truck in with the door closed) and the hood open the coolant would only get to 114*. I would let it get to 114* then turn the EB off and bump the idle to 1500 for a few minutes. Then shut it down, drain, and repeat.
This photo shows 1 gallon from each flush, with the full strength OE fluid on the left and an unopened gallon of water on the right. Drains 4 and 5 were identical in color, so I assumed that was about my point of diminishing returns.
For coolant I chose Zerex G-05, its HOAT and the factory fill. HOAT coolant is very difficult to find, and HOAT is not compatible with non-HOAT. I think I paid about $11/gal for it at NAPA. (Even thou its the OEM fluid, its not pink it's a yellow, which is really hard to see in the overflow tank)
Since its a 7.4 gallon system and only 4-5 gallons drain you MUST, I repeat MUST, use concentrated coolant, not a 50:50 pre-mix (even thou the service manual states 50:50 you don't want to do this, it will yeild you a 25-40% mix at most). You need to add 3.7 gallons of coolant to the system to have a 50:50 mix. First thing to do is to make 1.5 gallons of pre-mix, this is for the overflow tank. Fill the overflow tank to the FULL line and pour the rest of the 50:50 in the radiator. Now add the remaining 3 gallons to the radiator. Now, and only now, will you and any straight distilled water to the radiator. I was only able to get about .5gallons of distilled water in after the coolant, so even adding a gallon of distilled first will mess up your 50:50 desierd mix. Now start the enigne with the heater still on full and let it idle for a minute. Then add more distilled water to top it off. Repeat this once. Now you should be full enough that you won't pull your overflow reservoir below ADD.
Take it for a test drive, try to drive it a few miles after you have reached operating temp to get the coolant and water to properly mix throughout the block, radiator, and heater core. This was the hardest part for me, it was 19* outside, and there was 1-3" of snow on the roads. Even with my winter front fully closed I had to get up to 65-70 to get the T-stat to open and mix, then slow and accelerate again... But I got the t-stat to open 6-8 times and am confident I got a good mix.
I used 3.7 gallons of G-05 and approx 23 gallons of distilled water.
A little trick for pouring the coolant into smaller containers from the bucket. If you have ever put a funnel in a gallon container you know it bubbles and spills since the air cant escape. Try putting a toothpick in the opening of the container with the funnel, works great.
roaddog50 and CumminDreamz like this.
2018 Ram 3500 Laramie CC LB
6.7, Aisin, Auto-Level
AH64ID is offline
The Following 38 Users Say Thank You to AH64ID For This Useful Post:
98whitelightnin (02-20-2014), avvblanc01 (09-27-2015), Blue2003 (06-28-2010), chrisa70 (09-07-2014), CLEATUS (01-25-2010), commtrd (07-20-2013), Devilman (10-05-2011), Diesel_Nuts (12-13-2009), dmurdock (06-15-2010), Dodge Brother (12-31-2009), dodge3500 (05-01-2010), Doozy (10-19-2018), Dr.Dizzle (02-20-2010), Fanman43 (08-31-2018), Frisk151 (06-13-2015), jamesr (11-12-2010), jayhaitch (05-07-2010), KeaHiggins48 (05-20-2017), killerdodge1977 (03-27-2016), MATRIX (12-13-2009), MyMach5 (03-24-2011), Otto91 (07-08-2015), rat4791 (04-26-2011), roaddog50 (04-21-2016), Rocksolidcummins (02-20-2010), RollingCoal1983 (05-01-2014), rthouck (08-02-2012), scotchwhiskey (09-17-2011), slinenfelser (07-07-2016), slowmover (04-27-2015), smokeythedodge (06-30-2010), starfltcdrjr (12-13-2012), styler007 (01-13-2015), texasborn01 (08-03-2010), texasgreg (05-18-2016), turborep (01-23-2010), vf171 (01-08-2011), Whiskey_Z (02-24-2014)
post #2 of 6 (permalink) Old 12-13-2009, 12:32 PM
Cummins6speed's Avatar
What is the radiator pressure cap? It says remove radiator cap then says remove radiator pressure cap
My truck: 06 5.9 6-speed2/28/09-470hp/980tq Sold and missed
New 2014 Mineral Gray 68RFE - Current
Cummins6speed is offline
post #3 of 6 (permalink) Old 12-13-2009, 01:17 PM Thread Starter
COFFMAN CUSTOMS
AH64ID's Avatar
The pressure cap is the 16psi cap on the left hand side (looking towards engine) of the radiator. Its the same thing as the radiator cap.
AH64ID is offline
The Following 2 Users Say Thank You to AH64ID For This Useful Post:
AZCumminsD (04-05-2014), dalton06 (12-20-2010)
post #4 of 6 (permalink) Old 12-13-2009, 01:45 PM
That is nice I have been in the business for 40 years and never just rinsed a system or taken out a thermostat. If you are going to remove and replace the coolant, you might as well do a proper flush. I use Arm and Hammer washing Soda, and If oil in the system Dawn Dish washer fluid. Do the flush first with the Dawn in then after without it, mix the fluid in a pail, and transfer the fluid to another jug to fill the system. Cover the front with cardboard or plastic, The system must be full everything so when it warm up it will blow out coolant. Take it for a drive gently and get it warm for 10 minutes, bring it home and run it at high idle. Get everything ready to drain the system. Put it to idle for 1 minute, shut it down and immediately drain the system. Do the flushes with the heater flow on full flow no fan required, you have to do more than one flush, do it until it drains clean then do a couple of rinses, you have to get it hot in each cycle. When it rinses clean then do the thermostat if needed, Fill the system to the thermostat level, then assemble, Fill the system, If you know the system holds 5 gallons and you want 50% add the antifreeze and then the water leave the system a little low and then check it after you go on a road run to get the thermostat open and the system mixed for at least 20 minutes, then test and fill to level. I always go to 60% plus antifreeze. If you want Cummins makes a good product called "RESTORE". If you have access to air pressure, and a nozzle I take off the heater intake hose off the cylinder head, and blow air into it to blast out the sludge that will settle in the core, do it after the system has drained and you can see buy the fluid coming out if there is contamination, and you want to do it more than once. Works for me!
xltsp8 likes this.
JP 3 :Licenced HD mechanic for 35 years. RETIRED!
worked on engines all my life. Spent last 19 HAPPY years at Freightliner:
The Following 7 Users Say Thank You to [email protected] For This Useful Post:
bannagh (12-06-2010), commtrd (07-20-2013), flynn78us (07-30-2016), jmemmert (11-25-2013), roaddog50 (04-21-2016), scotchwhiskey (05-15-2011), Stevehh (11-16-2013)
post #5 of 6 (permalink) Old 12-13-2009, 01:55 PM
EAST TEXAS VP
Diesel_Nuts's Avatar
Good Info, as I will be Flushing my System and Installing a New T-Stat soon!!
Big Blue - SOLD....
Diesel_Nuts is offline
The Following User Says Thank You to Diesel_Nuts For This Useful Post:
crazylion62 (02-04-2015)
post #6 of 6 (permalink) Old 01-20-2010, 08:14 PM Thread Starter
COFFMAN CUSTOMS
AH64ID's Avatar
I have about 3K miles on this setup now. I know its winter, but the new coolant seems to transfer heat a bit better than the old coolant.. I will know for sure this summer.
AH64ID is offline
The Following 4 Users Say Thank You to AH64ID For This Useful Post:
alwaysdiesel (10-19-2014), cummins925 (07-29-2016), dcnichol (07-11-2017), toyota_mdt_tech (10-13-2016)
