Problems with new truck - Dodge Cummins Diesel Forum
post #1 of 16 (permalink) Old 09-18-2013, 10:03 PM Thread Starter
Just bought an 07 5.9. Have a few problems and wanted to get advice on it while I have a bit of a Grace period warranty. First off, I am pretty sure I have shuttle shift issues. The truck seems to shuttle shift sometimes from first to second, then also 2-3. It usually feels like it messes around with third until it finally shifts into overdrive. Can anyone post up the TSB for this if it applies to my year truck? Also, I noticed at idle that every few seconds the truck has a tiny surge in it. You can just barely feel a little shake intermittently. I have made sure the AC and all is off to make sure it is not that. I have a V2 with EFI and was able to test my balance rates. Everything was under 1.5 except for number 4. It was negative 2-4 depending on the load of the engine. Just in park it hovered around -2 and then when the AC kicked up it would start to climb towards -4. I didn't think about checking them in drive. Also, I was not able to select any transmission PID's in the scan program so I was not able to confirm the shifting issues but it definitely does not seem right. Does it not currently support checking current gear and TC status? Thanks in advance.
2017 Ram 2500 CCSB 4x4 Tradesman Auto
07keo02 is offline
post #2 of 16 (permalink) Old 09-18-2013, 10:29 PM
imoncall's Avatar
The tanny problems sound like just the standard ones, do a service/ band adjust and change the gov solenoid/transducer/output speed sensor.
2006 qclb 4x4 300,000km, low fuel pressure light,one piece drive shaft, gdp 2 micron filter,edge cts with pyro, EFI live by Anarchy, magnaflow 4"tbe , superior shift kit, home depot cai.
Sold: 1998.5 dodge qclb 4x4 24 valve
Sold: 1997 dodge reg lb 4x4 12valver
Sold: 1994 gmc 1500 4x4 6.5 diesel
Sold: 1990 gmc 1500 4x4 gas to 6.2 diesel conv
imoncall is offline
post #3 of 16 (permalink) Old 09-18-2013, 10:35 PM Thread Starter
Thanks. Do you think it is worth trying to get someone to look at it, pay the 100 dollar deductable, see if they actually find something etc. Or, just buy the correct parts now and have a good operating trans I know I did right?
07keo02 is offline
post #4 of 16 (permalink) Old 09-18-2013, 10:37 PM
imoncall's Avatar
Where is the warranty from? you cant trust to many places...
imoncall is offline
post #5 of 16 (permalink) Old 09-19-2013, 12:05 AM Thread Starter
It is through the independent dealer I bought it from. They told me get it to any ASE shop ASAP and they will get it straightened out. Still waiting on the email copy of exactly what it covers though. Is there one kit that gives me all of the mentioned updated parts? I have done some research on the issue and I've got the adjustment of the band figured out, seems easy enough.
07keo02 is offline
post #6 of 16 (permalink) Old 09-19-2013, 12:09 AM
imoncall's Avatar
no kit that i have seen, you can get the speed sensor from a parts store for 25 bucks. ebay has the bw solenoid and transducer for under 100 bucks all in 200 buck for the gov/transduc/speed sensor with fluid and filter.
imoncall is offline
post #7 of 16 (permalink) Old 09-19-2013, 12:44 AM Thread Starter
ok just want to make sure i'm clear. The governor and transducer is one part. Then the speed sensor another. All I need is those two parts and the front band adjustment correct?
07keo02 is offline
post #8 of 16 (permalink) Old 09-19-2013, 12:47 AM
imoncall's Avatar
The govenor solenoid and transduecer are 2 diff parts but sometimes sold together. Then u need speed senser and filter with gasket.
imoncall is offline
post #9 of 16 (permalink) Old 09-19-2013, 01:35 AM Thread Starter
Thanks for the help. I might just order those and not deal with the deductable. It sounds like this should get it shifting good.
07keo02 is offline
post #10 of 16 (permalink) Old 09-20-2013, 12:38 AM Thread Starter
Well the dealer is going to check it out on the 1st. My as well have the warranty pay for at least part of it.
07keo02 is offline
post #11 of 16 (permalink) Old 09-20-2013, 12:44 PM
Snakebite's Avatar
Location: Damascus, Orygun (For you East Coasters that can't pronounce it)
If the warranty does not cover the solenoid then step up and get the GM conversion.
DAP has them for $145 with free shipping. It is better than the factory solenoid. You'll have to get the transducer somewhere else, they don't have them.
Change the filter, adjust the bands, and it will be like new.
2007, Quad Cab, 5.9, Long Bed, 4X4 2500, SLT Big Horn, Edge w/Attitude, K&N Drop In, 285/70/17 Cooper Discoverer ATP, No Cat, Magnaflow, GM Solenoid Conversion, Lost Silencer Ring. (If found call me)
Snakebite is offline
post #12 of 16 (permalink) Old 09-20-2013, 01:29 PM Thread Starter
What about the BG solenoid in comparison to the GM conversion?
07keo02 is offline
