Dodge Cummins Diesel Forum
Dodge Cummins Diesel Forum (https://www.cumminsforum.com/forum/)
-   3rd Gen. Powertrain (https://www.cumminsforum.com/forum/3rd-gen-powertrain/)
-   -   2004.5 Dually With Blown Engine..... (https://www.cumminsforum.com/forum/3rd-gen-powertrain/562600-2004-5-dually-blown-engine.html)
Skag 01-05-2013 05:59 PM
Guys - I'm considering swapping my 1994 2500 4x4 for a friends 2004.5 4x4 crew cab dually with the six speed manual trans. I would have to throw in additional cash to close the deal. The 2004.5 has a giant hole in the block at #4. The rod is no longer on the crank. Truck has ~170K miles and never towed hard.
Is there an issue with the ISB 325's? Seems odd to me that he did not get a low perssure or overheat alarm. Just heard a clicking noise and then boom.
What's a beautiful 2004.5 crew cab 4x4 dually with a blown engine worth - he's asking 12K...? I plan on doing the engine work myself. Should I go for a 6.7 transplant?
Walk away??? Or go for it?.......... I'm in California so the 2004 requires smogging......
TJ_mopar 01-05-2013 06:09 PM
Give you and idea, I bought my truck for 15k with only 119,000 miles on it. So a blown engine for 12k might be a little high and you can add on 5000+ for a rebuilt engine, since that one is toast.
Sent from my iPhone using AutoGuide.com Free App
jerejoe 01-05-2013 07:11 PM
mine is a 05 with 70k with a blown motor and i paid 7k
Podiesel 01-05-2013 11:38 PM
Close to here there was a 2003 White Sport QC NV5600 6 speed, 4x4 dually with 93000 miles that the fellow was asking $16,000 for. Clean but needed a tail gate, bumper and right dually fender extension because it rolled down the fellows steep driveway and into some trees. On the plus side he was an avid diesel guy and had just done the ball joints, unit bearings and steering upgrade.
I would walk as $12K Is way too much with a blown engine. Well for the swap thing it's too hard to judge without seeing both the trucks.
:confused013:.
MoparProud 01-06-2013 01:42 AM
Too much. You're looking at at least 5k for a junkyard pullout
jerejoe 01-06-2013 03:21 PM
With those kind of miles 6-9k and I'm not sure I would pay 9
MowerMan6 01-06-2013 04:50 PM
I just bought my 05 with a blown motor. Truck has 152k on it. Good take out motor cost me close to 6k. Got that done and found the starter bad, multiple coolant and tranny line leaks and a blown tranny. I paid 10k for the truck and have close to 12k into bringing it back to life. Buyer beware, it can hurt the wallet.
rdefayette 01-06-2013 04:52 PM
comsidering a hemi (gasser) truck of that particular vintage would go for 11-13K and it would run, I'd be hard pressed to to give him anything over 7k.
Just forget the fact it WAS a diesel. Right now it's a rolling chassis with a 1k lb paperweight between the front tires.
7k for the truck-7k for a descent engine (can't even rebuild a ventilated block) 14k so farand we haven't even looked at labor/time for the install+who knows what else once you get it running.
BTW, so far as what he told you "Just heard a clicking noise and then boom." I kinda doubt that.
I've seen washed down cylinders, low/no oil pressure, bad injectors, etc. there are only a couple a things that'll hole a block.
A "clicking" noise then boom isn't one of 'em!
Usually it sounds like someone beating the h--l out of a 55 gallon drum with a sledgehammer then boom!
sikmusicfreak8 01-06-2013 07:30 PM
I bought last april an 05' Dually, 4x4, Laramie, with all service records from the original owner with a fresh trans (auto) for 14k. 12k is crazy, no way in hell.
MoparProud 01-06-2013 07:32 PM
My 03 just started ticking and about 10 seconds later went boom and I saw the rod and part of the cam and block bouncing down the road in my mirror. No warning...
I had just enough time to turn the radio down and go "what the hell is that?" before it hit the fan. Story doesn't seem far fetched.
Skag 01-21-2013 06:03 PM
Thanks guys. I walked away. Sticking with my 1994 12 valve. It rides like a covered wagon, but I don't have to take it to the smog police in California and it has never let me down. I was dreamin' about the nice spacious leather interior of that 2004.5. But you guys set me straight. Thank you.....
I'll spend some $ on my 1994 to make it nicer instead - paint and install air conditioning.
Cheers,
Craig
TJ_mopar 01-21-2013 06:48 PM
Cheers,
Craig
You can always look into dropping a newer leather interior in your truck while you are at it.
Powered by vBulletin® Copyright ©2000 - 2020, vBulletin Solutions, Inc.
User Alert System provided by Advanced User Tagging (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
vBulletin Security provided by vBSecurity v2.2.2 (Pro) - vBulletin Mods & Addons Copyright © 2020 DragonByte Technologies Ltd.
