P2149 resolution - Dodge Cummins Diesel Forum
post #1 of 46 (permalink) Old 05-19-2012, 11:29 PM Thread Starter
Diesel Junkie
Taquache's Avatar
iTrader Score: 6 reviews
P2149 resolution
brand new injector harness
brand new #5 injector (original ohmed incorrectly)
Bad injector re ohmed out side of truck I think its fine.
New injector ohmed after starting the truck didnt ohm the same as 4 & 6
I'm getting p2149 and it shuts down the Group B injectors 4,5,6
I can use some input and direction. I'm guessing its time to start ohming out the entire engine electrical harness
?##?%@%#@$?#?$?%?%$$?^#??#[email protected][email protected]#??$#@?$#@
'13 4WD 3500 Crew Cab Dually Chase Truck "Negrita"
'04 4WD 2500 Quad Cab Hemi Class 8 Baja Race Truck "El Ariete" - Hoss Outfitters, 6 Line Construction, Taquache Motorsports, EBC Brakes, Thuren Fabrication, Dodge Off Road, Finish Line Factory, Jiffy-Tite Motorsports, Raceline Wheels, Lubbock Bolt Bin
Taquache is offline
post #2 of 46 (permalink) Old 05-19-2012, 11:36 PM
CAPTAIN DILLIGAF
BEERPLAY's Avatar
MY MEGA DID THE SAME STINKIN THING BRYANT WAS A SMALL EXPOSURE ON HARNESS
BEERPLAY is offline
post #3 of 46 (permalink) Old 05-19-2012, 11:41 PM Thread Starter
Diesel Junkie
Taquache's Avatar
what part of the harness? was there like a rub causing a short?
Taquache is offline
post #4 of 46 (permalink) Old 05-19-2012, 11:47 PM
CAPTAIN DILLIGAF
BEERPLAY's Avatar
YESSIR IT WAS VERY SMALL I CLEANED ALL THE WIRES AND FELT IT ON THE BOTTOM MINE WAS DIRECTLY TO THE LEFT OF THE INTAKE HORN
U IN MIDLAND OR LUBBOCK
BEERPLAY is offline
post #5 of 46 (permalink) Old 05-19-2012, 11:58 PM Thread Starter
Diesel Junkie
Taquache's Avatar
I'm in Midland, was it on the harness that plugs into the injector/valve cover gasket?
Taquache is offline
post #6 of 46 (permalink) Old 05-20-2012, 10:26 AM Thread Starter
Diesel Junkie
Taquache's Avatar
Bump for some help. The truck has been down over a month
Taquache is offline
post #7 of 46 (permalink) Old 05-20-2012, 11:53 AM
Dr.Dizzle's Avatar
If only one injector or wire is shorted or open it will take out all injectors on that bank. The #1 #2 #3, injectors are bank one. Injectors 4,5,6 are the second bank. This could be a bad injector issue as well. Here is the diagnostic process used in order to determine the cause.
Possible Causes
OTHER DTC'S
HIGH SIDE DRIVER CIRCUIT OPEN
LOW SIDE DRIVER CIRCUIT OPEN
HIGH SIDE DRIVER SHORTED TO LOW SIDE DRIVER
HIGH SIDE DRIVERS SHORTED LOW
LOW SIDE DRIVER CIRCUIT SHORTED OTHER LOW SIDE DRIVER CIRCUIT
LOW SIDE DRIVERS SHORTED LOW
HIGH SIDE DRIVER SHORTED TO VOLTAGE
LOW SIDE DRIVER SHORTED TO VOLTAGE
LOW SIDE DRIVER CIRCUIT SHORTED IN INJECTOR HARNESS
INJECTOR
INJECTOR HARNESS
ECM
INTERMITTENT CONDITION
Always perform the Pre-Diagnostic Troubleshooting procedure before proceeding. (Refer to 9 - ENGINE - DIAGNOSIS AND TESTING)
Diagnostic Test
1. OTHER DTC'S
With the scan tool, read DTCs.
Do you have any combination of DTC's P0204, P0205, or P0206?
Yes
Repair other DTC's first.
Perform POWERTRAIN VERIFICATION TEST VER - 1 (DIESEL). (Refer to 8 - ELECTRICAL/ELECTRONIC CONTROL MODULES/ENGINE CONTROL MODULE - DIAGNOSIS AND TESTING)
No
Go To 2
2. HIGH SIDE DRIVER CIRCUIT OPEN
Turn the ignition off.
Disconnect the ECM harness connectors.
Disconnect the Injector 4-6 harness connector.
NOTE: Check connectors - Clean/repair as necessary.
Measure the resistance of the injector high side driver circuit between the Bank 2 high side driver circuit in the ECM harness connector and the high side driver circuit in the injector harness connectors for cylinders 4-6.
Is the resistance less than 10 Ohms?
Yes
Go To3
No
Repair the open high side driver circuit from ECM harness connector to the Injector harness connector.
3. LOW SIDE DRIVER CIRCUIT OPEN
Measure the resistance of the 4, 5, and 6 injector low side driver circuits between the ECM harness connector and the injector harness connectors.
Yes
Go To 4
No
Repair the open low side driver circuit.
4. HIGH SIDE DRIVER SHORTED TO LOW SIDE DRIVER
Measure the resistance between the Bank 2 high side driver circuit at the ECM harness connector and the low side driver circuit for injectors 4-6 at the ECM harness connector.
Is the resistance more than 100k Ohms?
Yes
Go To 5
No
Repair the High side circuit shorted to the low side circuit.
5. HIGH SIDE DRIVERS SHORTED LOW
Measure the resistance of the injector harness connector high side driver circuits to battery negative for injectors 4-6.
Yes
Go To 6
No
Repair the High side driver shorted low in the harness.
6. LOW SIDE DRIVERS SHORTED LOW
Measure the resistance of the injector harness connector Low side driver circuits to battery negative for injectors 4-6.
Yes
Go To 7
No
Repair the Low side driver shorted low in the harness.
7. HIGH SIDE DRIVER SHORTED TO VOLTAGE
Turn Ingition on, engine off.
Measure the voltage between the high side driver circuit in the engine harness and battery negative.
Is the voltage less than 1 volt?
Yes
Go To 8
No
Repair the high side driver shorted to voltage.
8. LOW SIDE DRIVER SHORTED TO VOLTAGE
Measure the voltage between the low side driver circuit in the engine harness and battery negative for cylinders 4-6.
Yes
Go To 9
No
Repair the low side driver shorted to voltage.
9. LOW SIDE DRIVER CIRCUIT SHORTED OTHER LOW SIDE DRIVER CIRCUIT
Measure the resistance of each of the Bank 2 low side driver circuit to all other Bank 2 low side driver circuits at the ECM harness connector.
Is the resistance greater than 100k ohms?
Yes
Go To 10
No
Repair Low side driver circuit shorted to other Low side driver circuit.
10. LOW SIDE DRIVER CIRCUIT SHORTED IN INJECTOR HARNESS
Reconnect the disconnected injector harness connector.
Measure the resistance of each of the Bank 2 low side driver circuit to all other Bank 2 low side driver circuit at the ECM harness connector.
Yes
Go To 11
No
Replace the injector harness.
11. INJECTOR CIRCUITS SHORTED INSIDE ENGINE
Measure the resistance of each injector from the through head connector.
NOTE: Be sure to zero the ohm meter prior to checking the injector circuit.
Is the resistance greater than zero and less than 1 ohm?
Yes
Go To 12
No
Go To 14
12. INJECTOR
Disconnect the pigtail nuts from injectors 4-6.
Measure the resistance between the solenoid posts of each injector.
Is the resistance less than 1 ohm and greater than 0 ohms?
Yes
Go To 13
No
Replace the fuel injector or injectors.
13. INJECTOR HARNESS
Measure resistance of each circuit in the injector harness from pigtail side to injector harness connector.
Is resistance above 1 ohm?
Yes
No
Refer to the INTERMITTENT CONDITION Symptom (Diagnostic Procedure). (Refer to 9 - ENGINE - DIAGNOSIS AND TESTING)
14. ECM
Reconnect all the injector pig tail harness connectors to the Injectors.
Reconnect the ECM harness connector.
Reconnect the Injector harness connector.
Start the engine.
Did the DTC return?
Yes
Replace and program the ECM in accordance with the Service Information.
No
Test Complete.
2003 - 2500 SLT 5.9 HO 4X4 Quad Cab Shortbed, 48RE, Garnet Red Pearl, Isspro, Carli Pintop Suspension, Carli Torsion Sway Bar,Carli Ball Joints, Carli Control Arms, Raptor 100, Toyo 285 75 18 Extreme and 14 Laramie 18"wheels
Dr.Dizzle is offline
The Following User Says Thank You to Dr.Dizzle For This Useful Post:
Rairegg (07-11-2018)
post #8 of 46 (permalink) Old 05-20-2012, 12:33 PM Thread Starter
Diesel Junkie
Taquache's Avatar
Thanks, I have two copies of that diagnostic from the dealer. Which plug is C1 on the ECM?
Taquache is offline
post #9 of 46 (permalink) Old 05-20-2012, 10:12 PM Thread Starter
Diesel Junkie
Taquache's Avatar
I checked the ground to the ecm and it feels tight. gotta start ohming out everything.
Do I unplug the connector from the ECM when checking this?
Taquache is offline
post #10 of 46 (permalink) Old 05-21-2012, 09:45 AM
StealthDiesel's Avatar
Here is some PD info on P2149:
Case Number K30540141
Vehicle Issue MIL and the engine runs rough. P2146 or P2149 are logged.;No wiring problems such as a chafed or shorted wire are found per P2146 / P2149 diagnostics.
System or Component Engine Misfire,Rough / Unstable / Erratic Idle,Lack of Power / Sluggish;DTC / Error Message;Yes - Continuously
Recommendation One at a time, disconnect both wires from each injector and insulate the terminal ends so the circuit will not short to ground on the effected bank (1-3 for P2146 or 4-6 for P2149).
Clear the codes and start the engine, check if the same code resets. If an injector is disconnected and the code does not reset, replace that injector.
2004.5 Dodge SB QC 2500 2wd Cummins 600/6spd manual/3.73 LSD
ATS 3K/5K Twin turbos. DDP 50HP tips, F1 valve springs, ARP headstuds.
SBC Dual disk 3250. Smarty. Glacier Diesel intake plate, air horn, fuel & filter system.
MBRP S.S. muffler. BD short shifter. Brakesmart tow controller.
BD exhaust brake. Pullrite 24k Superglide.
StealthDiesel is offline
The Following User Says Thank You to StealthDiesel For This Useful Post:
Taquache (05-21-2012)
post #11 of 46 (permalink) Old 05-21-2012, 10:04 AM Thread Starter
Diesel Junkie
Taquache's Avatar
I'll give that a shot. I'd much rather it be an injector than trying to diagnose the wiring harness. However all my injectors are ohming correctly...
Taquache is offline
post #12 of 46 (permalink) Old 05-24-2012, 04:02 PM
Kman Art's Avatar
Hey Taq, sorry to hear about all of your troubles. Brings back memories of my AC issue. I ended up having to replace my ECM, fan clutch, and my AC compressor.
Good luck n hope you get it sorted soon!
"my job is a figment of hell that I have percieved as an
occupation to help bide my time here on earth.
" - Alabama Mud Machine
Kman Art is offline
The Following User Says Thank You to Kman Art For This Useful Post:
Taquache (05-24-2012)
