Good source for transmission lines. - Dodge Cummins Diesel Forum
post #1 of 4 (permalink) Old 12-05-2010, 09:27 AM Thread Starter
Hey guys where can I get some good transmission lines (ones at the cooler). Both of mine are leaking. Should I leave the check balls in ?
coxey2 is offline
post #2 of 4 (permalink) Old 12-05-2010, 11:06 AM
rgaskell's Avatar
If you don't want to use dodge then try your local salvage yard. If you hate that idea then a hydraulic shop in your area might be able to make the hoses if you bring them a sample. Then there is the aftermarket world. But that can take awhile somethings. Oh the check balls were put there for a reason so I would put them back.
2016 3500 Asisn Megacab Stock for now
rgaskell is offline
The Following User Says Thank You to rgaskell For This Useful Post:
coxey2 (12-05-2010)
post #3 of 4 (permalink) Old 12-05-2010, 02:33 PM
Everything was put in for a reason, not all for a good reason. Remove the check ball......if it sticks it can cause you to burn up your tranny.
Annabelle is offline
post #4 of 4 (permalink) Old 03-25-2011, 01:24 AM
dieseldude5.9's Avatar
Where are these check balls located?
04.5' QC SB, 6" miters, Autometer NV gauges, Smarty TNT-R, AD II, AFE Stg II, MaxSpool Cam, BD 90 hp injectors, 60 lb valve springs, BD Super B Special, Bag O parts, Goerand Full Billet tranny.
dieseldude5.9 is offline
